Old 03-05-2010, 10:56 AM   #1
camphost's Avatar
cleaning calcium deposits on skin
We have large areas of calcium deposits on the outside of our 1976 ambassador - how they got there is a long story.
Any ideas on how to remove the calcium without damaging the skin? We have tried vinegar - long sloooow process.
thanks
camphost
camphost is offline   Reply With Quote
Old 03-05-2010, 11:33 AM   #2
2011 25' FB Flying Cloud
Anywhere & , Everywhere
Meguiars makes a product that sill supposedly remove hard water spots. Have no idea if this will work - it's hard to find - and I can't remember offhand where I've seen it but should be possible to order from the I-net. Seems to me I may have seen another product that claims to do this in Bed, Bath & Beyond but not 100% sure of this.
Al - K4GLU is offline   Reply With Quote
Old 03-05-2010, 12:00 PM   #3
_
camphost...
post PICTURES...
here are some relevant threads and links...
http://www.airforums.com/forums/f441...its-36047.html
http://www.airforums.com/forums/f441...ots-30563.html
http://www.airforums.com/forums/f441...ent-12529.html
howz the original plastikote ???
is there ANY left?
u may be seeing lattice style corrosion instead of water spotting.
ANY acid solution (vinegar) that will work GENTLY will be slow.
stronger acids will eat/etch/degrade the surface.
mechanical agents (clay) will work fine but IF the plastikote is gone will 'polish' the aluminum in undesirable ways.
cheers
2air'
Old 03-05-2010, 02:55 PM   #4
kevin242's Avatar
1977 25' Tradewind
Waskesiu Lake , Saskatchewan
In Canada there is a popular removal product called "CLR" (Calcium, Lime, Rust). I'm not sure if it's available where you are, but for about $10.00 it would be worth a try.
Kevin
Every home needs a dog, and every dog needs a home.
1977 25' Tradewind (with two ... three... FOUR dogs)
2011 Ram 1500 Quad cab, 5.7 Hemi, tow pkg.
kevin242 is offline   Reply With Quote
Old 03-05-2010, 08:07 PM   #5
WILDRTEXAS's Avatar
1970 27' Overlander
ARLINGTON , TEXAS
Images: 31
Send a message via Skype™ to WILDRTEXAS
Can CLR be used on aluminum??
He is your friend, your partner, your defender, your dog. You are his life, his love, his leader. He will be yours, faithful and true, to the last beat of his heart. You owe it to him to be worthy of such devotion...
Taylor 1/20/96 - 11/28/08
WILDRTEXAS is offline   Reply With Quote
Old 03-05-2010, 08:12 PM   #6
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
The website specifically says not to use CLR on aluminum.
Jelmar | All Kinds of Dirty, One Kind of Clean
Do not use CLR on wood, clothing, wallpaper, carpeting, marble, terrazzo, natural stone, colored grout, painted or metallic glazed surfaces, plastic laminates, Formica or aluminum.
Richard
Old 03-05-2010, 08:40 PM   #7
WILDRTEXAS's Avatar
1970 27' Overlander
ARLINGTON , TEXAS
Images: 31
I thought Id read that about CLR. Thanks Richard for protecting our aluminum
Removing mineral deposits on exterior utahredrock Cleaning, Stripping & Polishing 4 08-02-2009 09:24 AM
Question about white aluminum oxide deposits williamhenshall Ribs, Skins & Rivets 11 04-02-2008 12:44 PM
removing hard water deposits djfrantic Cleaning, Stripping & Polishing 11 10-11-2007 03:07 PM
Cleaning Brad Hunt Cleaning, Stripping & Polishing 6 09-14-2007 03:17 PM
Sealing exterior skin panels with Lizard Skin BB 55 Bubble Leaks - Weatherstrips, Gaskets, Caulks & Sealants 15 11-21-2006 04:50 PM
