Old 04-05-2006, 11:51 AM   #1
cameront120's Avatar
1972 25' Tradewind
Cleaning before re-sealing?
I want to re-seel a few joints, but before applying the sikaflex, is there a preferred method for cleaning the area in question? Should the old sealant be completely removed and the aluminum cleaned? If so, how do you do this and what sorts of cleaners or solvents do you use?
Cheers!
North Vancouver, BC
Old 04-05-2006, 12:41 PM   #2
Images: 59
Don't use my method.
I use a pressure washer. Blasted all the seams.
Lots of dirt and corruption comes out. Lots of water goes in.
This only works if you have the inside skins off and the insulation out.
Old 04-05-2006, 12:55 PM   #3
1972 25' Tradewind
I'm trying to prevent more water from coming in, so I will definitely not be using your method!
North Vancouver, BC
Old 04-05-2006, 01:30 PM   #4
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Cameron,
A plastic brush and a mild detergent, then a plastic brush and some mineral spirits. That will get it as clean as it is going to get. Then use Vulkem or Parbond caulk.
Aaron
WBCCI #XXXX AIR #2495
Old 04-05-2006, 01:43 PM   #5
1972 25' Tradewind
Originally Posted by wahoonc
Cameron,
Aaron
Thanks Aaron!
North Vancouver, BC
Old 04-05-2006, 02:54 PM   #6
rebel beck's Avatar
1975 31' Sovereign
Oxford , Mississippi
Images: 35
I love the par bond it is so easy to work with on seams and small gaps. And it matches great. I also like the alcoa gutter seal both of these products come in small tubes whith small tips.
Becky
rebel beck is offline   Reply With Quote
Old 04-05-2006, 03:00 PM   #7
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Images: 40
Becky,
Alcoa gutter seal is good stuff too. I failed a drug test one time because of that stuff
Aaron
Old 04-05-2006, 07:23 PM   #8
1972 25' Tradewind
Have any of you used Sikaflex?
North Vancouver, BC
Old 04-05-2006, 07:35 PM   #9
Images: 59
I use parbond with a 30ml syringe, and Sikaflex for larger seams.
Old 04-05-2006, 07:42 PM   #10
lewster's Avatar
Naples, FL , Hood River, OR
While I agree that Par-Bond and Sikaflex are great for large work, I prefer the pinpoint accurace of Acryl-R. It comes in a little can that a grease gun style dispenser fits on. You just squeeze the trigger to apply. It has a very fine tip and gets into those open seams perfectly
Old 04-06-2006, 12:15 PM   #11
rebel beck's Avatar
1975 31' Sovereign
Images: 35
Cool
Aaron,
How in the world did you fail a drug test with gutter seal or should I ask.
Becky
Old 04-06-2006, 01:54 PM   #12
Over59's Avatar
Putnam , Connecticut
Images: 37
Becky
I think some of the gutter sealers are a silicon product and may not hold up to temperature extremes with movement.
Over59 is offline   Reply With Quote
Old 04-06-2006, 05:45 PM   #13
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Images: 40
Aaron,
Becky
Hehe...the base chemical is Methyl Ethyl Ketone...among others. I had been working in the shop on a rainy day...apparently with insufficent ventilation Went to take a drug screen for a upcoming project and tested postive for something really obscure, like mushrooms The tech was kind of puzzled, and asked me to come back in the morning for a retest. I tested clean the next morning. We finally figured our that the MEK probably gave me the false positive.
Aaron
Old 04-06-2006, 05:47 PM   #14
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Images: 40
Trust me the Alcoa IS NOT silicone it is a MEK based sealant and it work great, in fact try to get it off of anything once it dries. I haven't tried the Acryl-R...yet, but it looks like good stuff at $2 an ounce it better be.
Aaron
Old 04-06-2006, 07:57 PM   #15
flyfisher's Avatar
2004 30' Classic
Field and Stream , PA & MT
Aaron
Isn't Acryl-R what the factory uses now for a number of different applications? If so, you can buy a good sized oil-type can at the factory store for about $20 and they will fill it (and refill the can as you need more) from their bulk supply for about a couple dollars. I got some there
over a year ago, and it's good as new, and ready whenever I need it. That stuff works great.
John
Flyfisher
flyfisher is offline   Reply With Quote
Basic exterior cleaning of a neglected trailer Andy R Cleaning, Stripping & Polishing 12 05-10-2013 11:03 AM
Cleaning Agent (Aluminum Exterior) Cat Cleaning, Stripping & Polishing 20 10-09-2012 05:44 AM
Cleaning Zylotone Trotter General Interior Topics 1 09-02-2002 09:58 AM
Cleaning a 41 year old AlumiTank? Andy R Fresh Water Systems 1 05-21-2002 06:54 PM
White water tank cleaning... Andy R Fresh Water Systems 9 05-17-2002 08:14 PM
