Old 05-11-2010, 06:37 AM   #1
2008 19' Bambi
gallatin gateway , Montana
cleaning and polishing
new owner looking for advice on cleaning and polishing products. Also, does the airstream have a factory installed coating that can be damaged with abbrasive polishes.
gsgofish is offline   Reply With Quote
Old 05-11-2010, 07:08 AM   #2
AIR-Quarius's Avatar
1970 27' Overlander
Espanola , Full Timer
Send a message via Yahoo to AIR-Quarius Send a message via Skype™ to AIR-Quarius
Check out the polishing area in the forums and post that question again.
http://customrvdecalplus.com
AIR-Quarius is offline   Reply With Quote
Old 05-11-2010, 08:02 AM   #3
I'm pretty sure that modern Airstreams like your 2008 come with a clearcoat. I would not advise polishing. You can wash it, as you would a car, and probably wax it as well.
Old 05-11-2010, 08:19 AM   #4
ts8501's Avatar
1990 34' Excella
1964 22' Safari
Savage , Minnesota
It is hard to beat regular old Meguiar's Deep Crystal Car Wash available just about everywhere. It even takes off the sap that we get on our trailer sitting under the trees, and it will not harm the clear coat. That, and it is very reasonably priced.
"I've got aluminum fever, and the only prescription, is more AIRSTREAM!!!"
'64 Safari Resoration Blog ("May"):
http://ts8501.blogspot.com/
TAC MN-6
WBCCI/VAC 11736
AIR 25979
ts8501 is offline   Reply With Quote
Suggestions for cleaning/polishing options with little time? Boondocker Cleaning, Stripping & Polishing 12 01-25-2016 10:32 PM
Cleaning vulkem after polishing ronstory Cleaning, Stripping & Polishing 1 10-26-2008 12:01 PM
Cleaning Wool Polishing Cloths dbaur Cleaning, Stripping & Polishing 13 12-23-2007 01:18 PM
Cleaning and Polishing plastic windows? Resorts Rock Guards, Segment & Window Protectors 2 06-11-2007 07:31 AM
