Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Cleaning, Stripping & Polishing
Old 10-05-2002, 12:16 AM   #1
Cat
Cat's Avatar
Profile:  Mukilteo , Washington
Images: 8
Cleaning Agent (Aluminum Exterior)
I have a travelling 'detail' guy that will come out and clean my whole 32 footer...for $150.00.
I asked him what compound he uses...and he gave me this "recipe"..:
50 % Simple Green
40 % Clorox Bleach
10 % pink boat soap "Algae remover"
Any thoughts on this???? Andy? Jack? Peter? Anyone?
Should Walbernizing be done INSTEAD? AFTERWARD?
Should this recipe be SCRAPPED? Is it redundant if Walbernizing is being used?
............Cat
*Cat's Vardo "Bear" (1981-32ft.Excella)
http://autos.groups.yahoo.com/group/RoyalTrailerTrash[/u] to meet good people in good Parks[/i]
Cat is offline   Reply With Quote
Old 10-05-2002, 07:42 AM   #2
BobbyW
BobbyW's Avatar
Profile:  1965 20' Globetrotter
Houston , Texas
I would never use Simple Green or Bleach on aluminum. The Simple Green, like Dawn, will strip any wax you have on there now and it WILL discolor aluminum. It is for degreasing.
Plus his percentages on the soup are way to strong.
Use only automotive, clearcoat safe soap (Maguires) and water. Then Walbernize. This is tried and true.
-BobbyWright
-BobbyW AIR# 123
-Guess what? I got a fever! And the only prescription.. is more cowbell!
-"You want to make it two inches - or, if you're working in centimeters, make sure it's enough centimeters for two inches."
-Red Green
www.bobbywright.com/gallery
BobbyW is offline   Reply With Quote
Old 10-05-2002, 08:05 PM   #3
Cat
Cat's Avatar
Images: 8
Cleaning Agent Recipe
Thank you Bobby..
I THOUGHT so...that's why I asked you guys...I knew someone would be sure enough....& I had a FEELING that's what someone would say.
It's probably a job like my shower... I'm fearing it more than I need to... Is that correct??
My 'tile/wallpaper' advisor/expert told me (about the shower) ..."JUST DO IT"..
Do you have any special instructions for using the McGuire product (like the size to work with before rinsing and drying, etc.?)...
(P.s. that's ALL my son will use on any of our vehicles.)
The "Walbernizing" ... where is the least expensive place tobuy that?
Thanx again
Old 10-05-2002, 09:42 PM   #4
68 Overlander
Commercial Vendor
Profile:  Boise , Idaho
Images: 21
Cat,
I fly for the military and can assure you that our mechanics stay away from Simple Green and Mean Green, etc. because they are corrosive to aluminum. The military has banned there use on aircraft. On the other hand, Mean Green is the best product I have found to remove the "sticky ceiling syndrome" and Simple Green works too. Have him use Dawn detergent on the skin.
Randy
Old 10-05-2002, 11:14 PM   #5
BobbyW
BobbyW's Avatar
Houston , Texas
Only use Dawn if you want to remove all traces of previous wax/Walbernize jobs (and do the dishes) and are preparing to immediately follow-up with a Walbernize treatment.
I would just rather see you use a Clearcoat safe automotive wash. These have lubricants in them to minimize sratches and swirls.
To really be Airstream Politcally Correct, you could use Walbernize's "SoapMaster" or "OneStep". Both designed for Aluminum finishes.
-BobbyWright
-BobbyW AIR# 123
-Red Green
Old 10-05-2002, 11:46 PM   #6
68 Overlander
Commercial Vendor
Images: 21
Great point Bobby,
I was thinking grime, bug guts, and grease and trying not to damage the Plasticoat or aluminum. Dawn will cut wax products and you are right. Thanks.
Randy
Old 10-06-2002, 04:29 AM   #7
Cat
Cat's Avatar
Images: 8
Washing
Thanx guys,
as I said, my son recommends Mothers products, and McGuires...and he says the McGuires is good.
BTW, Bear's aluminum finish is in VERY GOOD shape, and obviously has the clearcoat in tact. He just didn't get a good wash this past spring, and a bit of algae has built up. The spring before, he was cleaned very good.
Should I do it now? or wait until spring?
Old 10-06-2002, 02:07 PM   #8
ALANSD
GA Airstreamer Air_005
Profile:  North , Georgia
I use a mild solution of Armorall car wash I buy at Walmart by the gallon jug. Fairly inexpensive, and my 20 yr old plasticoat looks great. I then wax with liquid non-abrasive car wax, goes on easy and has maintained my shine well. I have used Meguir's and Turtle wax liquids. Happy with both.
You wilol be surprised at how a little wax will shine up that bullet.
Old 10-06-2002, 09:14 PM   #9
Cat
Cat's Avatar
Images: 8
SHINE
<smile>
can't wait...it's like most other projects on these guys (the A/Ss)...we shouldn't sweat it... JUST DO IT! ...
Old 10-07-2002, 09:33 AM   #10
jcanavera
jcanavera's Avatar
Profile:  2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Cat, I also use the Armorall car wash, no petroleum additives and no amonia additives, both no-no's. It seems pretty kind to the Walbernize. I'm going to Walbernize the Safari once I get back from next week's trip to Branson and prior to going into winter storage at month end. It's nice to start off spring with a shiney slick trailer.
Regards,
Jack
Jack Canavera
STL Mo.
AIR #56
'04 Classic 30' S.O.
'03 GMC Savana 2500
'08 Vespa GTS 250
Old 04-16-2004, 08:10 AM   #11
Blackjack
Profile:  Beckley , West Virginia
Greetings everyone...this is my first attempt to communicate on this forum so please bear with me. I have just purchased a '69 Land Yacht which appears to be in original condition. Well, that's what the seller told me but I have found several stretches in his stories so this is suspect too. My question concerns the exterior aluminum skin. It appears that someone has used silver spray paint in several areas and I would like to know how to remove it. It also has some hail damage showing on the top and I was wondering if one of these "paintless repair" products might work.
Blackjack is offline   Reply With Quote
Old 04-16-2004, 10:42 AM   #12
ALANSD
citrus strip would remove it , also mineral spirits would probably do the same although maybe more caustic. What you find underneath may be interesting, but if you get it off and see good metal, you can start the polish process right there. Hail damage is tough, the dent wizrd guys might be able to help,though I don't know how they would do on aluminum. That area could be filled and painted silver, but if you hate the silver paint idea the next step is redoing th panel that is dented. If you look at Inland RV's site there are painted trailers on there to view. They look good.
Rallys twice a year..Lots of fun, food, and aluminum.
http://groups.yahoo.com/group/gaairstreamcampers/
http://airstreampassion.blogspot.com/
My Music Site:
HTTP://ALANDAVIDSONGS.COM
Old 04-18-2004, 05:54 PM   #13
Cat
Cat's Avatar
Images: 8
But, don't you have to paint them all over...like a total paint job on a car?
I saw one all creme coloured...it looked fantastic!!! and I saw one all RED...& it looked fantastic!!!
Maybe the person who was painted hers BROWN & creme with black marks to look like slices (loaf of bread?)...
It's all too cutesy for me...but then, whatever floats your Airstream, eh?
Re: The Hail...I read once to use a hair dryer to warm the dent...then use an icecube---and it apparently creates a vacuum which POPS it back out. Sounds too easy to me. ANYONE KNOW IF THIS WORKS?
........I'm gone to post my Curtain Tracks FOR SALE in the Forum of Items For Sale...Finally started understanding my digi camera a little..
......see ya yang.
............Cat
Interior Aluminum Replacement swebster Upholstery, Blinds, Walls & Interior Finishes 34 02-24-2005 10:14 PM
replacing aluminum on exterior cherring Ribs, Skins & Rivets 2 09-25-2003 03:08 PM
believer in aluminum tanks! JohnGalt48 On The Road... 7 08-15-2002 06:49 PM
What to wash your new trailer with. jcanavera Cleaning, Stripping & Polishing 53 07-11-2002 02:17 PM
Basic exterior cleaning of a neglected trailer Andy R Cleaning, Stripping & Polishing 2 02-25-2002 08:37 PM
