Old 05-18-2012, 02:49 PM   #15
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
That is a great cleaning solution for fiberglass, I use a similar concoction on boats, but I would never use it on Aluminum. Way too corrosive.
MICHAEL
Old 05-18-2012, 03:09 PM   #16
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
2 years ago I cleaned the interior panels with a bleach mix called 'Patio Furniture Cleaner'. It did a great job on the plastic fabric laminate aluminum on tthe interior of my '66. When I cleaned that material that lines the inside of the door the door was open. I sprayed that cleaner on and cleaned that up beautifully. BUT When I closed the door I discovered that the overspray landed on the outside aluminum side. 2 years later I am still polishing out the spots.
Neil
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 05-19-2012, 04:08 AM   #17
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Originally Posted by jgbyler View Post
I was just reading this post because my new (1971 Silverstream) is now in my possession and I notice these tiny white spots all over the aluminum. It has been sitting for 10 years but I don't think the exterior has ever been cleaned other than with water. Could you give me a recommendation on how to remove the white spots/oxidation? and get the aluminum in clean looking condition? I also have a strip of gold on the trailer about 5" wide around the centerline... Thank you...
Streamline is the trailer brand.
The exterior skin is not like an Airstream except that both are aluminum. The alloy and thickness are different, and the skin has been anodized (a hardening process) to avoid typical aluminum discoloration, etc.
Search in Vintage Kin on how to clean anodized (and what to avoid).
Old 10-08-2012, 03:21 PM   #18
dcasr's Avatar
1990 29' Excella
Stone Mountain , Georgia
I'm trying to find something that will take the sticky residue off of the front of my 1990 Excella. Previous owners had their numbers, stars, WB circular decal on the aluminum, and although I got them off, I can't get anything to take off the residue.
Tried soap, then Truck Box Polish, then same with a PC polisher, then mineral spirits, then goo gone and nothing cuts it. Acetone probably would but that is one of my final most drastic choices. Should I go ahead and use paint stripper and take off the remains of the clear coat, would that do it? I don't want to use anything that will pit or damage the aluminum.
+dcasr
dcasr is offline   Reply With Quote
Old 10-08-2012, 03:46 PM   #19
c_lewis77's Avatar
1982 34' Limited
Brunswick , Georgia
Images: 22
+dcasr
Try a heat gun
1982 34' Limited
2000 Excursion V10 4x4
WBCCI #3321
TAC #GA-24
c_lewis77 is offline   Reply With Quote
Old 10-08-2012, 05:00 PM   #20
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
I've seen recommendations of using MEK as a last resort (for your FYI Box, not as first or even second choice).
Old 10-09-2012, 05:44 AM   #21
dcasr's Avatar
1990 29' Excella
Thanks. I did use a hair dryer gun on high (it was quite hot) to get the decals off in the first place, that and a plastic scraper. I could use a painter's heat gun but that has scorchingly hot heat. I was afraid of getting the aluminum skin too hot in one place and have it distort.
dcasr
1990 Excella 29
1999 GMC 2500 4x4
7.4 Suburban
Stone Mtn. GA
Interior Aluminum Replacement swebster Upholstery, Blinds, Walls & Interior Finishes 40 05-16-2017 04:58 AM
Basic exterior cleaning of a neglected trailer Andy R Cleaning, Stripping & Polishing 12 05-10-2013 11:03 AM
replacing aluminum on exterior cherring Ribs, Skins & Rivets 2 09-25-2003 02:08 PM
believer in aluminum tanks! JohnGalt48 On The Road... 7 08-15-2002 05:49 PM
What to wash your new trailer with. jcanavera Cleaning, Stripping & Polishing 53 07-11-2002 01:17 PM
