Old 12-17-2002, 09:50 PM   #1
citrus based paint remover -anyone use it ?
Hi,....
Any one use the citrus based paint remover that you can get at Home Depot etc
Does it remove the clear coat ?
one coat or 2 ?
The airctaft stripper works but is pretty nasty to work with.....
oldvws is offline   Reply With Quote
Old 12-17-2002, 10:29 PM   #2
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
CitriStrip
The citrus-based stripper is fairly strong but it doesn't even put a dent in the factory Zolotone. Never tried it on clearcoat. Worked quite well on the four different layers and colors of house paint a PO or POs put on the original Honduran Mahogany though. Takes off skin too, if unattended.
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 12-17-2002, 10:45 PM   #3
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
clearcoat
Yep, it works..look at it in action . Photos under towner7's name for results.
Same rules apply here for usuage: Wear protective clothing, eye protection, etc.
I used several coats in areas that were tough. Generally, one coat was enough to remove the clearcoat. Very messy~!!
I wiped mine down with wet rags when it was ready. Keep a large bucket of water handy~! You might be able to just 'hose' it off but, I felt like this would create a bigger mess. Your call on that.
Tried "aircraft stripper" as well, bottom line: it works better for those really tough spots.
No matter what you use, it's alot of work. But, it's the most important step in the process of polishing your A/S.
ciao
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is offline   Reply With Quote
Exterior paint peeling! Astrodokk Airstream Motorhome Forums 2 08-10-2003 08:18 PM
Eternabond Paint to match Crsoley Kid Airstream Motorhome Forums 0 08-05-2003 06:15 PM
'92 paint vs. clearcoat fangthorpe Clearcoat, Exterior Paint & Trim 1 06-22-2003 10:23 PM
Paint Removal from side of A/S Lexxy Clearcoat, Exterior Paint & Trim 2 08-19-2002 07:03 AM
Question on what kind of paint to use for interior respray williamhenshall Upholstery, Blinds, Walls & Interior Finishes 2 08-15-2002 05:39 PM
