Old 08-23-2010, 08:21 AM   #1
1978 28' Ambassador
Savannah , Georgia
Cheap rivet polisher
I am not an expert by any means. Try this at your own risk. Faced with years of salty corrosion around the rivets, I tried many different things. Neighbor who restores motorcyles suggested taking a piece of black vacuum tubing and putting it on a bolt that had the head cut off. Secure it to a drill and then put a dab of polishing compund on the end. The tubing is about the same size as the head of the rivet. 4 seconds of polishing and the corrosion disappeared. The same principle as what a dental hygenist uses to polish your teeth. Only used a dab of marine 3M polishing compund and the areas around the rivets and the rivets shined like a new dime. May expertiment with other polishes. Needless to say this saved me alot of rubbing with bronze wool. Hope the pics show my results. Jack
Name:	Airstream rivet polish tool 002.jpg
ID:	109192   Click image for larger version
Name:	Airstream rivet polish 013.jpg
Name:	Airstream rivet polish 014.jpg
Skamper1 is offline   Reply With Quote
Old 08-23-2010, 08:46 AM   #2
Distantdrummer's Avatar
1975 31' Sovereign
Houston , Texas
Arrow Sweatshirt salvation
Interesting. Thanks for the tip. (no pun intended)
Seems though that the center of the Rivet head would not get touched by the open area in the rubber hose. Leaving sort of a dull bullseye.
How far from the polishing end of the device do you have before the inserted bolt. (i.e. the recess)?
Does the rubber seem to wear away quickly?
Maybe rubber is a secret material to polish Airstreams all over..??? Thus conserving the world's sweatshirt population.
__________________________
____ d'drummer ____
...aahh..rumm..pu..tum..tummm...
Distantdrummer is offline   Reply With Quote
Old 08-23-2010, 08:47 AM   #3
1977 Argosy 24
Milltown , Wisconsin
Looks great, thanks for sharing.
ventport is offline   Reply With Quote
Old 08-23-2010, 09:51 AM   #4
1972 Travelux Princess 25
Cobourg , Ontario
They make hard felt polishing mops for this kind of thing.
Living in the trailer park of sense, looking out the window at a tornado of stupidity.
Ganaraska is offline   Reply With Quote
Old 08-24-2010, 05:56 AM   #5
1978 28' Ambassador
Savannah , Georgia
The recess is about one half inch. So on a one inch piece, half of it is on the bolt. Used the first one on about thirty rivets. It appears that the inside edge of the tubing does wear down with use. Takes about 2 seconds to replace with a new piece. I spend about eight seconds on each rivet and not the four I orginally stated. Have not noticed any bullseye effect. My main goal was to remove the corrosion from the recessed area between the edge of the rivet and the AS. Attacked another area that was worse than the front. It took two passes to remove the corrosion. Will try to use "Mother's" to see if there is more shine. Hard felt pads are an idea, but I bet they are not as cheap as the tubing or easy to find.
Old 08-24-2010, 10:13 AM   #6
Soyboy's Avatar
1999 28' Excella
Frederick , Maryland
Images: 44
Seems like Dremel would make a bit/tool that could do this to.
1999 28' Safari
2012 F150 Platinum Max Tow 7650 GVWR 3.73 Elec. Locking Diff.(Prev 2003 Dmax).
Honda EU2000i, Equalizer Hitch
AM Solar Panels 150W - 2 Trojan T 105 6V Batteries
TAC MD-6
AIR 4534
On internet forums, please research and separate the wheat from the chaff (including mine!)
Soyboy is offline   Reply With Quote
Old 08-25-2010, 05:34 AM   #7
1978 28' Ambassador
Savannah , Georgia
Yes they do make attachments for a Dremel, but found they do not last and are expensive compared to vacuum tubing. Used the buffing pads and at $2 each, it was going to get costly for 28 feet of fun.
How durable is a Cyclo polisher? What about a rivet shaver? Andy R Cleaning, Stripping & Polishing 13 09-13-2011 05:56 AM
Which polisher? SilverHoot Cleaning, Stripping & Polishing 17 10-27-2009 05:09 AM
Factory rivet vs. repair rivet yukionna Ribs, Skins & Rivets 32 09-08-2003 04:41 AM
