Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Cleaning, Stripping & Polishing
Old 06-17-2006, 07:31 PM   #1
glacierrunne
Profile:
Car Wax on Airstream?
I use Meguiar's GOLD CLASS liquid car wax on my cars and really like it. Is there any problem using it on my 1980 Caravelle? Thanks, Don
glacierrunne is offline   Reply With Quote
Old 06-17-2006, 08:44 PM   #2
uwe
418
uwe's Avatar
Profile:  1963 26' Overlander
1958 22' Flying Cloud
1963 19' Globetrotter
Portola Hills , California
Images: 40
Don, there's aproduct that is supposedly formulated for the clearcoat of an Airstream it's called 'Walbernize".
I believe that your Gold Class wax will work very well also, but might not last as long. The Walbernize seems to give a good and long lasting protective finish on clear coated Airstream finishes.
Uwe
Old 06-17-2006, 09:24 PM   #3
glacierrunne
Profile:
Uwe, I bought some Walbernize and tried it on a small spot and didn't shine up the area much so I'd thought I'd try my wax and see if it looks better. I see turtle wax has a new product called ICE, I'll wait and see the results from other memebers. Thanks, Don
Old 06-17-2006, 10:25 PM   #4
flyfisher
flyfisher's Avatar
Profile:  2004 30' Classic
Lancaster County , PA & MT
I've used the Gold on my Airstream, and it worked okay, and I often use Meguiar's cleaner and wax on my Airstream, as well as on my truck and wife's car. I think either will work just fine.
I've used Walbernize on my Airstream, and it just seemed so-so to me. I think all the hype it gets from Airstreamer's is pretty much the same as those old wives tales - something that's been passed down from generation to generation, and before you know it, it's passed off as fact.
John
Flyfisher
flyfisher is offline   Reply With Quote
Old 06-17-2006, 11:46 PM   #5
glacierrunne
Profile:
John, I agree with you on the hype thing-- it's a marketing job. I'll like to hear about Turtle Wax ICE! Thanks, Don
Old 06-18-2006, 01:29 AM   #6
Safari-Rick
U.S.Navy Retired
Safari-Rick's Avatar
Profile:  2005 25' Safari
Lakewood , California
Waxing
I agree with flyfisher.
I just waxed my 25 with turtle wax emerald and it did a heck of a job. I had a friend come by with out mentioning a word and he right away noticed..."did you wax your TT?" yep, "looks like new"!
And the bugs and bird poop come off easier with waxing.
For what it's worth.
R/
Safari-Rick
"Better to have more then you need, then need more then you have because you don't have enough!"
AIR #: 8129
Safari-Rick is offline   Reply With Quote
Old 06-18-2006, 07:59 AM   #7
lewster
Commercial Vendor
lewster's Avatar
Profile:  2006 19' International CCD
Marco Island, FL , Hood River, OR
Rejex
When I first got my CCD, I read all of the threads and got some Walnernize . Atfer applying it so a small spot of the trailer, I really didn't like the finish, but thought that I should give it a try. I ended up polishing half with Walbernize and the other half with Rejex, which is a polymer product that I have been using on a regular basis since my MoHo days. It is available from www.corrosionx.com.
That was in Jan. After looking at the A/S yesterday as I get it ready for my trip, the Walbernize side is not as bright as the Rejex side, and the water beads are not as distinct......almost non-existent. I would say that I prefer the Rejex and will re-do the T/T as soon as I have the time. The CCD is stored outside, so it is a pretty good indicator of who expect. Plus, the Rejex makes it far easier to remove tar and bugs, from prior experience of owning a bug magnet (also known as a motor home).
Lew Farber - contact
Certified Master RV Tech
BACK IN THE 'HOOD' FOR A WHILE !!
"Laissez Les Bon Temps Roulez"
www.islandmetalworks.com
WBCCI #1032/VAC (assoc) #1032
AIR # 10325
CHARTER MEMBER: FOUR CORNERS UNIT
Old 06-18-2006, 08:06 AM   #8
uwe
418
uwe's Avatar
Images: 40
I had excellent results with the Walbernize Super Seal and Glaze. Water kept beading and rolling right off the surface for close to a year. You might have a point on it's shine, but I was more concerned about protecting what was left of the clear coat on the 71.
Uwe
Old 06-18-2006, 08:13 AM   #9
uwe
418
uwe's Avatar
Images: 40
Lew,
The Rejex sounds promising to protect my newly polished 63. Plus, it says that it is available at True Value hardware stores now. There's on of those close to work. Will definitely try this, as it says it is formulated to stick to chrome and polished metals. Thanks for the link.
Uwe
Old 06-18-2006, 09:32 AM   #10
kevino
Timberlake , North Carolina
Gold Class
I used the Meguiar's gold class on my 2005 Safari. It's what I had on hand as this is what I use on my vehicles. The Meguiar's did a fine job and that's probably what I'll continue continue to use.
I think the manual says to use an automotive type liquid or paste wax. I know lots of folks here use Walbernize and have excellent results.
kevino is offline   Reply With Quote
Old 06-18-2006, 12:47 PM   #11
tpi
Trabuco Canyon , California
I take care of the Airstream much I have taken care of all my other vehicles over the years.
I use lots of Meguiars "quick detail" with frequent washings. I find I can postpone the heavy rubouts. My trailer is 18 months old and the sides have only had the Quick Detail and look great. I did have to get on the roof and rub it out with cleaner wax to get a nice white shiny surface.
When the sides start to look oily or dingy, then I'll go with some automotive cleaner wax.
tpi is offline   Reply With Quote
Old 06-18-2006, 02:11 PM   #12
lewster
Commercial Vendor
lewster's Avatar
Originally Posted by uwe
Lew,
I use it on just about every surface....especially the windshield and window glass. I like it's water repelling action and I find that at highway speeds I don't need the wipers on as the water blows right off the glass!
Just be sure to follow the directions and have a place out of the sun to let it dry. It also has 'cure' for 12 hours with no water on it. An added benefit is that it wipes off very easily with almost no effort......wax-on/wax-off!
AIR # 10325
Old 06-18-2006, 02:19 PM   #13
ALANSD
GA Airstreamer Air_005
Profile:  North , Georgia
I used Turtle wax and Meguir's until i doscovered the Liquid Glass polymer sealant, thru someone here who used it on his boat. It holds up much longer than wax, and is very hard, a it cures in the sun.
It had been great on keeping my clearcoat and bare areas sealed. I stripped the lower area on my Moho to the bare aluminum, and sealed it with LG, it held up and shined well for about 10-12 months. One can did my 28' more than two times.
Rallys twice a year..Lots of fun, food, and aluminum.
http://groups.yahoo.com/group/gaairstreamcampers/
http://airstreampassion.blogspot.com/
My Music Site:
HTTP://ALANDAVIDSONGS.COM
Old 06-18-2006, 03:47 PM   #14
thecatsandi
More than one rivet loose
thecatsandi's Avatar
Profile:  2006 31' Classic
Missoula , Montana
Be careful what you use if you trailer is still clearcoated.
Some of the waxes are high in silicone and can interact with the clearcoat, softening over time. Leads to peeling.
Michelle
I'm not afraid I learned to drive in Washington, DC
Sarah
Ruby, (05 BMW R1200RT) serviced and put to bed for the winter
Daisy, (06 Diesel F-250 w/Tow Command)
Butter Cup, (06 Classic 31 w/dinette, solar)
http://Michelles-Adventures.US
Airstream vs. Avion? 68 Suburban Vintage Kin 29 11-21-2008 08:35 AM
Cost to restore a gutted Airstream Draco General Interior Topics 19 02-06-2007 02:04 PM
future airstream motorhome betteleal Airstream Motorhome Forums 11 02-12-2005 02:39 PM
Airstream Related List Servers Andy R Link Archive 0 02-22-2002 03:05 PM
AirstreamTrailers.com - Airstream Link Library Andy R Link Archive 0 02-22-2002 02:31 PM
