Old 09-22-2009, 01:37 PM   #15
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Originally Posted by ryan3326 View Post
Well, we went ahead and stripped using Removall 220 and can't believe the difference. I think we are going to leave her - "as-is" for a while and enjoy her. Here is a look before and after...
Looks great! I agree, that looks much better than the milky, failing clearcoat ~ any oxidation you do get before deciding to polish will at least be even. Our '64 was splotchy from the clearcoat failing overtime - even when stripped it still had oxidized splotches. But ours was another 10 years older than yours by the time we stripped it ~
Shari
Old 09-22-2009, 03:12 PM   #16
1972 31' Sovereign
1985 31' Excella
2010 31' Classic
Hendersonville , Tennessee
It really does look good.
How did you paint your blue stripe?
NashBuff is offline   Reply With Quote
Old 09-22-2009, 03:21 PM   #17
Iwannagocamping
Dakota's Dad's Avatar
Rineyville , Kentucky
I don't think they painted it, I know I didn't, it's supposed to be this stuff, and is what I am using..
See our blog here on how two RV/AS rookies tackle a 1979 Sovereign resto!!
Just the photos.. (sometimes you don't need the blog, just a picture worth a thousand words..)
1979 Sovereign International
2004 Ford Expedition Eddie Bauer
2 Golden Retrievers
Air #36788
TAC#3179
WBCCI #1265
Dakota's Dad is offline   Reply With Quote
Old 09-22-2009, 03:45 PM   #18
1972 31' Sovereign
1985 31' Excella
2010 31' Classic
Oh, thanks. Is is hard to put in?
Old 09-22-2009, 04:32 PM   #19
76sovereign's Avatar
1976 31' Sovereign
ozark , Missouri
What an amazing difference!!!!!! My husband has been wanting to do this to our for awhile now.....I will make sure he see this post....Thank you
before:
and after:
76sovereign is offline   Reply With Quote
Old 09-22-2009, 04:34 PM   #20
1976 31' Sovereign
ozark , Missouri
HOW MUCH Removall 220
How much of the Removall 220 did you buy to get this look?
Old 09-22-2009, 05:52 PM   #21
2001 30' Classic S/O
2001 36' Land Yacht XC Diesel 300 hp w/slide
Helotes , Texas
Smile
I stripped just above the belt line on my 1995 Excella with Removal 220. I did not take the lens off nor did I mask anything. Painted it in waited 2-3 hours power washed it off, and it looks GREAT. I applied Maquires Gold paste wax left it on overnight and buffed it out, Put on new letters and ready to go. Did it all in 2 days, Hope you are as happy afterwards as we are.
Good Luck
lsmith is offline   Reply With Quote
Old 09-22-2009, 07:09 PM   #22
Roadrunner's Avatar
1978 29' Ambassador
1974 25' Tradewind
1974 27' Overlander
Indiana , Pennsylvania
That Does It!
Well after seeing what a great job you did...I am going to apply the Removal 220 to our "78" Ambassador tomorrow and hope for the same results. Do you think it is necessary to use a power washer or will a garden hose suffice. I'm hesitant to be blasting high pressure onto the exterior shell. Great job!
Roadrunner is offline   Reply With Quote
Old 09-23-2009, 05:59 AM   #23
Helotes , Texas
I used a power washer because I have my water pressure regulated down to 35 psi for my irrigation system. I also removed some faded blue tape at the top of the trailer
Old 09-23-2009, 10:41 AM   #24
Islay - 63 O.
dufferin's Avatar
Montreal , -
Images: 11
Send a message via MSN to dufferin
I did mine with water hose and it was enough...
dufferin is offline   Reply With Quote
Old 09-24-2009, 05:44 AM   #25
ryan3326's Avatar
1976 31' Sovereign
Columbus , Indiana
thank you for the compliments... We bought 2 containers of Removall 220 and honestly, our 31' could have used just one. We have plenty left over. We applied the stripper as directed with a natural brush on the sides and lower and an extended roller on the top. Let it sit for 3-4 hours and used a pressure washer to remove. We did have a few areas that needed a second coat - so we just reapplied everywhere for round two (it really goes on easy).
After stripping the second time we cleaned her up and hence the photo that you see.
I should say that we did remove what was left of the blue beltline, all plastic lenses, etc. before stripping. I didn't want to take the chance that I would need to replace all of these.
The very top of our Sovereign had very little clear coat remaining - and as a result, oxidation. You can see in the bottom photo the oxidation. Our plan now is to use Mothers Aluminum Polish on a random orbital auto buffer to remove/minimize the oxidation. We have tried a few areas and it appears to REALLY work. Once we get the oxidation under control and make sure that the lightly polished top blends well with the unpolished sides and shoulders - we plan to wax with a carnuaba paste wax to eliminate future oxidation.
I have read that we may then need to wax a couple of times per year after the first time - but that doesn't scare me too much at this point. The bottom line is we were looking for some way to clean up the exterior of our AS without the expense ($3000 - $6000) for a full polish or the countless hours needed to polish ourselves. We have only owned our AS for 20 days and the list of time consuming projects grows daily (a labor of love!) We didn't want to put everything else on hold to embark on a full polishing project.
ryan3326 is offline   Reply With Quote
Old 09-26-2009, 06:57 PM   #26
airstreamhobo's Avatar
Ryan 3326...Last night I went to Home Depot looking for 220Removal, But they never heard of it? Is it under another brand name? or what is the correct name? How much did you buy? Quart cans...gallon cans?? What about awnings,did you cover,protect them? I saw some one covered windows with garbage bags and tape them. Should I remove the front window awning guards (the dark ones)? Thanks ..Airstreamhobo
AirstreamHobo
Lancaster Co. Pa.
1999 28' Excella
Ford Diesel Van "The Obie Van"
WBCCI #2590
TAC PA-2
http://airstreamhobo.blogspot.com/
airstreamhobo is offline   Reply With Quote
Strip 'n Polish Project Thread (lots of great tips and links) Ferroequine Cleaning, Stripping & Polishing 422 03-11-2018 08:46 PM
half polish, dull, or matte, polish techniques ? greenrig Cleaning, Stripping & Polishing 9 07-11-2009 10:11 PM
To strip or not to strip. That is the question. mjmcwhorte Cabinets, Counter Tops & Furnishings 2 01-16-2006 08:10 AM
Strip & Polish ..In the Winter Julison Cleaning, Stripping & Polishing 3 11-26-2005 09:22 AM
Strip and polish Argosy. can it be done? vm777 Cleaning, Stripping & Polishing 11 07-12-2003 02:28 PM
