Old 08-15-2015, 01:34 PM   #1
1997 25' Safari
mastic beach , New York
Brushed skin with unrepairable blotch spots
The question is not new, except to me.
I have a 1995 or 97 brushed Safari with blotch spots on the skin which definitely need repair.
Is it a good idea to sandblast the skin entirely and re surface with the same material?
Pond
pond is offline   Reply With Quote
Old 08-15-2015, 01:50 PM   #2
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
Certainly not sandblast. Sand is too heavy and sharp and cuts and stretches the Al. Maybe someonw with sandblasting experience will chime in. I did some Al cleaning with walnut hulls as the blast medium years ago but that Al was thicker and stiffer than the Al skin on a trailer and we still stretched it some. I do not know what to suggest but I do not think sandblasting is the way to proceed.
Old 08-15-2015, 02:23 PM   #3
2007 25' Classic
Hutto , Texas
I had a '97 Safari. Had the clearcoat replaced once under warranty. It failed again after a year or so. We bought a couple gallons of stripper at the hardware store and stripped all the coating off.
I used Nuvite and a triple reduction Dewalt drill and polished the whole thing. Big job but it looked nice.
I would not use any blasting if I were you. It will not be good on the skin.
Wanderer2604 is offline   Reply With Quote
Old 08-16-2015, 11:18 AM   #4
1997 25' Safari
Thank youz! Big job sounds about right. A 6" disc on a 27 foot trailer!
These blotches have 3 different tones color.
Old 08-16-2015, 11:37 AM   #5
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Pay to have it clear coated. If you were near Oregon I'd recommend McIntire. Hell, I still would recommend him.
Old 08-17-2015, 01:40 PM   #6
WBCCI # 23456
2000 30' Excella
Greeneville , Tennessee
If you choose to blast, use baking soda as a medium. My 2 cents.
jimfa440 is offline   Reply With Quote
Old 08-17-2015, 08:05 PM   #7
1996 25' Excella
Tillsonburg , Ontario
I have a photo of polished corrosion marks form work done on my '89 at P&S Trailer Service in Helena Ohio. I highly recommend them and they are fairly close to you. The polishing is just enough to remove the marks and not be too shiny. You do lose the brushed look!
I don't seem to be able to add the image to this post ...help anyone! Do I have to put it on the cloud?? Can't copy and paste
You cannot blast ...not even Soda. Leaves a dull finish that is hard to even polish to bright metal
JCW
JCWDCW is offline   Reply With Quote
Old 08-18-2015, 03:22 AM   #8
1997 25' Safari
The pictures would be great. Before n after.
Mike
Old 08-18-2015, 12:13 PM   #9
2010 28' Flying Cloud
Slidell , Louisiana
You can restore and match the brushed finish by usind gray, red, or green scotch brite pads...practice on a piece of scrap aluminum to pick the coarseness of the finish you want. Use light straight strokes in only one direction. It helps to use a short 1x4 as a wrist guide to keep the brush marks straight. Also works great to refinish segment protectors....just practice and go slow.
dayner is offline   Reply With Quote
Old 08-18-2015, 01:37 PM   #10
1979 23' Safari
Wayland , New York
You CAN NOT sand blast the sides, not with anything, it will ruin the finish. Sand blasting with sand will ruin it beyond belief, soda and anything else will leave it worse than your blotches and un-polishable at that point.
As a point of reference I had the banana wraps sand blasted since they get painted anyway. They became so rough and pitted that I actually had to use heavy grit sand paper just so smooth them out. Doing this on the aluminum skins you actually want smooth and shiny WILL RUIN THEM.
Also sand blasting generates a lot of heat, and will warp sheet metal. You'd be amazed at how much heat and how fast it will warp the sheet metal. I could actually see it happen on the banana wraps, but knew I could flex them back later, can't do that with the skins and they would end up all wavy. From about 50 feet away, to stay out of the dust cloud, I could watch the blaster. With literally a second of blasting it was amazing to watch the banana wraps curl up really quickly and so much that it was impossible to miss.
The blotch is likely failing clear coat. Strip the clear coat off completely, then polish, if the clear coat was mostly intact the polish won't be as difficult.
Brushed look for interior skin Flysoncloud Upholstery, Blinds, Walls & Interior Finishes 10 08-30-2010 01:59 PM
Brushed Aluminum Skin Protectant timatron General Interior Topics 15 06-01-2010 12:11 PM
Brushed Surface Help Randy Johnson Ribs, Skins & Rivets 2 05-05-2003 04:57 PM
Fixing a scratch on a brushed finish? acwdgw Cleaning, Stripping & Polishing 3 10-22-2002 01:27 PM
polish a brushed trailer? john hd Cleaning, Stripping & Polishing 6 08-25-2002 10:03 PM
