Old 02-05-2012, 05:37 PM   #15
1972 Travelux Princess 25
Cobourg , Ontario
Older cars had trim that was held on the same way and this problem came up all the time. One popular solution is to use a special double sided tape made for trim installation.
Stick the tape on the back of the letter, carefully cut around the outside, then peel the plastic off the back of the tape, and stick the letter in position.
You should be able to get a bit of the tape from a friendly body shop. If you buy it you will have to buy a whole roll, enough for 100 trailers.
Living in the trailer park of sense, looking out the window at a tornado of stupidity.
Ganaraska is offline   Reply With Quote
Old 02-09-2012, 10:16 AM   #16
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
JB weld worked like a champ. Letters are installed on the Safari and the posts seem totally secure under the tension of the speed nuts.
To get the finish, I polished the face of the letters first, then masked off the raised edges using painters tape and a razor blade. A light coat of aluminum primer (rustoleum from HD) and two coats of Sail Blue (rustoleum from HD) finished the job. Once the masking tape was peeled off, a careful polish of the face removed any paint that leaked onto the edges.
Name:	P1000736 repaired letters-s.jpg
Zep
Honda 3000i Handi for late 70s Sovereign? Airstream Dad Electrical - Systems, Generators, Batteries & Solar 6 10-13-2011 01:42 PM
Scale plans for early '70s Tradewinds Madmike 1970-79 Tradewind 2 07-30-2011 11:03 AM
Door sprung AND frame broken Stella Doors & Locks 12 07-06-2011 05:04 PM
'78 Argosy Minuet broken rear stabilizer jack ArgosyMinuet All Argosy Trailers 2 06-20-2011 08:42 AM
'70s Safari bertro Trailer Values 1 01-26-2011 03:05 PM
