Old 10-23-2009, 12:49 PM   #1
1977 Argosy Minuet 6.0 Metre
Sunnyvale , California
Best polishing tool
Hello, I'm looking for the best and cheapest all around tool for polishing the interior aluminum walls. I'd like to use a drill rather than a polisher but also thinking that a drill might weigh to much. What are your opinions on polishing tools? I only plan on polishing the interior walls once and not really ever again, or very rarely. I'm thinking an investment in a good polisher is not really necessary right now.
If a corded drill is the best tool for this, should i be looking for variable speed? or is this not necessary, what about weight and a second handle? What features would you say is best.
I already bought a polishing kit from perfectpolish with a 1/2" adapter.
Joe
joe77 is offline   Reply With Quote
Old 10-23-2009, 12:59 PM   #2
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
Joe
Joe, get a good 1/2in drill, those usually are slow speed anyways. Keep the speed at around 1000rpm or so. Make sure it has a handle near the chuck of the drill. 3/8in drills are usually not power ful enough to deal with a polishing pad under pressure.
Good Luck.
Uwe
www.area63productions.com
Old 10-23-2009, 02:44 PM   #3
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
The alloys used in the inside liners will 'gloss' up but not really take a perfect polish - beware trying to do so since you ~can~ remove enough metal to raise the grain and leave texture where there should be glass smooth gloss.
The exterior panels on the old airstreams can get true mirror brilliance since they are electro-plated with a pure layer of aluminum from the factory.
I hope someones with practical experience will chime in...
Old 10-23-2009, 05:37 PM   #4
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Best and cheap are contradictory. Polishing puts a lot of use on a tool. You might be able to get something through Harbor Freight but consider it a throw away.
Interior aluminum has blems which will often show up when you strip off what ever covering there is on the surface,
Old 10-23-2009, 06:09 PM   #5
vinstream's Avatar
1962 19' Globetrotter
1963 19' Globetrotter
1961 19' Globetrotter
Wheat Ridge , Colorado
FYI.... I have polished two trailers in the inside to a level that you are wanting... I was under the understanding that Airstream uses the same aluminum inside as they did for the outside in the year this trailer was build (1977 Argosy) Yes, the end caps of the Argosy are steel, however the rest is alclad aluminum....
I would also point out that in small areas a polished interior aluminum skin is great, I, however, (I know many will disagree) feel that the entire interior makes you feel like you are looking at a circus mirror....
As for your question a drill works best!
Good Luck
www.VINSTREAM.com
Wheat Ridge, Colorado
WBCCI # 1962
Instagram #Vinstream
vinstream is offline   Reply With Quote
Old 10-23-2009, 06:41 PM   #6
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
The interiors of the Airstreams built in this era were vinyl coated aluminum. I believe the Argosy's were the same. Getting to the aluminum will be a challenge.
Richard
Old 10-23-2009, 09:24 PM   #7
Over59's Avatar
Putnam , Connecticut
Images: 37
You cann't imagine the mess this will make.....
Over59 is offline   Reply With Quote
Old 10-24-2009, 05:21 AM   #8
Baltimore , Maryland
Sage words there... Buy a good tool and buy it once. The vibration of those cheap Harbor Freight tools will cause you a great deal of discomfort in the long run. If you do go with HF you might want to know how to care for it properly
Also how are going to get the vinyl off the walls?
Also vintstream is so right, a little goes a long way on an interior.
Old 10-24-2009, 10:33 AM   #9
Vinyl has been off for a while now. Jasco did the trick. The aluminum under the vinyl is beautiful and looks new as it is. I'm looking to add just a little shine to it.
I have a 1/2" cordless dewalt but by the time the battery runs out the other hasn't charged from the previous polish. I'm looking to buy a corded drill and if i'm going to buy one i'm thinking i'll buy a good one (under $100) Any suggestions? Since the drill wont be working in the usual manufactures ideal settings I'm thinking its going to need to be a reliable drill that will hold up over time with this kind of usage.
Hammer drill? just a regular drill? variable speed? rubber grip? reliable brand?
Old 10-24-2009, 12:13 PM   #10
VIKING's Avatar
Boulder Creek , California
Not a hammer drill, but you will want a side handle. Yes to variable speed and it should have a trigger lock for slow speed settings, so you don't need to manage the speed while you are trying to polish. Nothing much faster than 1000 rpm. Milwuakee is fantastic, as are their prices, maybe a corded Dewalt is in order? Go to Lowes or Home Depot's website and search for 1/2" variable-speed drill. They should have several brands.
Rich the Viking
VIKING is offline   Reply With Quote
Old 11-08-2009, 10:48 AM   #11
goransons's Avatar
1963 22' Safari
1955 26' Cruiser Overlander
Yakima Valley , Washington
Send a message via MSN to goransons
Frank that's the funniest thing I've read on here to date! I had that polisher, or I should say I had 4 of those polishers. I had 4 of those fail polishing the tradewind. Fortunately I had the extended warranty and the harbor freight was about an hour away, and near my parents (so we got to visit once a week or so) and they always swapped them right out (and they always failed the same way) and yes vibrated like hell.
After the 4th trip my wife said "why don't you get a cyclo..." have put 10 times the hours on that and it continues to work amazing.
Scott & Megan
VAC LIBRARIAN
Restoring Wally Byam's 1955 26' European Caravan Trailer!
WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
goransons is offline   Reply With Quote
Old 11-08-2009, 03:46 PM   #12
banjobill
wmarsha's Avatar
2000 30' Limited
battle ground, , Washington
1/4 inch air angle die grinder
best polisher yet, keep it lubed, will last forever, but ya gotta have air...
wmarsha is offline   Reply With Quote
Old 01-10-2010, 10:46 PM   #13
webspinner's Avatar
Menlo Park , California
What is a "cyclo"?
webspinner is offline   Reply With Quote
Old 01-10-2010, 11:16 PM   #14
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Originally Posted by webspinner View Post
What is a "cyclo"?
A dual head, random orbit polisher. It takes out the streaks &/or swirls that are left after removing oxidation to achieve that final "mirror finish" you see on vintage Airstreams. You can find out just about everything you need to know here: Cyclo Polishers and Perfect Polish.
Shari
What's this tool? SafeHarbor Off Topic Forum 71 05-30-2012 08:06 PM
Polishing Tool Comparison- What Works Best? millionairstream Cleaning, Stripping & Polishing 56 04-29-2009 03:34 PM
What's in your TOOL BOX? New2it Classic Motorhomes 36 08-16-2007 07:44 PM
better search tool? Boondocker Forum Admin, News and Member Account Info 11 06-17-2007 06:39 PM
