Old 08-04-2005, 12:33 PM   #1
froggies's Avatar
Lapeer , Michigan
Before Pic of Argosy to be polished...
Here it is! 1977 Argosy Minuet, you can see where PO started to polish, at this point I am going to back up and try compounding again, even though trailer looks as though it has been sanded with various techniques previously. It is covered with lots of swirls and straight sanding marks. I am mostly afraid I might chew thru the mysterious "Alclad" layer.
Any suggestions would be appreciated. I know there is tons of ways to polish, but especially if you have polished your Argosy, please let me know what you found helpful. I realize the aluminum panels might be of different qualities.
My plan is to paint the steel end caps and the roof with silver automotive paint, so if anyone has a product to suggest for that, I would appreciate it. Thanks!
Name:	argosy 1 003 (Small) (3).jpg
ID:	13795   Click image for larger version
Name:	argosy 1 004 (Small).jpg
FROGGIES
froggies is offline   Reply With Quote
Old 08-04-2005, 04:01 PM   #2
Janet H's Avatar
1964 26' Overlander
1964 19' Globetrotter
Eastern , Washington
Images: 90
Try contacting member "3Ms75argosy" He (marc) is also polishing an argosy and is a little further along. He may have some useful advice for you...
Check out this thread to follow his progress.
AirForums Custom Search
Janet H is online now   Reply With Quote
Old 08-04-2005, 04:48 PM   #3
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Rivet
The swirled scratches are from when the aluminum was prepared for painting. It has to be sanded so the paint will adhere to the aluminum. Buffing with a light compound should remove the scratches. There should be no alclad layer on the panels, although I am not 100% sure of this.
As far as painting the end caps, I would suggest waiting until you have the trailer polished as far as you want to go with it, and then find a silver paint that will most closely match the polished aluminum color.
Good luck with it.
Old 08-04-2005, 05:02 PM   #4
jaiman's Avatar
Images: 32
Sanding before clearcoat
"The swirled scratches are from when the aluminum was prepared for painting. It has to be sanded so the paint will adhere to the aluminum."
Not really the case as the Aluminum is coated as a coil. A coil of Aluminum is fed along in a large sheet the width is 3 or 4 feet but can be very long 500 feet. The aluminum coil goes through a 5 or 7 stage pretreat which cleans etchs and pretreats the aluminum to prepare for coating. The clear coat is applied usually with a reverse roller coat application which deposits the required clear coat. The coil continues through an oven which cures the coating. The the coil is wound back up and shipped to whichever end user in this case AS to cut and form the coil into useable sized sheets. Imagine the way a newspaper is printed.
jaiman is offline   Reply With Quote
Old 08-04-2005, 05:08 PM   #5
Well Preserved
1993 21' Sovereign
So much for a brief reply...
Okay, I guess I should have elaborated further, and stated that since Airstream exterior aluminum is originally prepped to be shiny without painting, it needs to be sanded so that paint will stick to it. Argosy aluminum panels were purportedly blemished Airstream panels, and as such they were originally shiny, and had to have that shininess removed, or the whole trailer would look like the galvanized steel end caps. But, I wanted to be brief and to the point...
Old 08-04-2005, 05:09 PM   #6
jaiman's Avatar
Images: 32
Better explanation of Coil Coating
http://www.epa.gov/ttn/chief/ap42/ch04/final/c4s02_2k.pdf#search='coil%20coating'
Old 08-04-2005, 07:32 PM   #7
froggies's Avatar
Lapeer , Michigan
Thanks for the replies...I was wondering whether to paint first, or shine first, you are right, if I wait I can match up the paint better. Though I have been sorta tempted to just paint the whole thing silver...but for some reason which I am not really aware of I think I will try polishing.... I think it has something to do with the whole shiny aluminum airstream fever that I have suffered from so long...if I totally fail and botch this, I COULD repaint it, it is an Argosy after all. Hopefully I won't fail!
"light compound"???? I was thinking of starting with the Nuvite C or F7, think that will be too much grit for what I already have going on here? Which light compound would you advise to start with?
Thanks for the info too on coiling and on Marc's thread!
FROGGIES
Old 08-04-2005, 07:57 PM   #8
Well Preserved
1993 21' Sovereign
I would start light, then progress to a heavier compound if needed. If you use too coarse formula compound, it could swirl even more, not a good thing. I started with this stuff, it seems to be just right. Available at Ace Hardware.
Old 08-04-2005, 08:11 PM   #9
froggies's Avatar
Lapeer , Michigan
Thanks for being so specific! What kind of bonnet would you recommend with that? Do I go in circles or just go straight down with the polisher really slow? How many times should I go over same spot with this product? And what would you do next? Thanks a ton!
FROGGIES
Old 08-05-2005, 04:49 AM   #10
Well Preserved
1993 21' Sovereign
I used a readily-available 7" grinder-type buffer, with the pads that came with it. I made several more passes with it than I needed to, appearantly you use mineral spirits to remove the "black gook" that you will get on the surface. I went back and forth with the buffer, not around in a circle. I am also relatively new to the polishing scene, as I am also a former Argosy owner. Here is a photo I took of the first panel I polished with the product shown in my previous post. I think it came out pretty good:
Old 08-06-2005, 04:03 PM   #11
froggies's Avatar
Lapeer , Michigan
Thank-you Terry!
FROGGIES
Old 08-06-2005, 04:13 PM   #12
greg176's Avatar
Gabriola Island , British Columbia
If you decide to go with Nuvite I would suggest you start with F7 as you have some pretty good scratching there.I found it is better to start with F9 then follow up with F7.The swirl marks these make are very fine.Much less than you have there.
You have to compound till you remove all the cloudiness.The best way to see is to shine a white LED light on it at night.
greg176 is offline   Reply With Quote
Argosy Motorhome Manual & Brochures WANTED Rik Argosy Motorhomes 28 05-22-2017 11:45 AM
Stripping an Argosy CHRIS CANNON Cleaning, Stripping & Polishing 8 05-11-2017 04:42 PM
confused Argosy newbie Dave Cole All Argosy Trailers 23 09-15-2006 09:36 PM
1985 Argosy MH???? ViewRVs Airstream Motorhome Forums 8 03-21-2002 07:39 PM
Argosy Motorhome Owners Manual & Brochures WANTED Rik Airstream Motorhome Forums 5 03-02-2002 11:21 PM
