Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Cleaning, Stripping & Polishing
Old 02-24-2002, 07:28 PM   #1
Andy R
Administrator
Andy R's Avatar
Profile:  1961 16' Bambi
Dallas , Texas
Images: 13
Question Basic exterior cleaning of a neglected trailer
I recently purchased a 1961 Bambi that had been sitting in a field in Idaho for who knows how long? What should I do to clean the exterior of as much residue as possible.
  • Will a coarse scrub brush scratch the surface through the oxidation?
  • What soap/detergent would work the best?
  • I have read about mineral spirits? Would these be effective at this point?
I plan on polishing her when it gets warmer.
AIR # 2 - 1961 Bambi - Jeep Cherokee
Campground Reviews: Submit and review campgrounds around the US
Andy R is offline   Reply With Quote
Old 02-24-2002, 08:48 PM   #2
VintageRV
Vintage Trailer Supply
Commercial Vendor
VintageRV's Avatar
Profile:  1956 22' Caravanner
Montpelier , Vermont
Cleaning your trailer
Your 1961 Airstream most likely does not have a plasticoat on it. That means you can polish it as soon as you are ready to do so without having to strip first. But it also means you have to be careful not to scratch the aluminum while trying to clean it.
Don't use any steel wool or any of those green plastic scrub pads on it. Just get some dishwashing detergent or car wash detergent and wash it using a wool or terry car wash pad or mitt. There's no problem using mineral spirits if it helps to remove some residues.
Steve Hingtgen WBCCI #2669
http://www.vintagetrailersupply.com
800-644-4620
VintageRV is offline   Reply With Quote
Old 02-25-2002, 08:37 PM   #3
JrnymnJay
JrnymnJay's Avatar
Profile:
Images: 11
I second Steve's cautions and mild detergent recommendations.
In my experience, a nylon Libman scrub brush helps with residue without scratching.
However, test scrub a small spot first on yours...the skins can vary.
JrnymnJay is offline   Reply With Quote
What is your Brake Controller of Choice? overlander64 Brakes & Brake Controllers 71 11-29-2008 09:40 AM
Some towing Q & A for newbies femuse Towing, Tow Vehicles & Hitches 3 08-24-2004 09:05 AM
trailer wiring Cruiser Electrical - Systems, Generators, Batteries & Solar 4 09-02-2003 02:43 PM
Getting Close! kamadeca Our Community 48 02-05-2003 09:56 AM
Trailer Listing To "Street Side" montanaandy Axles 4 06-07-2002 01:15 PM
