Old 04-16-2014, 02:23 PM   #1
1966 26' Overlander
San Luis Obispo , California
Bad water spots
I finished the first pass on my polishing early last year. I then made the mistake of leaving the trailer at my daughter's house for a few weeks and didn't realize the sprinklers would hit it. When I saw all the spots on most of the drivers side of the trailer, I didn't worry too much about it although I had seen numerous postings about it. Now I am finally getting back to the polishing and discovered the spots are next to impossible to remove. Compounding with F will work but it takes several attempts and I can only get a small area from each pass. The best results so far has been with an airway wheel using a black bar. Again it is very slow. Last night I did a 4 foot square area and it took about 1 hour. I am considering wet sanding with a 2000 grit paper to remove the spots. Does anyone have any pros or cons about this idea? Thanks in advance for your help.
slofoks is offline   Reply With Quote
Remove water-spots from removALL/Citristrip DustDom Our Community 3 06-21-2012 07:14 PM
Water Spots Archersfin Cleaning, Stripping & Polishing 10 04-30-2010 02:21 PM
Water Spots balestrine Cleaning, Stripping & Polishing 8 03-03-2007 09:29 PM
Water spots...how to remove or prevent? Rog0525 Cleaning, Stripping & Polishing 1 07-11-2004 04:54 AM
Darned water spots! Charcigar Cleaning, Stripping & Polishing 6 07-30-2002 02:29 PM
