Old 01-06-2010, 02:58 AM   #57
1969 21' Globetrotter
Cambridge , Massachusetts
Levon,
What is the size, speed and make of the grinder did you use to get the result shown in the photo you attached to post #53? I have a 4 1/2" grinder that goes 11,000 rpm. Surely that can't be the right thing. Is the set-up something like what I see in the photo in post #49? What about this adapter that is comes as part of the jestco kit? Do I need it? Did you finish with a Cyclo or was it grinder all the way? Any and all help on this will be appreciated.
John
JoePfznik is offline   Reply With Quote
Old 01-06-2010, 05:19 AM   #58
Levon's Avatar
1985 27' Sovereign
1981 22' Excella II
Colbert , Georgia
Images: 168
Greetings John,
The grinder I use is a Variable Speed...Maktia...max rpm is 4000...I use it around 3500 to 4000 rpm....I finish with a cyclo.....the cyclo removes the vertical lines that the grinder buffing wheel puts in the metal. Yes, you need the extender adapter...it comes with the Airstream Kit....along with a smaller one for a reg. drill to get into small places around windows and such. Feel free to ask other questions if I can be of help.
Best Regards,
Levon
Levon is offline   Reply With Quote
Old 05-22-2010, 04:41 AM   #59
Rollerboy's Avatar
1963 30' Sovereign
Gaylord , Michigan
Send a message via Yahoo to Rollerboy
did jestco go out of business ? I went to the website,and it is no longer in use,any ideas?
Rollerboy is offline   Reply With Quote
Old 05-22-2010, 06:17 AM   #60
Levon's Avatar
1985 27' Sovereign
1981 22' Excella II
Colbert , Georgia
Images: 168
Web site being redone
Greetings,
I ordered a couple of weeks ago off the web site. After reading you post, I went to their site and it says they are rebuilding their site and I think all new and old customers have to register again.
Levon
Old 05-22-2010, 06:27 AM   #61
Rollerboy's Avatar
1963 30' Sovereign
Gaylord , Michigan
Cool,thanks for the tip....website must have been down when I tried to get on it,Thanks again !
Axis Products no longer building Airstream axles. Axis Axles 11 05-22-2006 08:56 AM
Sealant Products - Exterior & Interior Cat Leaks - Weatherstrips, Gaskets, Caulks & Sealants 21 02-12-2003 10:00 PM
Thor made AS motorhomes chopperbob General Motorhome Topics 13 01-07-2003 09:31 AM
Polishing Blues. TBKP's Overlander Cleaning, Stripping & Polishing 19 10-12-2002 07:57 AM
