Old 06-03-2010, 08:54 PM   #1
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
Anybody want to try this on their fresh polish job?
Armour All just came out with this new wheel protectant: Armor AllŪ - Product Detail I'm almost finished re-polishing my trailer. I had SO many water spots that wouldn't come off with my cyclo & "S". I had to use "C" with the compounder & even some "F7" and then the cyclo after that. That's a ton of work for a 31 footer. Especially if I have to do it every year!! I think I might try a small spot of this stuff. The Liquid Glass that I used last year didn't do squat. I think you have to wax every month or so to keep the water spots off! I'm really discouraged!
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 06-03-2010, 11:06 PM   #2
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Becky, I assume you are talking about water spots on the trailer and not the tires.
Water spots are caused my minerals in the water. You can use a filter on your water supply to help. There are somewhat expensive filters available from companies that sell products to detail cars and other vehicles. Griot's Garage sells them. You can Google them. I use their paint sealant on the trailer and find it works very well—seems to last a year as they claim, is easy to apply and polish. It took the 2 of us about 3-4 hours to do our 25 last month. Bugs are easier to remove too.
You can get whole house filters at Lowe's or other big box stores and plumb them into your household water supply and that should help.
Gene
Old 06-04-2010, 06:36 AM   #3
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
Out on the Prairie there is always enough dirt in the air the OP could have sand dunes! And when the ground is frozen theres the acid rain from scores of power plants, home heating fuel oil and wood fire fall out from parts unknown there are effects looking just like the honest hard water 'water spots'. We get them here too, occuring on everything polished including windshields, etc. and thats without pollen and organic stuff.
And for your original question - I don't know of any product that sheets off the water instead of letting it bead up.
When the beaded water evaporates it leaves the ring which then gathers more water in the exact same spot - I have holes burned in the clear coat of my F-150 from not paying attention to them - and - the wax that works on the smooth F150 paint does little or nothing on the aluminum.
Old 06-04-2010, 07:16 AM   #4
Becky B.'s Avatar
1964 17' Bambi II
I am talking about putting it on the trailer. Gene, do you have your trailer polished to a mirror finish? That's what I have, & that's the problem. Once the wax wears off (which was in the winter I assume), the water from rain, snow, sleet, etc. is what leaves water spots that adhere to the aluminum. I know, there is no magic thing (I tried Shark Hide & it wasn't satisfactory). I don't mind giving the trailer the once over each year, but an entire polish job every year is brutal!
Becky
1964 Bambi II
1988 Avion 32S
Old 06-04-2010, 07:55 AM   #5
76sovereign's Avatar
1976 31' Sovereign
ozark , Missouri
Good info folks
76sovereign is offline   Reply With Quote
Old 06-04-2010, 10:10 AM   #6
Master of Universe
Gene's Avatar
Mine has the clear coat used on the 2008 models. It won't show the spots like a super shiny aluminum, so I guess I'm lucky. We also get a lot of dust in western Colorado (thanks Utah) so that covers up any spots we may see.
Gene
Old 06-05-2010, 02:24 PM   #7
1976 31' Sovereign
ozark , Missouri
We were wondering about how much it would cost to have several coats of clear shot on the AS would cost. If it lasts 10 years that would put it past our problem...
Shine it to a mirror finish and shoot it with clear? Anyone done this? How much did it cost?
Old 06-06-2010, 06:10 AM   #8
Becky B.'s Avatar
1964 17' Bambi II
ditto to that!
Becky
1964 Bambi II
1988 Avion 32S
Old 06-06-2010, 06:58 AM   #9
Jezibels's Avatar
1966 24' Tradewind
Chicago , Illinois
Water spots, I got em too!
Becky,
My trailer is polished to a mirror, or was last year, now it has tons of water spots, I too Cyclo'd last weekend with "S" and have to say it did nothing to the water spots, I put in an order for Nuvite F7, so Im waiting for that to come.
I guess after that maybe this fall I will check back with you on the wax you found to be the charm!
PS If I find a good solution Ill let you know also!
~Jes
Happy Trails!
Jezibels is offline   Reply With Quote
Old 06-06-2010, 03:22 PM   #10
Becky B.'s Avatar
1964 17' Bambi II
Originally Posted by Jezibels View Post
Becky,
~Jes
Jes,
Try some Nuvite C before you use the F7 all over. I used the F7 where my finish wasn't as smooth from my first time of polishing (I used too harsh of a wheel on my curbside last year). I switched back to the Nuvite system this year, since, when I polished my 1976 I didn't seem to have such a tuff time getting the water spots off. On the streetside of my 1986, I used a softer wheel & the finish didn't hold on to the water as badly. The spots came off of that side with "C" & then you can go directly to "S". I think I might even try a little Rain-X too. I think I'll test some patches on the top of the trailer & see what flies!!
Becky
1964 Bambi II
1988 Avion 32S
Old 06-25-2010, 11:53 PM   #11
howco's Avatar
1970 27' Overlander
Sumner , Washington
Comment people; I hear a number of you saying that your wax is 'gone' in less than a year. I use a pure carnauba wax, (in my opinion) it is one of the hardest and strongest finish waxes available.
The big issue is what you use to wash the finish with. 'IF' you use detergent to wash the finish with, it will strip off almost any wax quickly. Most waxes are petroleum based and detergent dissolves grease and oils and boom, wax gone. Use only a non detergent car-wash, your wax will last for a long time.
Favorite Bumper sticker:
Yes, this is my truck...
No, I won't help you move....
howco is offline   Reply With Quote
Old 06-27-2010, 09:30 AM   #12
1976 31' Sovereign
ozark , Missouri
Did you try the Rain X?
Originally Posted by beckybillrae View Post
Jes,
Did you try the rainX yet? We are wondering how that works...
Old 07-05-2010, 02:50 PM   #13
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Becky's Choice
So Becky, you have lots of polish experience. Aluminum wax choice is like cold remedies; lots of theories out there. What have you found that works for your Airstreams?
David
dbj216 is online now   Reply With Quote
Old 07-05-2010, 04:55 PM   #14
Becky B.'s Avatar
1964 17' Bambi II
Well, I now have a section with Rain-X, a section with Meguires caranuba wax, and a section with a product that truckers use called Master Formula Metal Sealer Gloss. Most of the trailer has Meguires. I'm waiting for rain to see how it wipes off after it's dry. I already have some spots where the Meguires was applied earlier this summer. I just put the other stuff on in the last couple of days. I put the wheel stuff from Armour All on my wheels. I think it's too cloudy for the mirror finished AS. I'll report back, troops!
Becky
1964 Bambi II
1988 Avion 32S
half polish, dull, or matte, polish techniques ? greenrig Cleaning, Stripping & Polishing 9 07-11-2009 10:11 PM
clearcoat over a polish job gloriavoxdei Clearcoat, Exterior Paint & Trim 12 12-05-2008 07:06 PM
1971 Land Yacht Fresh From Polish And Paint mikenlyn 1970 - 1973 Sovereign 10 06-10-2007 06:24 AM
Big Job turned into bigger JOB, need advice. lebolewis Waste Systems, Tanks & Totes 10 11-16-2006 05:28 AM
Needing a good Polish job? zinbar Commercial Listings 1 04-27-2005 08:57 PM
