Old 10-19-2008, 04:22 PM   #1
avon , Colorado
Aluminum type?
I'm planning on customizing a pre 1960 airstream with a new floor plan, window placement and new aluminum skin. I know there could be a lot of questions and comments with this project, but the one question I have now is about the aluminum skin. I would like to use aluminum that would polish up for decades with possible clear coat removals. QUESTION- Is there aluminum better than 2024 T3 alclad that you will not have to worry about wearing through the thin layer of aluminum but will still produce a mirror polish?
scooter66 is offline   Reply With Quote
Old 10-19-2008, 04:37 PM   #2
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
From what I understand It will all Polish up the same and it should be solid Aluminum not coated.... Not sure what you mean by thin layer of aluminum???
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 10-19-2008, 05:16 PM   #3
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Unless you are going to polish it with a belt sander, you should not have to worry about the cladding thickness which I think is about 5% of the thickness. If you had thicker cladding it would weaken the sheet.
Richard
Old 10-19-2008, 05:32 PM   #4
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
You are right the pre 70's airstreams are made with Alclad 2024 t3 that has a fairly thin coat of pure aluminum. It is really rather thick and I have never heard of anybody polishing one so much the rubbed thru it, but I guess you could. The 2024 by itself is rather prone to corrosion and that is why alclad was invented for planes during the WWII. Only pure aluminum would have the same surface characteristics of Alclad but pure aluminum is very soft and not nearly as strong as 2024 T3. The presnce of the alloying elements are what give it the strength plus the precipitation heat treatment. T3 is still ductile enough that you can stretch form it for the end caps. T6 is stronger but poor elongation and would rupture if you tried to form it. There are some alloys with better corrosion resistance than 2024 but none as good at forming the protective oxide film as pure aluminum.
Old 10-19-2008, 05:59 PM   #5
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
The pure aluminum layer is only about 2% for the .032.
Old 10-19-2008, 06:12 PM   #6
2002 25' Safari
Dewey , Arizona
Images: 62
I thought I read that it was 5%, maybe they added both sides to get that number.
Richard
Old 10-19-2008, 07:10 PM   #7
avon , Colorado
Thanks guys. I wonder if todays 2024 T3 has a thinner cladding than the aluminum they used say 30, 40 years ago? Countless vintage trailers have been polished up with no problems, but I have heard of stories of people stripping and orbital sanding the clear coat and then had accidently sanded through the aluminum cladding as well. I'm more concerned with the removal of scratches than the removal of clear coating. With the currant cost of aluminum and modern technology I can see how this cladding has evolved as a much thinner coating. If I go to the expense of a new skin, I would like to know if I used the best possible material. P.S. I'm thinking of replicating a 1948 liner but only longer, so I don't think I'll have to form stretch any parts.
Old 10-19-2008, 08:50 PM   #8
47WeeWind's Avatar
1948 16' Wee Wind
1953 21' Flying Cloud
Denver , Colorado
Images: 20
Here's a 1948 28' "Whirlwind" Liner. Are you stretching your Liner longer than this?
Fred Coldwell, WBCCI #1510, AIR #2675
Denver, Colorado - WBCCI Unit 24
Airstream Life "Old Aluminum"
Airstream Life
"From the Archives"
47WeeWind is offline   Reply With Quote
Type of aluminum? Silvertwinkie General Interior Topics 7 09-19-2007 04:40 AM
Aluminum sheet thickness/type crispyboy Ribs, Skins & Rivets 2 05-29-2007 01:58 PM
Type of aluminum on the bottom front? sequoiacoast Belly Pans & Banana Wraps 7 05-19-2006 09:32 AM
Oshkosh, by gosh and the flying type of aluminum... Zeppelinium On The Road... 5 03-13-2006 08:23 PM
Tow bar receiver type or ball type? Astrodokk Airstream Motorhome Forums 2 06-09-2004 07:20 PM
