Old 08-19-2013, 05:34 PM   #1
Hail on wheels
GeGe's Avatar
1992 25' Excella
Little Elm , Texas
Aluminum brightner
I have recently stripped clear coat from my 92 excella. But there is a lot of oxidation. I saw something at the auto part store called aluminum brightner. Has anyone used this. It is an acid.
Gege
GeGe is offline   Reply With Quote
Old 08-19-2013, 05:54 PM   #2
1972 31' Sovereign
1979 29' Ambassador
west monroe , Louisiana
Not used it on my AS, but sounds like muratic acid.
litlgeezer is offline   Reply With Quote
Old 08-19-2013, 05:56 PM   #3
Baltimore , Maryland
it is used by just about every polishing shop. It eats the oxidation and makes polishing easier. It does not polish your aluminum.
Old 08-19-2013, 06:12 PM   #4
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
"Aluminum brightener" can be hydrofluoric acid. Big truck cleaning, for instance, on wheels and tanks. Not recommended without experimentation first. I've used it for non-A/S purposes, but would be VERY concerned over it getting into seals, under rivets, etc. Etches glass.
Old 08-19-2013, 06:47 PM   #5
Hail on wheels
GeGe's Avatar
1992 25' Excella
Little Elm , Texas
Thanks so much
Gege
Old 08-20-2013, 08:29 AM   #6
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
You can buy AlumaBright online it works well when used in between each step of polishing. You hose it off.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
