Old 07-04-2004, 01:55 AM   #1
JohnG's Avatar
Alumbright or other chemicals
Has anyone ever used the product "Alumbright" on the exterior?
Just adding my 2 worth
John G
___________________________
1975 31ft Sovereign International
........Rear Bath Double Bed Model
Tow Vehicle:1999 GMC Serria SLE Classic 1500 5.7Ltr
System: Jordon 2020 Ultima Brake Controller
Hook-Up: Equalizing Hitch and Sway Bar
JohnG is offline   Reply With Quote
Old 07-04-2004, 02:34 AM   #2
JohnG's Avatar
Also what about cleaning solvents for the skin? Is any one product recommended over others?
John G
Old 07-04-2004, 03:19 AM   #3
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
Cool Well, since you asked
JohnG,
When you say "cleaning solvents", you're indicating something stronger than just a common detergent, for example, like "Joy or Dawn".
There has been numerous threads on the subject of cleaning, polishing, and preserving the results of same~ (Plse take a look at these sites)It's been generally accepted that, you shouldn't use anything on the Airstream's skin which contains a high acidity level, or ammonia products. (If you do use any of these, be sure to risen it off well~!)
This list may includes petrolum products as well.
What you do use depends on your goals and, the actual condition of your unit's surface. Read, & read, then evaluate your needs accordingly`
Again, welcome to the forum..
ciao
53FC
[/B]
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is offline   Reply With Quote
Old 07-04-2004, 12:58 PM   #4
JohnG's Avatar
I was talking about Walburize (Probably misspelled) for cleaning the skin.
I have used Alunbright to polish mag wheels, but was wondering if that would be too harsh for the skin of an Airstream.
John G
Old 07-05-2004, 07:37 AM   #5
1984 29' Sovereign
Savannah , Missouri
Yep, the correct spelling is: Walbernize (no biggie)
I've never used the stuff..
The thing is..Just what are you trying to do? If all you want is to clean your unit and, make it look nice, then just stick with using Walbernize several times a year. If your unit's clearcoat is flaking, oxidized, has really bad scratched, etc..Then the approach is very much different..
Unless you're willing to spend a huge effort of time and money to bring it to a show-room state, I'd say..just clean it..And enjoy it..There's thousand of units out there that look no better or worse than the next.
Hope this helps..
ENJOY your 4th`!
ciao
53FC
WBCCI 5292 AIR 807
NEU #64
New England Unit
Do you use holding tank chemicals? John Waste Systems, Tanks & Totes 15 10-14-2007 02:00 AM
Toilet chemicals gwsullivan Waste Systems, Tanks & Totes 33 02-24-2005 12:28 PM
Save me from my effluence! darin Waste Systems, Tanks & Totes 23 01-09-2004 08:53 AM
WHEW!!! Tank Stench... Jabba Waste Systems, Tanks & Totes 8 06-15-2003 10:53 PM
Storage Advice? Mr. Bliss Our Community 8 04-18-2003 08:15 AM
