Old 08-11-2016, 03:52 PM   #1
nickclifford's Avatar
1972 31' Sovereign
felton , California
alternative to finishing with a shiny polish?
hi all, looking for advice for my 1972 Sovereign.
I love the bright mirrored look on smaller trailers but not convinced about my 31' beast .!
what's my alternative, just remove old clear coat and leave at that, how would that look after and what to use for sealing / finishing off and long term cleaning / maintenance ...?
many thanks in advance
nickclifford is offline   Reply With Quote
Old 08-11-2016, 07:37 PM   #2
sealaker's Avatar
1993 30' Excella
Winter Park , Florida
I have a 1993 30 and I have recently stripped it with Aircraft Stripper. I like you am interested in maintaining the original finish. I am having the trailer re-clear coated. I am only stripping above the belt line as the bottom portion is still in tact. Best of luck with your project.
sealaker is offline   Reply With Quote
Old 08-11-2016, 07:44 PM   #3
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
I am working on my 1988 Excella now. Stripping clear coat above the belt line. I have oxidation on the end caps and the top 1.5 feet or so on the walls. I just tried the Aluminum Polish from Outdoors Mart Airstream today and it does about what I want. Takes the white oxidation off the aluminum and leaves it about the original color. No grit in it. Seems to be a chemical cleaner. It is going to take a little blending to make it match the unoxidized areas but it goes quickly and does the job I wanted. My plan is to either clear coat with the little Aerosol cans of clear coater or to buy a quart of Nyacrilic and spray it. I am using Citri strip and stripping one small area at a time. It works well on cool damp mornings. Not so much during the day. It has to sit 15 min or so without drying out to be effective. But the water wash off makes it fairly easy.
Old 08-11-2016, 10:52 PM   #4
1972 31' Sovereign
felton , California
Good advice. Thanks
Old 08-12-2016, 12:31 PM   #5
BigButtUgly's Avatar
1958 22' Caravanner
not shared , Nebraska
My 1958 Caravanner has the aluminum electroplate .005" pure aluminum so it would polish to a mirror finish. Mine was never clear coated. The skin on 1982 and older models have Alcad sheets with plating and may polish to luster. Why they clear coated I have no idea. Maybe they oxidized faster than pre 1960 models. So if you strip and polish you might want to re clear coat or your aluminum might oxidize quicker than mine. I don't think the older mirror polished Airstreams get clear coated. Mine not polished - has "patina" My theory: Never polish a turd !!!
BigButtUgly is offline   Reply With Quote
Old 08-12-2016, 01:02 PM   #6
1996 25' Excella
Tillsonburg , Ontario
I'm actually considering painting my '96. The clear coat is gone and there is enough variation in spots corroded in awkward places that polishing is going to be expensive.
Some years ago AS factory painted some 98-99 vintage when the aluminum got into serious trouble. One of our members had his factory coated under warranty and it still looks better than any of the '90s units in our club. One of our members has an original '96 AS Motorhome which has the nose cone painted. I did not pick it out until it was mentioned. The color is a bit blue but the overall look is quite good and there is no messing with tonal variations. It just isn't original!!!!
JCW
JCWDCW is offline   Reply With Quote
Old 08-12-2016, 09:02 PM   #7
DavidsonOverlander's Avatar
1964 26' Overlander
Milton , ON
JCW
We saw this painted Airstream a few years ago. I could tell that it had been painted, but it looked good.
Grant Davidson
Milton, ON
1946 Spartan Manor
1954 Va-Ka-Shun-Ette
1964 Overlander
1965 Avion C-10 Truck Camper
1974 Sovereign
2005 F-350 SRW 4x4 crew cab long box
TAC ON-5
DavidsonOverlander is offline   Reply With Quote
Old 08-14-2016, 09:53 AM   #8
1996 25' Excella
Yep
That's the colour. This one looks to be about the vintage that the AS factory did warranty work by painting the aluminum.
JCW
Old 08-21-2016, 07:03 PM   #9
1978 31' Excella 500
SOUTH ANHERST , Ohio
What is a good striper that is good to use on a argosy that is safe.
thanks
Gosman is offline   Reply With Quote
New hardwood floors- finishing touches kween Floor Finishes 11 03-25-2013 08:31 PM
Polish: Shiny VS. Not so shiny adonh Cleaning, Stripping & Polishing 4 01-02-2012 07:53 AM
Finishing the removal of the furnace mouth012006 Furnaces, Heaters, Fireplaces & Air Conditioning 3 01-19-2009 08:32 PM
Finishing in the Bathroom Stone Ridge General Interior Topics 6 07-25-2008 10:34 AM
Ideas on finishing damaged ceiling tinsltootsie Upholstery, Blinds, Walls & Interior Finishes 3 08-17-2005 07:28 PM
