Old 06-28-2006, 05:17 PM   #1
Airstream Dent removal & Polishing
Hi!
I'm looking for a company to remove a softball shaped dent on the back corner of my airstream (the entire panel I guess) as well as have the entire unit polished. Any referrals or recommendations for anyone that specializes with Airstreams in the Northwest area would be very much appreciated.
Thanks.
Shimmer is offline   Reply With Quote
Old 06-28-2006, 05:50 PM   #2
HHP
HHP's Avatar
Yucca Valley , California
Where are you located?
HHP is offline   Reply With Quote
Old 06-29-2006, 04:25 PM   #3
Hi, I'm located near Vancouver, BC, Canada. However I bring the Airstream to the US several times a year.
Old 06-29-2006, 04:35 PM   #4
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Check the year
Makes a big difference when it comes to replacement panels. Later aluminum won't match. If its an early model....see the parts for sale now. There are some early panels for sale. Some specialized repair facilities have the older panels too.....but getting rare. If you run into problems let me know. I have some early stuff located. Good luck.
Old 06-29-2006, 05:06 PM   #5
Excella CM's Avatar
1978 31' Excella 500
Venice , California
If the dent is just a dent without any creases, a good metal worker can probably fix the original.
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 12-26-2011, 02:09 PM   #6
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
for what is worth
Old 01-01-2012, 11:36 AM   #7
Spencer , New York
sorry this is second hand advice, i have two dents that i wanted fixed on my avion. a man came and looked at it and told me if you buff it long enough to heat the aluminum. you could very easily pop the dents out with a screw dent puller then cover the hole(which the screw puller will leave). he said it would be very simple? i don't know if this helps. my husband is a millwright. and claims this will work. i'll see in the spring!
jennygt is offline   Reply With Quote
Polishing...approx cost? Drew Cleaning, Stripping & Polishing 10 03-31-2014 10:37 PM
Cost to restore a gutted Airstream Draco General Interior Topics 28 02-18-2013 11:17 PM
Sale of Airstream excelladep Our Community 9 03-12-2005 03:32 PM
Airstream Related List Servers Andy R Link Archive 0 02-22-2002 02:05 PM
AirstreamTrailers.com - Airstream Link Library Andy R Link Archive 0 02-22-2002 01:31 PM
