Old 07-29-2004, 06:50 AM   #1
froggies's Avatar
Lapeer , Michigan
After I wash it, now what do I do....
Going to wash my new old 1983 310 Airstream moho....after that what do I do...can you wax them....I have tried some Walbernize or something before on another trailer and was super unhappy with it as it just seemed to look cloudier after...I don't have time to polish right now...thanks.
froggies is offline   Reply With Quote
Old 07-29-2004, 08:19 AM   #2
Froggies.
Anything you do to the exterior, at this point, is a waste of time, and money,
unless your coach has been replasticoated.
Plasticoat lasts 3-4 years. Therefore, yours has been long ago, aged out.
If you use anything on the exterior, all you will manage to do is take more of the old finish off, and protecting the coach from bugs.
Other than that, it's done.
Old 07-29-2004, 08:23 AM   #3
froggies's Avatar
Lapeer , Michigan
thank-you very much!
Old 07-29-2004, 10:56 AM   #4
JohnG's Avatar
Froggies.
Plasticoat last only 3-4 years? Wow I thought it was suppose to last much longer. Does that mean that you should have it stripped and recoated every 3 years or so?
I plan on coating my AS once I complete the polish work on it. I hope I don't have to redo it every 3 years.................
Just adding my 2 worth
John G
___________________________
1975 31ft Sovereign International
........Rear Bath Double Bed Model
Tow Vehicle:1999 GMC Serria SLE Classic 1500 5.7Ltr
System: Jordon 2020 Ultima Brake Controller
Hook-Up: Equalizing Hitch and Sway Bar
JohnG is offline   Reply With Quote
Old 07-29-2004, 01:36 PM   #5
John G.
Average age of the plasticoat is 3 to 4 years. The hotter the climate, the shorter the life.
Then it becomes aged out and starts peeling.
Or, you can paint them metallic silver like we do, wax it once a year, and it's good for about 20 years.
Costs more intially, but is very cost effective, over it's life.
Old 07-29-2004, 01:44 PM   #6
JohnG's Avatar
John G.
Is there anywhere that I can view photos of the finish you're talking about?
Is it possible to paint an AS with a clear automotive finish and then wax that once a year and still have any life expectancy?
I really like the high shine finish and would prefer that over painting with metalic silver. Would that even shine as much as a factory finish does?
John G
Old 07-29-2004, 04:35 PM   #7
John G.
Plasticoat "IS NOT" an automotive finish.
There are many types of clear automotive paints, "BUT" none of them will stick to raw aluminum. Try it if you like. In short order it will peel off like cellophane. Then you will have a problem you don't need.
The only paint that will stick or bind to aluminum, is a primer. Obviously that's out if you want to see the metal.
Bottom line is, it's Plasticoat" or nothing.
Not what you want to hear, but that's the way it is.
If you want to see a metallic finish that we do, go to our web site, inlandrv.com
Old 07-29-2004, 06:34 PM   #8
cosmotini's Avatar
1963 24' Tradewind
Highland , Illinois
Images: 83
Is there any harm done to the trailer if the Plasicoat fails? Or is it just cosmetic that it may look ugly when it fails.
Dennis
cosmotini is offline   Reply With Quote
Old 07-29-2004, 06:43 PM   #9
When the plasticoat on an Airstream fails, it peels off, starting at the roof area, because the roof obviously gets the hottest from the sun.
Normally, all that happens then to the aluminum, is that it discolors and turns slight shades of brown, blue and black.
All that hurts is it's appearance.
However, if the trailer, in that condition is close to salt water, then serious trouble can start. 50 to 75 miles from salt water, is considered too close.
The salt is an acid to the aluminum, and can cause serious oxidation and electrolysis, as well as causing steel to rust, especially within the underbelly.
Trailers parked near salt water for years usually suffer very severe damage to the frame and outriggers.
Old 07-29-2004, 08:31 PM   #10
froggies's Avatar
Lapeer , Michigan
Andy,
I looked on your site and I saw the polishing guru....where exactly is the metallic finish you mentioned...thanks.
Old 07-29-2004, 10:52 PM   #11
JohnG's Avatar
Originally Posted by froggies
Andy,
I think this is the photo Andy was talking about. It is the first one at the top of the page. here is the link http://www.inlandrv.com/airstream-pics01/crunch101.htm
John G
Old 07-30-2004, 09:52 AM   #12
Froggies.
Many people ask the same question.
The point?
They see the metallic silver paint job, but still think it's the original aluminum finish.
That paint job, is on the first page in the "slide show" and if you go to the Airstream key chains on the left of the first page, click on "projects" and you will see an enlarged view of the same trailer.
Old 07-30-2004, 10:54 AM   #13
JohnG's Avatar
Andy,
Does Inland RV sell the plasticoat in a Gallon or 5 gallon size so I would be able to apply it to my AS myself? And does it need to be baked on as or like a powder coat?
John G
Old 07-30-2004, 10:56 AM   #14
John.
It's a 2 part mix that is sprayed on.
Comes in gallon kits.
Acid wash gmc70 Cleaning, Stripping & Polishing 5 08-21-2005 04:06 PM
Wash n' air dry Diana Langley Cleaning, Stripping & Polishing 0 07-04-2004 09:36 PM
Wash 'n Watch... canny_banjo_man Off Topic Forum 2 06-30-2004 02:17 AM
Where to wash, when on-the-road? Kistler On The Road... 35 03-29-2004 01:48 PM
coin car wash wax david h Our Community 1 01-13-2003 08:27 AM
