Old 10-26-2008, 10:47 AM   #15
Larry in MO's Avatar
1957 22' Flying Cloud
Lone Jack , Missouri
Images: 27
Originally Posted by ts8501 View Post
So how long might it take for water leakage to appear after an acid wash?
My guess is that there will be no leakage unless there is already a problem. Acid "eats" until the ph level reaches 7 or neutralizes itself. Large amounts of water speed this up. It won't keep "eating" forever.
If you are unsure, find yourself a couple pieces of scrap aluminum and rivet them together w/ Vulkem as a sealant. Spray the acid wash on the aluminum and see what happens. I don't think anything will happen to the sealant, rivet, or aluminum. After that, soak the piece in the wash for a couple of days. If it doesn't eat the rivet or the Vulkem you will be satisfied, I think.
Larry
"Turleen", the '57 Flying Cloud
Lone Jack, MO
Pop.528
"You better learn it fast; you better learn it young"-John Fogerty
Larry in MO is offline   Reply With Quote
Old 10-27-2008, 07:48 AM   #16
ts8501's Avatar
1990 34' Excella
1964 22' Safari
Savage , Minnesota
Update on Acid Process Used
This morning I spoke to the person/company that stripped and polished this '64. He used what he called a lighter duty aluminum "brightner". He said he also uses on some applications of truck an 'acid wash", but this is not what he used on this Airstream, and that he felt the acid wash is too heavy duty. The unit was then fuly washed down with rinse water. He then went on to say that he used a two step polishing compound process (I assume like Nuvite, different grades).
I do not know the exact brand, but I believe is was close to this:
Aluminum Brightener, Regular Strength - Removes oxidation from any aluminum surface. Cleans as it works. Dilute up to 50 to 1 with water for light oxidation; use in a more concentrated form for heavier oxidation. ALWAYS WORK FROM BOTTOM TO TOP. Light blue liquid. Hydrofluoric acid based. Caution: Do not apply to glass surfaces. 55 gal.
So what is the opinion of an "aluminum brightner" verus an "acid wash"? Again, I see no evidence of any leakage or water damage, over one year later. I want to pull the trigger on this AS today, but I have hesitated, after reading all the horror stories of "acid wash", and leaking rivets, and junk AS as a result.
Thanks!
-Tim
ts8501 is offline   Reply With Quote
Old 10-27-2008, 08:07 AM   #17
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
Tim - just buy the unit! : )
Better?
Seriously, if the acid "damage" would have been evident by now.... if none, just smile!
I'm sure it looks nice... pics after the purchase?
Marc
Old 10-27-2008, 09:09 AM   #18
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Not to Worry
Go get that Airstream RIGHT NOW. It's snowing in Fargo this AM. You have to get that baby home and tucked in. Your worries should be completely put aside after getting the "brightener" history from the truck maintenance fella. Now you can concentrate on axels, tires, Corning windows,frame separation, floor rot, leaking panels, aluminum wiring, Univolts, and all the other joys of a Vintage. You WILL love it and the good folks you have in that group.
Old 10-27-2008, 04:38 PM   #19
ts8501's Avatar
1990 34' Excella
1964 22' Safari
Savage , Minnesota
I told the PO "Yes", and the check is on its way. I will get some pics posted within the week! Thanks to all for their input!
-Tim
Old 10-27-2008, 05:47 PM   #20
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Way to go!!!
I'm proud of your decision. Looking foreward to the pics.
Old 10-29-2008, 12:33 PM   #21
-Tim
1. Any acid bath for any Airstream or Argosy product, is not necessary in order to properly paint them a color, or to polish them.
2. The risk invovled using acid is not worth the ultimate costs of corrcting problems than can arise from the acid.
3. Painters offer advice and opinions, owners offer advice and opinions, and I offer 42 years of experience, backed with facts.
DON'T USE ACID, PERIOD
Old 10-29-2008, 12:52 PM   #22
ts8501's Avatar
1990 34' Excella
1964 22' Safari
Savage , Minnesota
I already pulled the trigger, and in this case, I am feeling good about it. 1 1/2 yers with no sign of an issue makes me believe all will be well on this unti. Yesterday Andy quoted new axel/brakes/shocks/wheels for me. This work will most likely wait for spring.
-Tim
Old 10-29-2008, 01:19 PM   #23
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
Whoops, thought this was a thread about growing up in the sixties.
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 11-03-2008, 01:51 PM   #24
ts8501's Avatar
1990 34' Excella
1964 22' Safari
Savage , Minnesota
Finally some pictures to share
It has taken me time to get around to posting some pictures. I am inspired by the many refurbish threads I am seeing, and even the blogs. I might go there as well, but in advance of that, here are some pictures that I took. Much work to be done!
ID:	70820   Click image for larger version
ID:	70822   Click image for larger version
Old 11-03-2008, 02:28 PM   #25
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Looks nice...congratulations on jumping in!
Shari
Old 11-03-2008, 03:29 PM   #26
1975 Argosy 26
1963 24' Tradewind
Where did you go that has so many Airstreams lying around?
Old 11-03-2008, 04:23 PM   #27
ts8501's Avatar
1990 34' Excella
1964 22' Safari
Savage , Minnesota
It is a winter storage location that is popular with Airstream owners at the Airstream Park in Clear Lake, MN.
The Long, Long, Trailer by Clinton Twiss overlander64 Off Topic Forum 274 12-02-2013 07:57 AM
The LONG LONG TRAILER Movie Trivia rseagle Off Topic Forum 26 06-23-2008 03:43 PM
Our long, long trailer (AKA 19' CCD) crazylev 1997 - 2004 Bambi 60 05-11-2006 12:53 AM
Long, Long, Trialer on DVD/Netflix Kintscher Airstream "In the News" 2 05-01-2006 09:12 PM
There's a long, long trailer in front of my house - 2004 Classic Porky Pig 2001 - 2005 Classic 35 01-28-2004 05:28 PM
