Old 02-27-2014, 11:00 AM   #1
Silver streak
Vancouver , Washington
Acid in Portland OR area
Anyone have a source for the acid to clean and brighten aluminum in the Portland Metro Area? Oregon that is!
Transoceanic is offline   Reply With Quote
Old 02-27-2014, 11:39 AM   #2
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Any good paint shop. Ask for brightener.
Old 02-27-2014, 12:26 PM   #3
1977 Argosy 24
Milltown , Wisconsin
Don't use it on riveted aluminum. The acid gets in between the sheets and around the rivets and doesn't wash out. I have read other threads here warning about this.
ventport is offline   Reply With Quote
Old 02-27-2014, 01:09 PM   #4
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Well then.....EVERY...EVERY! riveted aircraft in the world is about to fall apart. The required standard to paint a riveted airplane is to prep it with acid (brightener) before paint. All trucks with aluminum bodies are acid washed. Airstreams too.....
Old 02-27-2014, 01:37 PM   #5
truckasaurus's Avatar
1960 33' Custom
Saskatoon , Saskatchewan
Yup, the acid scare mongering is just that. Once it's done it's job it's not acid anymore. As I understand it….
truckasaurus is offline   Reply With Quote
Old 02-27-2014, 02:48 PM   #6
Baltimore , Maryland
I thought this was going to be a warning about the brown acid…
I use it in my shop. After rinsing well, I mix up a solution of baking soda and water and apply that. I then rinse that really well. If I don't, it leaves white spots all over the place.
Old 02-27-2014, 02:59 PM   #7
JFScheck's Avatar
Rockville , Maryland
Images: 33
Brown Acid - you mean "Alodyne" as in how you prep an Aluminum aircrafts skin so the primer will adhere before polypain?
John "JFScheck" Scheck
2015 Roadtrek CS Adventurous XL
2015 Mercedes Sprinter 3500 XL Chassis with Mercedes BlueTec V6 Diesel
**I Love U.S.A.**
JFScheck is offline   Reply With Quote
Old 02-27-2014, 03:18 PM   #8
TinShack's Avatar
2005 28' Safari S/O
Paradise , California
More like Woodstock
Steve
"THE OLDER I GET, THE BETTER I WAS"
TinShack is offline   Reply With Quote
Old 02-27-2014, 03:40 PM   #9
Silver streak
Thanks for the response. I'll check with a paint store I know .
Old 02-27-2014, 03:54 PM   #10
1977 Argosy 24
I was just repeating what I had read here. I assumed it was good information. I just didn't want anyone to wreck their trailer. If the info is wrong I am sorry I repeated it.
Old 02-27-2014, 03:55 PM   #11
check with truck supply stores. The place where truckers go. You will find it there.
OR
there is Amazon
Old 02-27-2014, 07:36 PM   #12
Cyquest's Avatar
1969 23' Safari
Blenheim , Ontario
I would check with aircraft spruce. But that's just me.
Cyquest is offline   Reply With Quote
Old 02-27-2014, 07:55 PM   #13
Silver streak
I checked with three local paint stores and no one had it. There is a freightliner down by Delta park I will give them a try. If not (Thanks for the Amazon link ) I'll order it online.
Old 02-28-2014, 04:16 AM   #14
oh yeah, Freightliner. They have all kinds of polishing supplies.
Polish job about done! Sodbust General Repair Forum 11 03-11-2012 11:29 AM
Issues with an acid bath.. Fixing the blimishes caused? dtodom Cleaning, Stripping & Polishing 2 10-26-2011 02:30 PM
I do aluminum polishing for a living acidstorm General Repair Forum 4 09-22-2011 10:01 PM
AGM equivalent? UAPachyderm Batteries, Univolts, Converters & Inverters 22 01-31-2011 08:44 PM
