Old 01-08-2013, 09:05 AM   #43
2013 27' FB Classic
Woodstock , Georgia
Replacement of clear coat
I am buying a trailer that needs new clear coat on the top corners. What is the procedure to do that. Can you do sectoins or the whole trailer? Do you strip, then buff, then reapply some special lacquer? Is it best to have a body shop do it?
jsaucer is offline   Reply With Quote
Old 01-08-2013, 12:15 PM   #44
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
Some of us think clear coat is a mistake. You might be able to apply it to one panel at a time, but never to a partial panel. What year is this Airstream you intend to buy? Z
Old 01-09-2013, 06:59 AM   #45
2013 27' FB Classic
Woodstock , Georgia
It's a 1996 Excella.
Old 01-09-2013, 07:09 AM   #46
1975 31' Sovereign
1977 23' Safari
Oops, clear coat is definitely an option on the newer Airstreams (I am guilty of always thinking in the 70s, or earlier). The newer alloys don't polish as well as the older stuff.
Zep
Old 01-09-2013, 09:26 AM   #47
Shehanigans's Avatar
1994 34' Limited
Sulphur Springs , Texas
Zep
What do you suggest for the new ones?
Shehanigans is offline   Reply With Quote
Old 01-09-2013, 10:32 AM   #48
1975 31' Sovereign
1977 23' Safari
I'd ask Airstream. Clear coat is a lacquer, so any good auto paint shop can apply it. I think I've seen a post where it discussed the difference between various kinds of finishes that can be used for clear coating. But I am no expert, obviously.
The issue for older Airstreams is whether to polish or clear coat. As far as I know, since newer Airstreams are more difficult to polish, you don't have that option.
Zep
Old 01-09-2013, 08:31 PM   #49
Skatiero's Avatar
1986 32' Excella
Canton , Georgia
You can also strip off the old failing clear coat, clean well, polish, and wax, relaxing at least a couple times a year. Clear coat is much more expensive, and will eventually have to be redone anyway. Note that is is different from automotive clear coat meant to go over paint.
Skatiero is offline   Reply With Quote
Old 10-02-2013, 12:27 AM   #50
Scottsdale` , Arizona
M & M Truck Polishing
Just a bump for this thread. We took our 1974 31' Sovereign to M & M Truck Polishing and they did an amazing job. More photos of the before, during and after on our blog airstreamy | Our journey with a 31' 1974 Airstream Sovereign. Tell them Matt and Jenny Hibbard sent you!
I would highly recommend these guys. Ask for Antonio at 520-483-5571. The phone # on the side of the building is no longer used. Address is 518 S. Sunshine Blvd. Eloy, AZ 85131.
airstreamy is offline   Reply With Quote
Old 10-08-2013, 08:19 PM   #51
Roadrunner's Avatar
1978 29' Ambassador
1974 25' Tradewind
1974 27' Overlander
Indiana , Pennsylvania
Do Your Homework...
I cringe when I think about truck polishers touching an Airstream. Granted, some are good and will respect your Airstream. But BEWARE... I had taken a beautiful "60" Overlander to a "recommended" truck polisher and could have cried when I went to pick it up. I'm not sure what was done but it was a mess. Make sure your polisher has experience polishing Alclad aluminum. These vintage beauties aren't semi-tankers. Make sure you have serious discussions with your polisher before jeopardizing the skin on your trailer. Just my two cents...
Indiana, PA
TAC PA-5
WBCCI 4871
Roadrunner is offline   Reply With Quote
Our Great Labor Rate- semper fi Commercial Listings 1 04-27-2010 06:01 AM
Polished New Airstream spinyman Off Topic Forum 10 05-25-2006 06:01 PM
Did Airstream ever offer a sealant on their roof as an option? 72Blazerod Roof 7 05-23-2006 06:05 AM
Someone just bid themselves into a bargain 87MH Classic Motorhomes 5 08-24-2005 05:27 AM
