Old 08-21-2010, 05:30 PM   #1
an10awiz's Avatar
1965 17' Caravel
Palo Alto , California
64 Caravel
I am about to undertake the task of polishing my 64 Caravel after 10 years of ownership. The reason for the delay? Well it has a few little dents that I keep looking at. One is where the previous owner came into a parking site at night and failed to see some overhanging branches. The result was a very slight crease on the right dome. I used some glue-on dent pullers and managed to remove shock effect. The second is when the suicide door flew open at 55 MPH and slammed the side. It happened again before I realized the previous owner cracked the door frame and the door would not close securely. I have fixed the door and again used glue-on dent pullers to some what restore the dents. The creases remain. I have just accepted the fact that it is the history of my Caravel.
Now for the questions: I plan on two more 5 day trips before October. Should I compound with F7 the whole Caravel, stopping where I finished before the next outing and continue when I return. OR: Start at the back compound F7, cyclo S small panels at a time?
an10awiz is offline   Reply With Quote
Old 08-21-2010, 06:24 PM   #2
Roadrunner's Avatar
1978 29' Ambassador
1974 25' Tradewind
1974 27' Overlander
Indiana , Pennsylvania
We just started polishing our "78" Ambassador. We tried F7 and G6 without much success. We then tried Nuvite C and it immediately took off the oxidation and brought it up to a shine. Normal progress would be to cyclo with S. It will be some time until we can get back on her with the S. Yes we have some dings and creases too...just beauty marks! And then seem to be accentuated after being polished. Whatever way you plan to polish, you'll be pleasantly surprised at the results. Good luck!
TAC PA-5
WBCCI 4871
Roadrunner is offline   Reply With Quote
caravel
Hello - new here and new '66 Caravel kamilaji Member Introductions 4 10-10-2009 01:02 PM
Our new '66 Caravel in the UK eddiecross 1966-68 Caravel 8 09-10-2009 10:12 PM
Help with a 66 Caravel RLStephens Sinks, Showers & Toilets 13 03-22-2009 08:14 AM
Help with new '69 Caravel? KHarris 1969-1971 Caravel 14 09-25-2006 04:28 PM
Did you see the '67 Caravel.... C Johnson 1966-68 Caravel 12 05-27-2005 12:12 PM
