Old 04-08-2014, 02:51 PM   #43
Trestrey's Avatar
1961 16' Bambi
Rowley , Massachusetts
Originally Posted by Aage View Post
Jim,
None of your image "attachments" worked; the links all give dead ends.
You need to use the other method you were using at first, or use an "image warehouse" site to post a link.
Thank you, Sir! I spent a while on that original reply, then when I tried to publish it, it disappeared, so I just re-wrote the whole thing. Anyway, you can see my revisionist's version of the original post, with the intended pictures, just before this one. Sorry for any confusion. You can delete the reply with all the failed links, if you are able to. Thanks for the heads up!
Trestrey is offline   Reply With Quote
Old 04-08-2014, 09:58 PM   #44
Ottawa , ON
You're quite welcome, and I removed the post as you suggested.
Old 05-10-2014, 05:58 AM   #45
cdmagda's Avatar
Images: 51
I used wet sanding on heavily oxidized/ scratched areas on the 55 FC. Depending on what grit they used, you will need to gradually increase the grit to remove the previous finish. I found that I needed to go as high as 1500 grit to be able to polish it out with an aggressive compounded grease type grey bar (maybe F9 would work, I don't know). This requires a lot of patients, loads of effort, and hundreds of hours for a whole trailer, even a trailer your size. At this point in the trailer restoration, I would concentrate on the structure and interior sheet replacement. The finish is the last thing to do on these projects. Pick at it as you find time, but there are tons of things to do prior to the ext. finish.
cdmagda is offline   Reply With Quote
Old 05-10-2014, 09:04 AM   #46
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
I wouldn't begin to wet sand an Airstream without a air powered water feeding dual action sander.
3M makes soft sanding disks ranging from 1,000 grit to 3,000 grit that work very well. They aren't cheap at about $5 a pop, but they last quite a long time when compared to regular paper.
Old 05-10-2014, 07:09 PM   #47
cdmagda's Avatar
Images: 51
Concerning the front and back windows with the rivets galore, you could put the fifties style aluminum drip cap over the two windows to cover the rivets.
Old 05-12-2014, 08:44 AM   #48
Trestrey's Avatar
1961 16' Bambi
Thanks for all the feedback.
I am in the process of replacing a number of panels, as we speak. In the end, only the end caps and the top center roof panel will remain original. It has been going very well.
I have also restored all the windows, and am prepping them for new glass. I am going to use scratch Resistant Lexan for all of them. I have brazed two of the broken windows back together, and have two more to do.
I am replacing the door's panels as well. I am going to get rid of the existing window on the door, and just have it be blank. I might put a cool peep hole on the door. We will see.
I hope to have the entire exterior sealed up (new panels, windows and door) completed by June 15, 2014. I will post some pics when it is done.
Thanks for the advice on sanding. I am interested in the 3M sanding wheels. Sounds like a good time-saver item.
Cheers,
Is my door doomed? Kevrey50 Ribs, Skins & Rivets 5 08-24-2012 09:14 PM
PO sanded with 300 grit paper lizpickering Cleaning, Stripping & Polishing 0 08-05-2012 03:44 PM
Polishing what has been Sanded? NomadKitchen Cleaning, Stripping & Polishing 27 10-29-2009 07:26 PM
Complete door lock and assembly for a 72,am I doomed? Pkerr Exterior Storage Compartments & Access Doors 10 10-25-2009 06:05 PM
Sanded roof? Alumanutz Cleaning, Stripping & Polishing 4 09-17-2008 11:02 AM
