Old 04-12-2010, 06:46 AM   #1
vitag's Avatar
1958 26' Overlander
Webster Groves , Missouri
58 overlander intl. just got home !
what's the first step in cleaning and polishing exterior? Do I wash with soap and water first then on to "gravel in a bottle" , then Nuvite? Thanks
vitag is offline   Reply With Quote
Old 04-12-2010, 08:45 AM   #2
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
Well, since you don't know about any leaks since its a new to you trailer, I would not suggest a high powered car wash or power washer. Wash it at home with a long handled brush made specially for RV's where the water goes through the handle. Use a mild detergent along with the brush. What kind of interior water damage do you see on the cabinets and floor? The windows and vents will be your biggest leaking culprits so look below them. Seams can and will leak too, so look everywhere for any evidence of prior leaking. According to the VAP Panel Pros, "they all leak."
Good luck and post some photos when you can.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
New 2009 25 Ft Intl SS rgentry Trailer Values 3 06-07-2009 08:27 PM
1958 Overlander International Coming Home juel 1954 - 1959 Overlander 7 06-27-2006 06:23 PM
Overlander not home, but making progress blackboat 1970 Overlander 12 06-26-2006 08:00 AM
1958 Overlander is home juel 1954 - 1959 Overlander 21 04-04-2006 06:46 PM
New Int'l Floorplan RoadKingMoe 2002 - 2005 International 41 03-02-2003 05:10 PM
