Old 11-26-2008, 07:03 AM   #29
LHall's Avatar
1962 28' Ambassador
Phoenix , Arizona
Originally Posted by goransons View Post
can you take me a close up shot of those hubcaps sometime so I know what I'm looking for? love the look
I would be happy to do that. It just so happens that I have an extra set that were originally on the trailer when we purchased it. Two of them are in good shape, but the other two really could use a re-chroming. I ended up finding another pristine set on E bay for around 25 bucks so I just decided to keep the old ones for spares.
I will take a close up photo and post it here.
Louis & Sergio
Air #22673
WBCCI# 2731
Four Corners Unit
LHall is offline   Reply With Quote
Old 11-26-2008, 07:09 AM   #30
LHall's Avatar
1962 28' Ambassador
Phoenix , Arizona
Originally Posted by azflycaster View Post
Mr InsideOut did a demo using that technique this year at the RMVAC, it was very impressive. He went back over the area with the cyclo and produced a mirror finish.
We learned of this process from attending the Restoration Rally last April. Levon demonstrated the method and has used it extensively on a number of trailers that he has restored. We are pleased with the outcome, but there are a few precautions especially working around drip caps, lights, corners of hatches and doors. It is easy to catch something and rip it off and you really have to be careful when you are working on ladders as the buffer really "bites" into the oxidation which can cause you to lose balance if you are not careful.
Louis & Sergio
Air #22673
WBCCI# 2731
Four Corners Unit
Old 11-26-2008, 07:40 AM   #31
azfiredog300's Avatar
Surprise , Arizona
Looking really good Louis, I was contemplating using that method since seeing it at the resto rally. I wish I could see it at Picacho but my Department is not allowing any vacations due to the economic slowdown. I will be thinking of you guys and would like to extend my holiday greetings to all.
Jerry C.
"Travelstar Galactica"
WBCCI #13317
AIR #25664
Member of the Four Corners Unit
The only true failure is the failure to try.
azfiredog300 is offline   Reply With Quote
Old 11-26-2008, 11:19 AM   #32
LHall's Avatar
1962 28' Ambassador
Phoenix , Arizona
Originally Posted by dogpound View Post
Louis;
OK, I'll bite. What do you use with your buffer. The top of mine is peeling and we don't want to spend the $4,500 to do another clear coat. I tried Turtle Wax and the aluminum just turns black and it is hell getting it to get a shine.
Your trailer looks very good. Hope to see you and Sergio in Cottonwood in Feb.
_
Bob and Lou
Members Four Corners Unit/CAC
WBCCI # 10105
AIR # 28748
Bob,
Here are a few photos of how and what we were using to polish. The only question you may want to get clarification is that your trailer is much newer and I know that AS used a different type of aluminum on the newer ones. I am unsure how this process will work on the newer units. You might want to PM Lavon and see if he has used this on a newer rig.
The bar of red stuff is the rouge we are using. There was a gray bar for the first cut, but that is nearly gone so we photographed the red one. The comb looking thing is to clean your buffer pads as you polish. All of these items and buffing wheels were included in the kit we purchased.
ID:	71792   Click image for larger version
ID:	71794   Click image for larger version
Louis & Sergio
Air #22673
WBCCI# 2731
Four Corners Unit
Old 11-26-2008, 11:24 AM   #33
LHall's Avatar
1962 28' Ambassador
Phoenix , Arizona
Hubcap Photo
Here is the close up of the hubcap that you requested.
Louis & Sergio
Air #22673
WBCCI# 2731
Four Corners Unit
Old 11-26-2008, 11:29 AM   #34
LHall's Avatar
1962 28' Ambassador
Phoenix , Arizona
Hooray!!!
We finished the curb side this morning between rain drops... yes rain in Phoenix. One of our 50 or so non-sunny days here.
Anyway, here are some photos showing the results.
ID:	71798   Click image for larger version
Louis & Sergio
Air #22673
WBCCI# 2731
Four Corners Unit
Old 11-26-2008, 11:32 AM   #35
LHall's Avatar
1962 28' Ambassador
Phoenix , Arizona
Thanks Jerry, perhaps you will make the Restoration Rally in April. We are planning to attend again, maybe we can do some more polishing.
Have a happy Thanksgiving
Louis & Sergio
Air #22673
WBCCI# 2731
Four Corners Unit
Old 11-26-2008, 12:00 PM   #36
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
I bought the same kit about 2 weeks ago. As all the exterior lights and protrusions are off the GT and I am ready to start. I have already polished all the removable exterior aluminum parts. I bolted the buffer to a board and then clamped it to a bench so I would not fling the parts across the room.
Old 11-26-2008, 12:50 PM   #37
1958 26' Overlander
Lander , Wyoming
Kip, I think you'll be happy with this system. It is definitely faster than using nuvite and compounding. I have used both methods on the doors I am restoring. Using the rouge is faster and gives a finish that looks as good as nuvite which is much more laborious. The rouge method definitely heats the aluminum so moving much more rapidly is essential. Ed
n2batr is offline   Reply With Quote
Old 11-26-2008, 12:55 PM   #38
Ken J's Avatar
1956 22' Flying Cloud
Durango , Colorado
Images: 14
Looks great
Yes! We will do some more polishing at the restoration rally....
Ken J
1956 Flying Cloud
Founder :
Four Corners Unit
Albuquerque National Balloon Fiesta
Rally
Vintage Trailer Academy - Formerly the original
restoration rally
Ken J is offline   Reply With Quote
Old 11-26-2008, 02:04 PM   #39
Aerowood's Avatar
Arvada , Colorado
What speed did you use for the initial cut?
Old 11-26-2008, 05:12 PM   #40
LHall's Avatar
1962 28' Ambassador
Phoenix , Arizona
we used the max speed on the polisher, it worked much better than the slower speed. I believe our polisher max speed is around 3000 rpm. We just kept the wheel moving.
Louis & Sergio
Air #22673
WBCCI# 2731
Four Corners Unit
Old 11-26-2008, 06:25 PM   #41
goransons's Avatar
1963 22' Safari
1955 26' Cruiser Overlander
Yakima Valley , Washington
Send a message via MSN to goransons
wow looks great, and far cheaper from what I see than the hundreds of dollars of nuvite and bonnets. Thanks for the hubcap photo too!
goransons is online now   Reply With Quote
Old 11-26-2008, 07:07 PM   #42
Surprise , Arizona
Yes, I'm looking forward to the next resto rally. Hopefully I can get out before then, trying to hit Happy Jack in about 4 weeks. Wonder if it will be too snowy?
Jerry C.
WBCCI #13317
AIR #25664
technical info on 67 ambassador - length 28 feet bishopbonner Member Introductions 3 05-28-2008 07:12 PM
diesel pusher less than 36 feet? rachel kings Classic Motorhomes 5 04-22-2008 04:35 PM
New member, getting our feet wet sunset19 Member Introductions 6 07-06-2007 07:39 PM
staying warm at 7000 feet silverback Winter Living 4 11-04-2005 03:09 PM
19' Bambi cork floor need sq. feet of A/S JimBrownUT Floor Finishes 4 01-07-2004 05:26 PM
