Old 07-20-2013, 09:14 AM   #1
1991 34' Limited
sheffield , Alabama
Zip Dee emergency
Help! I was pulling out my curb side awning on my new to me 34' limited for the first time. Had it pulled out, rolled up the center strap and tucked it under the awning and then a number 10 bolt snapped on the right side of the awning. The bolt holds the head assembly to the shaft that runs through the awning. The awning quickly rolled up, not before the loose right hand side slightly dimpled the side of the trailer. My question, whats the best way to straighten this out. I have reattached the head assembly but I can't unroll the awning since the center strap is rolled neatly up inside the awning.
Tim Watts
Tim Watts is offline   Reply With Quote
Old 07-20-2013, 10:03 AM   #2
LFC
Memphis , Tennessee
You'll probably need to rewind the spring and then install the bolt...a quick call to Zip Dee should tell you how many rounds.
LFC is offline   Reply With Quote
Old 07-20-2013, 11:48 AM   #3
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Tim Watts
Get a friend or two and a couple of ladders. You can unroll an awning by hand but it's rather hard on longer units so the more help the better. Since the spring unloaded itself you won't have that resistance to worry about.
Zipdee should also be able to tell you whether you should rewind the spring first or just install a new bolt, then do the spring.
About the dimple, ordinary sunlight should lessen it over time since it happened on a flat panel. First beauty marks are always traumatic, but we all get them. Continue to enjoy your Airstream.
Paula
Old 07-20-2013, 01:18 PM   #4
1976 31' Sovereign
Oswego , Illinois
Smile
Tim Watts
have one person each arm then pull out or attache piece of rope up high each arm then pull evenly either way takes two people, as far as other prob. call ZiDee they are very helpful. Bill
Old 07-22-2013, 07:52 AM   #5
1991 34' Limited
sheffield , Alabama
I was able to unroll the awning from the back end by hand while standing on a ladder. Got everything straighten out and working like new.
Thanks for the suggestions.
Tim Watts
