Old 07-28-2015, 10:02 AM   #1
2001 30' Excella
Full-time traveling , Hmmmm. what day of the week is it?
Zip Dee Center Support Arm Foot badly bent
My Zip Dee center support arm is badly bent, beyond repair, and is just barely holding on with 2 screws.
I had a new one sent from Zip Dee and am ready to replace the busted one.
What I can't decide is if I should use stainless steel metal screws (that is what appears to be holding it on) or buy a rivet gun and use the two rivets that came with the new support arm.
Since it already has screws, I think rivets are out of the question.
Any suggestions?
Photo shown is the new part from the supplier
JBBeaubeaux is offline   Reply With Quote
Old 07-28-2015, 06:32 PM   #2
Larry C's Avatar
1996 34' Excella
Elberta , Alabama
Jim,
If you can find stainless steel screws, that are just a little larger that the original holes, that should hold. I think I would also get the proper size lock washer....
Just out of curiousity, what happened?
Larry
Old age is coming at a really bad time!
1996 34' Excella 1000, interior totally redone, 2003 Dodge/Cummins HO, U.S. Gear exhaust brake, Diablo tuner, 115 gallon aux fuel, Bedslide, Airsafe/Reese Dual Cam, and a bunch of other stuff
Larry C is offline   Reply With Quote
Zip dee awning support arm CMSmith Our Community 3 08-09-2012 09:35 PM
Zip Dee Support Arm Air Staked to Ground Bambi_Bandit Awnings 21 08-19-2011 03:23 PM
Zip Dee - Center support or not? vhord Awnings 42 07-01-2010 07:57 AM
Zip Dee support arm stuck Skamper1 Awnings 23 03-19-2010 06:36 PM
Zip Dee main arm bar bent- help! kstampa Awnings 13 08-29-2008 05:14 AM
