Old 07-11-2015, 08:27 AM   #1
1991 29' Excella
Mission , Texas
Zip dee awning problems
I recently purchased a 29 ft excella and was trying to roll out my awning. In the process, I bent the aluminum bar that attaches the awning to the airstream. Rolled out it lined up straight and held up but when I went to roll up the awning would not retract all the way. The bent brace prevented it from completely rolling into the protective shield. Not want to leave it like that I pushed on the awning arm and managed to detach the arm from the base of airstream. The screws holding the awning the to the airstream were completely striped off by the force.
I've ordered the new part from Zip Dee, but I am worried about not being able to secure the bracket back to the airstream once the part arrives.
Has anyone ever had this problem? And if so what recommendations do you suggest to assure that the bracket will be securely attached.
Thank you.
Frogrene3 is offline   Reply With Quote
Old 07-11-2015, 08:35 AM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
My brackets are attached with two large screws and a single large rivet. The screws go directly into a frame member.
MICHAEL
Old 07-11-2015, 08:57 AM   #3
1991 29' Excella
Mission , Texas
Correct, mine is the same. However, the screws were yanked out from the bracket and the base of airstream and I am wonder if the screws will be able to tighten up enough to support the awning.
Old 07-11-2015, 09:11 AM   #4
AWCHIEF's Avatar
Images: 33
You might have to go to larger screws.
MICHAEL
Old 07-11-2015, 10:59 AM   #5
dames7's Avatar
2015 25' Flying Cloud
GILBERT , Arizona
I have a similar problem, the screws are good but the rivet broke and now have a dent on the side of the AS we're the when opening up the awning.
I will have to take dealer when I get back at the end of July.
David & Nancy Ames
WBCCI # 9403 -- AIR # 95597
2015 FC 25' RB
2013 Chevy Tahoe LTZ
dames7 is offline   Reply With Quote
Old 07-11-2015, 12:32 PM   #6
1991 29' Excella
Mission , Texas
Thank you for your input. I'll try original screws if not then I'll jump to a bigger size. It just hurts to see that I damaged my AS. ��
Old 07-11-2015, 03:00 PM   #7
beaumont , Texas
zip dee
This is a common problem. A good solution is to make a mounting plate,,, out of aluminum plate. 1/4 in.. a little larger than the original mount size.Use the same location al original, with the rivets to the internal frame, slightly larger screws for the new mount. It looks just fine when finished, you can get the aluminum stock at any hardware store. and the screws also. Be careful with the rivets, got the right ones for the job.. the right length.and diameter,Once you have your parts, it is about a 20 minute job. good luck.. I know there are posts about this in the forum.. with pictures.. I think Zepp was the poster.
Dixie722 is offline   Reply With Quote
Old 07-11-2015, 06:17 PM   #8
hugheym's Avatar
1961 16' Bambi
1969 27' Overlander
Bonner Springs , Kansas
You probably wont want to use this method for this. I think the plate suggestion is the best.
I had stripped threads in a water heater one time. I filled the threads that remained with JB weld. Once it dried, I re threaded this connection. It has been solid for ten or eleven years. Something that can be tucked away for future reference.
hugheym is offline   Reply With Quote
Old 07-11-2015, 06:44 PM   #9
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
You might consider using a rivnut.
Old 07-11-2015, 10:09 PM   #10
1979 23' Safari
Wayland , New York
Vintage trailer supply makes oversized Olympic rivets. That's what I used for mine. I also had to do the reinforced mounting plates to strengthen the area from PO damage half a!?d repair.
Old 07-11-2015, 10:16 PM   #11
1979 23' Safari
Wayland , New York
Here's a link, Gesipa Olympic Rivets
The 3/8" 6-6 should work, unfortunately you have to buy a bunch . I think OODM or inland rv sells them individually.
Old 07-12-2015, 07:56 AM   #12
1975 31' Sovereign
North Fort Myers , Florida
I you search Youtube there is a video from an AS dealer that shows how to straighten your support guides and not have to buy new ones.
TLBIJOU is offline   Reply With Quote
Old 07-12-2015, 04:26 PM   #13
Sandi & Bob's Avatar
1988 29' Excella
Browns Mills , New Jersey
I don't know if this will help, be we made a patch for the center support when the same thing happened. I will attempt to post a picture. Good Luck!
Sandi & Bob is offline   Reply With Quote
Old 07-12-2015, 04:28 PM   #14
1988 29' Excella
here's the picture of the patch for our center support of our ZipDee awning. hope it helps.
RELAX 12v AUTOMATIC AWNING RETROFIT KIT by Zip Dee for Main Awning LaBigDogs Awnings 12 07-30-2013 02:02 PM
Problems with mounting Zip Dee window awnings Eagle & Bear Awnings 6 12-02-2012 08:31 AM
Zip Dee Awning Problems lmcatee Awnings 4 01-08-2012 10:33 PM
Will a Zip Dee awning fabric fit on Dometic Awning tube? montanablue Awnings 2 10-24-2011 10:27 AM
Zip Dee up or Zip Dee down? highsidepass Awnings 24 11-17-2007 08:12 PM
