Old 01-15-2014, 07:16 AM   #15
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
3/4 ton truck. I carry a fairly big tool box with a lot of stuff. Box of PEX fittings and crimper. Box with electrical stuff. Box of rivets and the riveter. Roll of metal tape. Battery powered drill. In the box are lots of things I picked up at Walmart on the road for specific probalems. Changed the whole umbical connector at Walmart in Wasilla, AK, one day wne the old one came unhooked and I ground it off the cable dragging it down the highway. Overall we have had little trouble on the road. But the box goes just because I like having the stuff.
the owners manual has been the most valuable tool for me. I have needed help from it with various electricl problems.
Old 01-15-2014, 07:40 AM   #16
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
I carry a typical assortment of tools, hope to not need them. But also in case someone else does need some help. I do carry an extra 30 AMP cord plug.
Never thought about carrying PEX, might look into it.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 01-15-2014, 07:53 AM   #17
rbs
rbs's Avatar
2015 30' Classic
Decatur , Illinois
One thing that I have needed more than once, is a 50 amp to 30 amp adapter. Breaker kept tripping on the 30 amp socket, changed to the 50 amp and good to go.
rbs is offline   Reply With Quote
Old 01-15-2014, 08:00 AM   #18
tony6373's Avatar
2000 28' Excella
1994 31' Legacy 30
Hillsboro , Texas
Tooks
I carry a plastic tool box with the minimum set of stuff I think I can get away with. But the one thing no one else has mentioned is a good pocket multi-tool. I carry an original Leatherman in my pocket while traveling. It has saved many hours of looking for the right tool just to tighten a loose screw etc.
I'm very weight conscious and once I made the mistake of suggesting to my late wife that we should reconsider the number of pots, pans and other cooking utensils we were keeping in the trailer. Her response was "right, lest start by looking in your tool box".
Tony T
2000 28' Classic TT
1994 30' Land Yacht M/H
tony6373 is offline   Reply With Quote
Old 01-15-2014, 08:05 AM   #19
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Multitools are never the right tool for the job (unless the right tool is needlenose pliers) but a multitool is better than no tool at all. I have one that I keep in an outer pocket of my canvas toolbag, because it's often easier to just grab it than to haul out the whole bag and search through it for the right tool.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 01-15-2014, 09:22 AM   #20
Someday'59's Avatar
Powder Springs , Georgia
Images: 18
The most important tools:
Originally Posted by Andrew T View Post
Patience, good red wine, a sense of wonder and adventure.
You speak the truth!
~Lynnetta
my restoration & travel blog:
http://someday1959.blogspot.com
Someday'59 is offline   Reply With Quote
Old 01-15-2014, 09:29 AM   #21
1988 Argosy 32
Lomita , California
Amex,visa,master,AAA. cards will fix about anything i want to deal with
Wolfe is offline   Reply With Quote
Old 01-15-2014, 09:32 AM   #22
2004 28' Classic
austin , Texas
Moosetags, what a great list of Apps. I am going to check them out!
Ntex is offline   Reply With Quote
Old 01-15-2014, 09:52 AM   #23
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
In addition to 50 pounds or more of tools, two 3 ton combination bottle jack and jack stand units:
http://www.toolsmithonline.com/produ...ack-Stand.html
Old 01-15-2014, 10:24 AM   #24
Roadtrain O--O~(--ooo--)
ebair's Avatar
2000 34' Limited
1979 31' Excella 500
Miamisburg , Ohio
Originally Posted by Bill M. View Post
3/4 ton truck. I carry a fairly big tool box with a lot of stuff. Box of PEX fittings and crimper. Box with electrical stuff. Box of rivets and the riveter. Roll of metal tape. Battery powered drill. In the box are lots of things I picked up at Walmart on the road for specific probalems. Changed the whole umbical connector at Walmart in Wasilla, AK, one day wne the old one came unhooked and I ground it off the cable dragging it down the highway. Overall we have had little trouble on the road. But the box goes just because I like having the stuff. The owners manual has been the most valuable tool for me. I have needed help from it with various electricl problems.
+1 on the spare umbilical connector. We had the same experience on the last trip, also a spare 30amp to 110 house adapter, ours toasted itself along with male end of the 30 amp while glamping, try finding one of those at a RV park in the sticks.
'00 34' Classic Limited (LOVSHAC)
'12 3500HD, 4x4 LBZ D/A CC LB
AIR #12881
TAC OH-10
ebair is offline   Reply With Quote
Old 01-15-2014, 10:35 AM   #25
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
We travel light as possible on long trips far from home, so tools can be a space and weight hog. We need a set of sockets and wrenches, breaker bar, screwdrivers, pliers, etc. that fit a sturdy nylon too bag. A torque wrench for the wheel lugs, plastic tire changing ramp (no jack), moisture test meter, small multi meter, Fluke IR thermometer to check tires, brakes, differential, pedestal surge protector, and a Cosco two-step ladder to reach upper side of trailer, step up into truck bed, outdoor coffee table, and is a low work seat. Not tools, but also polish, cleaners, corrosion treatment, and lubricants, and a portable water softener.
Doug and Cheryl
Old 01-15-2014, 10:38 AM   #26
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
We carry an adapter that is the reverse of that- to plug a 50 amp trailer into a 30 amp socket when no 50 amp socket is available- Salmon Lake Park, Grapeland, TX only has 5-6 50 amp sites and we never get there early enough-
I want to build or purchase an apparatus/adapter that is a 50 amp female to 2 30 amp males- plug the 50 amp trailer into 2 30 amp sockets at Salmon Lake Park-
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 01-15-2014, 11:29 AM   #27
1984 31' Sovereign
charleton , Illinois
Don't forget Glue. I carry several types: contact cement, wood glue, super glue, and an all purpose like duco cement.
jerry d is offline   Reply With Quote
Old 01-15-2014, 03:31 PM   #28
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
I am amazed at how often I use a dremel tool kit on the road
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
