Old 03-31-2013, 03:53 PM   #1
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
Rivet Your favorite Airstream specific Tools and Equipment
With all the combined experience of this forum, we all could benefit tremendously from a list of specific Tools and Equipment used in the restoration of the Classic Airstream Trailers and Motor Homes.
I have always struggled to find just the right tool to make precision cuts working on exterior aluminum panels. I finally found the jig saw that does what I expect, mainly due to a roller guide the blade runs on.
Thumbs up to the Bosch jigsaw JS365.
Let's hear about (and see) your favorite tools and/or custom equipment
1996 Airstream B190
1987 29' Sovereign Trailer
1997 30' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 03-31-2013, 04:05 PM   #2
tkasten's Avatar
1965 22' Safari
Vassar , Michigan
Olympic Rivet Shaver tool. Makes those Olympic rivets look real prudy!!
Tim
TAC MI 14
Everyday is a Saturday
tkasten is offline   Reply With Quote
Old 03-31-2013, 04:05 PM   #3
Airstream Driver
1997 30' Excella
Images: 51
I build this "thing" to remove and install the axles on my 34'. I am sure professional shops have sophisticated set-ups to keep the axles from "rolling" during RR, but this did the job for me. Since tank cover locations may very in different trailers, some of the dimensions may not work for all trailers.
ID:	182202   Click image for larger version
ID:	182204   Click image for larger version
1996 Airstream B190
AIR #13
Old 03-31-2013, 04:25 PM   #4
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
I modified a knife blade so it would fit a Sawzall so I could cut the Vulkem from between the drain pan and the roof when changing an air conditioner. It turns an ordeal into a job. I'll see if I can remember to snap a photo tomorrow.
Old 04-03-2013, 11:36 AM   #5
dirigible25's Avatar
1997 25' Safari
Yakima , Washington
Because of things like this wad of wires going through the front of my AS, and through the floor of my AS, I use a Power Probe. This circut tester is for 12 or 24 volt systems. It will check continuity, determine polarity, check voltage, check for a bad or ineffective ground, help trace short circuits, activate or power on things like a fan, motor or a light. You can also insert the probe into a trailer pig tail and check to see if the tail light, brake light, running light, or turn indicator is activated. The probe also has a built in circuit breaker that will trip so as not to burn up if you power it on and there is a direct ground. It also has modes or functions that will allow you to check things like a battery crank test, or trace a loose wire or connection that periodically drops a signal, such as a speaker wire, etc.. A good trouble shooting tool with a lot of functions.
ID:	182387   Click image for larger version
Dennis
1997 25' Safari
2012 Chevy Silverado HD 2500
Duramax/Allison
dirigible25 is offline   Reply With Quote
