Old 08-09-2013, 04:21 PM   #1
1973 31' Sovereign
Marysville , California
Yellow jackets in the underbelly
We have yellow jackets in the underbelly entering through the hole where the lever for the steps is located. Makes it difficult to enter the RV. Can anyone tells us how to get rid of them. How should we kill the queen? Thank you for any help you can give us.
BabsTrailer is offline   Reply With Quote
Old 08-09-2013, 04:49 PM   #2
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
You know, we had a somewhat similar problem with hornets. They were entering around the steps someplace. For the time being, we kept our distance from one another, and then I took a nice drive to Salida, CO from here (about 200 miles), and no more hornets.
Lynn
WBCCI 21043
Old 08-09-2013, 06:28 PM   #3
Silver Hawk's Avatar
1975 31' Sovereign
Palomar Mountain , California
I had them. Go to Home depot and buy a spray can of "Hornet Spray" - works! Spray it on the area and they are gone - have used it on bees, hornets, etc. Now I use around our home too!
Silver Hawk is offline   Reply With Quote
Old 08-09-2013, 07:26 PM   #4
dznf0g's Avatar
Oswego , Illinois
A less elegant solution I had to employ in one situation at the house......plug the ingress and egress points with newspaper and wait for them to starve.....if you have the time...it takes about a week.
-Rich-
Old 08-09-2013, 07:36 PM   #5
dkrug's Avatar
2012 30' International
Bad Axe , Michigan
We have had serious issues with yellow jackets this year! I got stung on the face and the dogs have been stung. Whatever you do, do at night when they are all in the hive.
2012 30' International Serenity
1947 Spartan Manor
2005 28' Safari LS - traded
1977 31' International Sovereign - sold
2012 Ford F250 Superduty Crewcab
WBCCI# 1007 Air#2158
dkrug is offline   Reply With Quote
Old 08-09-2013, 07:45 PM   #6
1977 Argosy 24
Milltown , Wisconsin
Starting fluid, which is either, drops them in their tracks. Then you can do the Harlem shuffle on them to further the abuse.
ventport is offline   Reply With Quote
Old 08-09-2013, 08:42 PM   #7
r carl's Avatar
Lin , Ne
A can of brake kleen works too.
Old 08-09-2013, 09:01 PM   #8
Central , Mississippi
Take a shop vac and a 10' section of 1.50" of PVC pipe. Duct tape the PVC to the shop vac hose. Stick the end of the PVC up to the hole and turn on the shop vac, walk away for a few hours.
Down here, yellow jackets nest underground and we use this trick to get rid of them before digging up the nest.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 08-09-2013, 09:12 PM   #9
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Ok... You sucked 'em up. They don't just die??!! What do you do with the bucket-I-buzzers-n-stingers?
Peace and Blessings..
Channing
WBCCI# 30676
Old 08-09-2013, 09:29 PM   #10
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
Spray some wasp killer into the hose of the vac, while still on. Then let it sit around for a few hours before listening to see if they are dead. If still buzzing a bit,take off the hose and spray directly into the vac input while running. The vac will smell of bees for months.
Old 08-09-2013, 10:58 PM   #11
USN/LAPD Retired
Safari-Rick's Avatar
North Las Vegas , United States
You know what?...... Just go to the Home Depot/Lowes and get the damnn spray.. That's all you need.
It does the trick.
2007 Dodge Ram Quadcab 6.7L Diesel w/jakebrake
"Better to have more then you need, then need more then you have because you don't have enough!"
AIR #: 8129
Safari-Rick is offline   Reply With Quote
Old 08-10-2013, 03:53 AM   #12
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
It does the trick.
I don't know why but this made me chuckle. :-)
Old 08-10-2013, 04:26 AM   #13
noreen&sal's Avatar
1981 27' Excella II
mays landing , South Jersey
It does the trick.
Exactly. And like has been said, do it after dark. Sal
Sal & Nora
Let us live so that when we die even the undertaker will be sorry. Mark Twain
AIR 42483
TAC N.J. 17
WBCCI 24740
noreen&sal is offline   Reply With Quote
Old 08-10-2013, 06:07 AM   #14
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Sometimes it's not as easy as the use of a spray would suggest. If they're in the underbelly, just where are they? With those sprays, if I remember correctly, you have to actually hit the wasps/hornets. It's not like Raid fly spray, where you merely spray into the air in the room.
Lynn
WBCCI 21043
