Old 08-10-2013, 06:26 AM   #15
dznf0g's Avatar
Oswego , Illinois
Originally Posted by eubank View Post
Sometimes it's not as easy as the use of a spray would suggest. If they're in the underbelly, just where are they? With those sprays, if I remember correctly, you have to actually hit the wasps/hornets. It's not like Raid fly spray, where you merely spray into the air in the room.
Lynn
Yes, that's exactly why I suggested the newspaper and starving them. Had some in a wall at the house where I couldn't spray them. Starving worked.
-Rich-
Old 08-10-2013, 07:25 AM   #16
2010 25' FB Flying Cloud
Davenport , Iowa
When using the starting fluid, brake cleaner and gasoline than follow up with a match; than the wasps, A$ and you will all be gone.
a
44
Airtandem is offline   Reply With Quote
Old 08-10-2013, 07:53 AM   #17
pappy19's Avatar
2002 30' Classic S/O
Garden Valley , Idaho
All you need to do is buy some dog flea collars and stuff a piece of it into the hole. Do this at night when they are all in the nest. I buy 2 extra large dog flea collars each year in the spring and cut 3-4 inch pieces and place them in every louvered or open location and then use the final piece with the buckle in the propane cover. No more bugs, bees, roaches, ant or what have you.
2008 F-250 4X4 Lariat V-10
2007 Kubota 900 RTV
1996 Ford Bronco
2007 Lincoln LT
pappy19 is offline   Reply With Quote
Old 08-10-2013, 08:21 AM   #18
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
X2 on the dog flea collars been using them for years.
Garry
Old 08-10-2013, 08:50 AM   #19
Davenport , Iowa
wasps and bees are attracted to leaking propane, sometimes works better than a sniffer.
Old 08-10-2013, 10:00 AM   #20
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
And to think some people actully put these on their fur-babies!?
Sure glad we don't have fleas here!
Shari
Old 08-10-2013, 12:41 PM   #21
pappy19's Avatar
If the dog flea collars repel ticks they will also repel other bugs, etc. I started using them in my permanent deer hunting huts to keep the wasps away. Works great, also repels wako anti-hunters as well.
2007 Kubota 900 RTV
1996 Ford Bronco
2007 Lincoln LT
Old 08-10-2013, 01:00 PM   #22
r carl's Avatar
Lin , Ne
I think the Shell no pest strips from the 1970's would work great.
r carl is online now   Reply With Quote
Old 08-20-2013, 10:30 AM   #23
1973 31' Sovereign
Marysville , California
Thank you for all you wonderful and funny suggestions for dealing with our bee problem in the under belly of our Airstream. We did get the wasp spray as suggested and stuffed the hole with a rag. One bee did try to get in but died on the rag. The end of the bees!!! We are very grateful to you all!!
BabsTrailer is offline   Reply With Quote
