Old 10-08-2014, 08:40 AM   #1
65will
65will's Avatar
1969 25' Tradewind
Greenwich , New York
would you run fridge on the road
Hello All,
I have a 69 Trade Wind with the original Fridge.It is a Dometic MB52C. The question I have is would you run this on propane while traveling? For vents it has the opening in the belly pan and the floor covered with chicken wire. If the flame blew out it should shut the gas off. As of yet I have not ran it on the road. Does anyone have experiance running these old units on the road. Thanks
65will is offline   Reply With Quote
Old 10-08-2014, 09:11 AM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
How else would I keep the beer cold?
2004 Excursion 4x4
HowieE is online now   Reply With Quote
Old 10-08-2014, 09:17 AM   #3
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
Always
SAFE TRAVELS
Bud
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
Old 10-08-2014, 09:24 AM   #4
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
We do also. Never had any issues.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 10-08-2014, 09:52 AM   #5
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Yup... 'cept while refueling.
Aaron
WBCCI #XXXX AIR #2495
Old 10-08-2014, 09:56 AM   #6
teagues's Avatar
2008 20' Safari SE
Charlotte , North Carolina
I am far more concerned about leaving on the hot water heater than the fridge.
teagues is offline   Reply With Quote
Old 10-08-2014, 10:36 AM   #7
jay
1974 27' Overlander
danville , New Hampshire
I do not ever travel with my tanks turned on. in my opinion much too risky.
Jay.
jaygood31 is offline   Reply With Quote
Old 10-08-2014, 10:45 AM   #8
gwg
gwg's Avatar
2015 30' Classic
Glen Mills , Pennsylvania
It's on LP while traveling, always.
gwg is offline   Reply With Quote
Old 10-08-2014, 10:48 AM   #9
1978 Argosy 24
MooreHaven , Florida
In previous SOBs i have always run the fridge while underway,however i prefer to have the gas shut off so run it on 120v from a small inverter.The TV alternator carries the load so no battery problems.
I will do the same with our Argosy when i get it road ready.
This is only temporary unless it works! Red Green
oldiesel is offline   Reply With Quote
Old 10-08-2014, 10:49 AM   #10
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
We have always traveled with it on, it would very inconvenient not to have fresh/frozen food available on a cross-country trip, months on the road. Is it safe? I believe there is enough safety in the system be be comfortable with it.
If uncomfortable when fueling just shut it off and turn it on again when finished.
Doug and Cheryl
Old 10-08-2014, 02:54 PM   #11
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
We travel with it on. The refrigerators have a safety that shuts off the gas valve if the flame blows out. When traveling with the flame on, best practice is to shut the refrigerator off when you fuel up at a gas station. Newer tanks (with the POL connections) also have quick release sensors on the gas bottle valves. If a quick release is detected (such as a hose leak or tear, the valve on the tank closes.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 10-08-2014, 03:09 PM   #12
1976 31' Sovereign
Oswego , Illinois
Smile re-fridge
Originally Posted by 65will View Post
Hello All,
If worry about flame blowing out, make scoop such as on airplane engines to fit over hole, width of hole, flush at front taper to 1-1/2 inch or so at back, bend flange at sides and front then pop rivet on belly pan. This we did on my 66 & 67 AS, never blew out after that. Yes I leave fridge on propane for longer trips, but have on elect. at home nice and cold frozen ice cream etc. after short trips. Bill
Old 11-06-2014, 07:40 PM   #13
Natty Lite's Avatar
Mandeville , Alabama
Is it legal to travel with your propane tanks open?
Natty Lite is offline   Reply With Quote
Old 11-06-2014, 07:47 PM   #14
HowieE's Avatar
Images: 12
YES
2004 Excursion 4x4
An Airstream Motorhomer Would Never Do This.....Would They? Fly at Night Airstream Motorhome Forums 11 12-09-2012 10:38 AM
Would you chance it? What would happen? Becky B. Repairing/Replacing Floor &/or Frame 6 03-05-2010 09:06 PM
How long would a furnace run on 2 40 gallon lp tanks? Mrcrowley Furnaces, Heaters, Fireplaces & Air Conditioning 13 01-02-2009 04:03 PM
Who would have thought they would steal my.... Kenyon On The Road... 30 10-21-2007 04:45 PM
