Old 02-01-2016, 07:44 PM   #1
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
Woops - will this cost me?!
So - first let me say hello air forums - I've been super busy and distracted and not been on here in a while...hope everyone is doing great!
I winterized my airstream 4 nights ago.
In the process - somehow I left the water pump on....and just tonight went in to trailer to get something and heard it running...
Not sure what this is going to mean
Cannot believe I did that! This will be an all time record dumb dumb move for me lately!!
Any advice at this point
My next scheduled trip will be the end of April.
Advice appreciated!
PharmGeek is offline   Reply With Quote
Old 02-01-2016, 07:52 PM   #2
Sbb
begorragirl
Sbb's Avatar
2017 25' Flying Cloud
Denville , New Jersey
Well at least you didn't hook the black tank flush hose upthinking it was your fresh water intake. Missed the mess by 1"!
2006 Bambi CCD ("EireStream!!")
2010 Funfinder
2005 T@B
2001 Teardrop, Mountain Hardware Tent
For some perfection takes a little longer...
Sbb is offline   Reply With Quote
Old 02-01-2016, 07:53 PM   #3
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up Welcome back...
Rat's...hate it when that happens......two daze on an empty tank is my personal best.
SFSG...6yrs ago and pump still going strong.
PFC
but I’m the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 02-01-2016, 07:56 PM   #4
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
Well maybe I'll survive
Hahaha sbb - oh man that was close !!!!!!!! Hahahaha
Old 02-01-2016, 07:57 PM   #5
dznf0g's Avatar
Oswego , Illinois
It'll be fine. It's a diaphragm pump and doesn't need water as a coolant or friction reducer.
-Rich-
Old 02-01-2016, 07:57 PM   #6
1998 30' Excella 1000
Livingston , Texas
I believe the manufacturer states that they can be run dry..... but for four days? You could get a another jug of antifreeze and see if it will still pump it. A cheap test so you won't be surprised come April.
Siegmann is offline   Reply With Quote
Old 02-01-2016, 07:59 PM   #7
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
I just came back from trailer and realized I used all my pink stuff - so I'll pick some up tomorrow and test it out - must have gotten a bit of air in the system somewhere - I thought I worked pink stuff in every single place then took off the winterization kit - probably right when I did that some air got in and I did not notice
Old 02-01-2016, 08:00 PM   #8
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
Is anything leaking? If not, I think you should be ok there. The pump may have had its' life shortened by a few hours. But that's just a guess.
Others may have different (and maybe more correct) view.
www.nesa.org
Air No. 6427
Old 02-01-2016, 08:00 PM   #9
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
Thanks - that is reassuring!
Old 02-01-2016, 08:04 PM   #10
curnes's Avatar
2010 23' FB Flying Cloud
McMinnville , Oregon
Did it last fall. Cost me $125 for new pump. Kicked myself in the butt then thought, it could have been a lot worse, now I have a new water pump.
curnes is offline   Reply With Quote
Old 02-01-2016, 08:05 PM   #11
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
Possibly it will still be fine - I believe earlier pumps could not tolerate this, but some newer models can survive running dry. We have done it with no apparent ill effect.
Likewise, leaving a hot water heater electrical element on with no water in the tank would likely burn out the element on earlier models.
Somehow we managed to leave hours switched on after winterizing (no water in the tank) for quite a few hours whenonshore power. Most likely the HW heater electrical switch was switched on by someone thinking it was the light switch! Could only have been me or one other person!)
When I discovered it and switched it off, I figured the element would be shot. Of course I blamed that other person! But it was fine.
Then I read someplace in the manual that the newer HW elements could survive this. Still not something I would do intentionally to test it though!
Brian
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 02-01-2016, 09:22 PM   #12
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
Well no leaks around the pump - so far so good - I'll test it all out tomorrow and see that it holds pressure no prob
Old 02-01-2016, 09:29 PM   #13
Livingston , Texas
Brian
You must have the same switch panel in the bath as me. It always bothered me the switches were so close. Now when I winterize and drain the heater, I put a strip of masking tape over that switch.
Old 02-02-2016, 04:46 AM   #14
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
If it was running when you went back to the trailer then it works. We mistakenly leaves ours on a lot. Seems fine.
SAFE TRAVELS
Bud
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
Whats Does It Cost You For Plates On Your RV? 68 Suburban Our Community 32 10-14-2015 11:54 PM
Polishing...approx cost? Drew Cleaning, Stripping & Polishing 10 03-31-2014 10:37 PM
Cost to restore a gutted Airstream Draco General Interior Topics 28 02-18-2013 11:17 PM
cost of '81 Excella new? jaiman General Motorhome Topics 7 11-09-2002 05:49 AM
