Old 02-02-2016, 06:51 AM   #15
1999 30' Excella 1000
small town , Maryland
Originally Posted by Wingeezer View Post
Somehow we managed to leave hours switched on after winterizing (no water in the tank) for quite a few hours when on shore power. Most likely the HW heater electrical switch was switched on by someone thinking it was the light switch! Could only have been me or one other person!)
When I discovered it and switched it off, I figured the element would be shot. Of course I blamed that other person! But it was fine.
Brian
My ex could do no wrong, so I always blamed myself for things gone wrong. The problem was... she was ok with that. Never sweat the small stuff, life is too short for that. Pharmgeek your thread shows me I'm normal...what a relief. Turn a negative into a positive...now you have a excuse to get the quieter pump. Good to see your back posting again.
streaminwild is offline   Reply With Quote
Old 02-02-2016, 07:19 AM   #16
2017 25' Flying Cloud
2014 23' FB Flying Cloud
2008 20' Safari
Chino Valley , Arizona
A water pump is one of the easiest thing to replace in your AS and one of the worst things to go wrong while camping. For that reason I always carry a spare. If it where me I would by a new one and store it in the AS. You may or may not have damaged your water pump, but eventually it will go bad and probably at the worst possible time.
AIRTRVL is offline   Reply With Quote
Old 02-02-2016, 08:54 AM   #17
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
Good point about a spare!
PharmGeek is offline   Reply With Quote
Old 02-02-2016, 09:01 AM   #18
Free Range Human
Drathaar's Avatar
2012 25' FB Flying Cloud
Twin Rocks , Oregon
Originally Posted by Siegmann View Post
You must have the same switch panel in the bath as me. It always bothered me the switches were so close. Now when I winterize and drain the heater, I put a strip of masking tape over that switch.
I built a plexiglas box that goes over the two WH switches so that we can't turn one on by mistake.
Old 02-02-2016, 09:43 AM   #19
1998 30' Excella 1000
Livingston , Texas
What is that saying.... "necessity is the mother of invention".
Siegmann is offline   Reply With Quote
Old 02-02-2016, 03:21 PM   #20
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario , Ontario
I believe the manufacturer states that they can be run dry..... but for four days? You could get a another jug of antifreeze and see if it will still pump it. A cheap test so you won't be surprised come April.
It seems that the placement of those switches in the bathroom isn't the only 'misthought"
It seems that there are a number of design 'placements' that were installed without any thought to the dynamics of usage.
One wonders what the design team is thinking, if indeed they DID think at all!
MelGoddard is offline   Reply With Quote
Old 02-02-2016, 03:23 PM   #21
One wonders what the design team is thinking, if indeed they DID think at all!😬
Old 02-02-2016, 06:48 PM   #22
Livingston , Texas
Yeah, like the things that I have had to fix that I could not access without cutting holes:
- Gray tank dump valve
- Black tank dump valve
- Low point drain valves
- Shower drain
- Front door frame hinge bolts
Let me think a little bit, and I'll come up with more.... just remember, you started this.
Old 02-03-2016, 11:36 AM   #23
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
Oh that is painful
Old 02-03-2016, 09:58 PM   #24
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
Update:
Pumped in some more pink stuff - pump seems to work fine
Whew
Gonna get a backup for later though - thanks everyone
Old 02-05-2016, 05:25 AM   #25
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Images: 8
I may have a different control panel than you but I added a lighted switch (blue) to see when it was on. It provides at least a visual.
WBCCI 8653/AIR 60240
2017 Ford F-150 3.5 Ecobeast Gen 2 3.55 Platinum
Old 02-05-2016, 06:57 PM   #26
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
Great idea - I plan on doing something to help me remember
Whats Does It Cost You For Plates On Your RV? 68 Suburban Our Community 32 10-14-2015 11:54 PM
Polishing...approx cost? Drew Cleaning, Stripping & Polishing 10 03-31-2014 10:37 PM
Cost to restore a gutted Airstream Draco General Interior Topics 28 02-18-2013 11:17 PM
cost of '81 Excella new? jaiman General Motorhome Topics 7 11-09-2002 05:49 AM
