Old 10-16-2014, 05:50 PM   #1
Builder of Diesel Jeeps
westernjeep401's Avatar
2014 28' International
Sedona , Arizona
Wiring repair
This ground pulled-free from the crimp connector. I do not know which circuit it grounds. Anyway, here's a couple frames showing the fix.
14 Serenity 28'
#5261
westernjeep401 is offline   Reply With Quote
Old 10-16-2014, 05:51 PM   #2
Sedona , Arizona
Name:	ImageUploadedByAirstream Forums1413503451.408724.jpg
I nudged it while underneath clearing away a black widow web. It came loose.
14 Serenity 28'
#5261
Old 10-16-2014, 05:52 PM   #3
Sedona , Arizona
Name:	ImageUploadedByAirstream Forums1413503513.900731.jpg
I used to see these crimp connectors on truck bodies supplied to DOT. The vendor was Godwin.
14 Serenity 28'
#5261
Old 10-16-2014, 05:53 PM   #4
Sedona , Arizona
Name:	ImageUploadedByAirstream Forums1413503595.104639.jpg
Using a Lawson Crimp-n-seal solder connector.
14 Serenity 28'
#5261
Old 10-16-2014, 05:55 PM   #5
Sedona , Arizona
Name:	ImageUploadedByAirstream Forums1413503674.249196.jpg
Crimped with ratcheting crimper.
14 Serenity 28'
#5261
Old 10-16-2014, 05:55 PM   #6
Sedona , Arizona
Name:	ImageUploadedByAirstream Forums1413503717.704607.jpg
Heat gun.
14 Serenity 28'
#5261
Old 10-16-2014, 05:57 PM   #7
Sedona , Arizona
Name:	ImageUploadedByAirstream Forums1413503754.535243.jpg
ID:	224511Click image for larger version
Name:	ImageUploadedByAirstream Forums1413503767.932846.jpg
ID:	224512Click image for larger version
Name:	ImageUploadedByAirstream Forums1413503785.178105.jpg
I bought this wire tool off the truck 20 years ago to scruff ground connections like on the AS. The polymer coating keeps the strands from fraying.
14 Serenity 28'
#5261
Old 10-16-2014, 05:58 PM   #8
Sedona , Arizona
Name:	ImageUploadedByAirstream Forums1413503886.777725.jpg
Connected to frame rail.
14 Serenity 28'
#5261
Old 10-16-2014, 05:59 PM   #9
Sedona , Arizona
Name:	ImageUploadedByAirstream Forums1413503923.501600.jpg
ID:	224515Click image for larger version
Name:	ImageUploadedByAirstream Forums1413503937.115677.jpg
Coated with spray tape. Similar repair to electric jack circuit connector at battery.
Trailer is new.
14 Serenity 28'
#5261
Old 10-17-2014, 07:07 AM   #10
Tyvekcat's Avatar
Blacksburg , Virginia
ground
Hmmmm. I have seen that ground, but never checked it to see if was loose.
I will tomorrow.
Next time I am at Lowes I think I will look for the liquid tape. Good idea
Have a good one !
Ra, Chelle & Natasha
For my next trick, I will use my new Airstream & Dodge Ram 2500 CTD to make this pile of money disappear.
Tyvekcat is offline   Reply With Quote
Old 10-17-2014, 07:26 AM   #11
1964 26' Overlander
Myrtle Beach , South Carolina
Wow thanks for all the pics. Never knew I had to have so many tools or it was so involved just to repair a ground wire.
streamdreamn is offline   Reply With Quote
Old 10-17-2014, 09:29 AM   #12
Sedona , Arizona
It's my vocation. I reckon the Snap On guy has bought his own AS due to my patronage.
14 Serenity 28'
#5261
Old 10-17-2014, 10:04 AM   #13
Sedona , Arizona
Wiring repair
After this I found the jack circuit terminal with the same type ring. It, too, pulled loose with a tug. Same repair.
The reason I seal-up exterior connections like this is if left open, they inevitably corrode, resistance goes up, then the circuit opens usually at the worst time.
14 Serenity 28'
#5261
Old 10-17-2014, 11:01 AM   #14
Tom Nugler's Avatar
1972 25' Tradewind
McHenry County , Illinois
Good illustrated step by step repair.
We need to get more people to start using these superior self sealing, heat shrink connectors.
When we started using these in the shop 30 years ago I saw a video comparing the crimped/sealed connector against a soldered/taped one in a 2-foot length of wire. Shorting the wire to ground had the soldered connection failing in a few seconds. The crimped wire set had the wire burned through before the connector failed.
Now that they are available to the general public I can't think of any reason to use any other method of repair.
Tom
AirForums # 2806
WBCCI / VAC # 6411
Not All Who Wander Are Lost.
Avid supporter of trailing edge technology.
Tom Nugler is offline   Reply With Quote
Water pump wiring and proper wiring Supertwin1 Water Heaters, Filters & Pumps 8 05-23-2014 07:05 AM
Plastic bathroom components crack repair with 3M 4240 semi-rigid plastic repair kit Top Upholstery, Blinds, Walls & Interior Finishes 1 05-09-2011 07:11 PM
shop repair of 1970s rear frame separation (non elephant ears repair) RV shop review simonhanbury Repairing/Replacing Floor &/or Frame 49 06-24-2008 09:16 AM
1975 Argosy Need wiring diagram to repair directional lights, etc. Rt66Argosy Member Introductions 2 09-27-2006 09:51 AM
Is House Wiring the same as Automotive Wiring? swebster Mechanics Corner - Engines, Transmission & More... 7 06-15-2004 06:11 AM
