Old 10-17-2014, 11:05 AM   #15
Alphonse's Avatar
2010 28' Flying Cloud
Lower Alabama , USA
LG, nice repair and far superior to original install. Thanks for sharing the good ideas.
Alan
"If you must choose between two evils, pick the one you never tried before!"
Air #64439
Southeastern Camping Unit WBCCI #5033
TAC AL-8
2018 Canopenian
Alphonse is offline   Reply With Quote
Old 10-17-2014, 11:13 AM   #16
1977 Argosy 24
Milltown , Wisconsin
Originally Posted by Tom Nugler View Post
Good illustrated step by step repair.
When we started using these in the shop 30 years ago I saw a video comparing the crimped/sealed connector against a soldered/taped one in a 2-foot length of wire. Shorting the wire to ground had the soldered connection failing in a few seconds. The crimped wire set had the wire burned through before the connector failed.
Tom
What part failed first on the soldered connector?
ventport is offline   Reply With Quote
Old 10-17-2014, 03:34 PM   #17
Builder of Diesel Jeeps
westernjeep401's Avatar
2014 28' International
Sedona , Arizona
I appreciate it. You get underneath a salter dripping sodium chloride in freezing temps to discover one of those crap connectors and it makes an impression!
14 Serenity 28'
#5261
westernjeep401 is offline   Reply With Quote
Water pump wiring and proper wiring Supertwin1 Water Heaters, Filters & Pumps 8 05-23-2014 07:05 AM
Plastic bathroom components crack repair with 3M 4240 semi-rigid plastic repair kit Top Upholstery, Blinds, Walls & Interior Finishes 1 05-09-2011 07:11 PM
shop repair of 1970s rear frame separation (non elephant ears repair) RV shop review simonhanbury Repairing/Replacing Floor &/or Frame 49 06-24-2008 09:16 AM
1975 Argosy Need wiring diagram to repair directional lights, etc. Rt66Argosy Member Introductions 2 09-27-2006 09:51 AM
Is House Wiring the same as Automotive Wiring? swebster Mechanics Corner - Engines, Transmission & More... 7 06-15-2004 06:11 AM
