Old 10-20-2014, 06:03 PM   #57
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
I do not blow out lines
I let the pink stuff run a bit to fill the corresponding p traps and I think with that extra going Through I'll be fine
PharmGeek is offline   Reply With Quote
Old 10-20-2014, 06:08 PM   #58
TinTin's Avatar
2009 23' FB Flying Cloud
Canmore , Alberta
Have you tried getting antifreeze into the black tank flush line, Pharm? Tough to do!
Bob and Nancy
http://www.rwcphoto.smugmug.com
Cheer Up, Slow Down, Chill Out!
TinTin is offline   Reply With Quote
Old 10-20-2014, 06:28 PM   #59
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
Not yet - I will just blow air in there and call it a day I think? Not sure
I don't have an air compressor if any sort though except my 12v one for slooooow filling of tires with air
Old 10-20-2014, 06:32 PM   #60
TinTin's Avatar
Canmore , Alberta
The point of my earlier post was that I wasn't very successful in blowing that line out or adding antifreeze due to the backup valve at the line's inlet.
Bob and Nancy
Old 10-20-2014, 08:28 PM   #61
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Didn't I read on another thread a couple years ago that someone had an Interstate with the black tank flush fitting check valve inserted backwards? Maybe they did it again?
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 10-20-2014, 08:36 PM   #62
TinTin's Avatar
Canmore , Alberta
Protag, it's not on backwards (i.e. it pushes inwards to open, springs back out to close). Just very difficult to push it in and add antifreeze at the same time. The opening around the check valve is small. Also, air pressure didn't appear able to open it at my compressor output setting of 40-50 psi (just judging from the sound, little air went in).
I did manage to get in about 250 mls. of antifreeze with a squeeze bottle.
Had no trouble using the line to flush the tank with water a few times this summer.
I'm not gonna worry about it, I'm pretty sure (knock on wood) that this flush line self-drains.
Bob and Nancy
Old 10-20-2014, 10:49 PM   #63
mefly2's Avatar
2015 25' FB Eddie Bauer
That's my take as well ...
Old 10-24-2014, 10:29 PM   #64
SSquared's Avatar
2013 25' FB Flying Cloud
Longmont , Colorado
More on black tank flusher
Back on Oct. 7, I mentioned that the blank tank flusher was supposed to be OK without being winterized, then Protag pointed out that even if the device was OK, there could be water in a low point in the attached lines.
So I got out my belt and suspenders and air compressor, and gave it a tank of air. The air blew through as you would expect. The air tank emptied in maybe a minute. Also, my wife had the toilet open when I did it, both to make sure the pressure would be released, and to see if anything happened in there. She reported seeing a little water spray. So points to Protag.
By the way, with the size compressor I have (1 hp, 10 gallon tank), I use a process like what richw46 described: Let the compressor charge, blow out a sink, let it charge again, repeat as needed.
SSquared is offline   Reply With Quote
Old 10-25-2014, 03:04 AM   #65
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
That is a most excellent report! Thanks
I now need a compressor on my Christmas list
Old 10-25-2014, 08:40 AM   #66
TinTin's Avatar
Canmore , Alberta
Interesting, SSquared. When I blew my line, it seemed like little if any air went past the stop valve. I had reduced my air pressure down to about 40-50 psi, maybe I should have blown it at the full tank pressure, about 100 psi.
Bob and Nancy
Old 10-25-2014, 09:42 AM   #67
Or maybe you should have held the toilet valve open so the air could leave the tank as fast as it went in; the vent alone may not be large enough to let the compressed air out that fast.
WBCCI #1105
TAC LA-4
Old 10-25-2014, 02:04 PM   #68
TinTin's Avatar
Canmore , Alberta
Maybe. If the trailer were parked here at home, I'd give it another blow. As is, I think I got enough antifreeze in to solve the problem.
Bob and Nancy
Old 10-26-2014, 07:14 PM   #69
2012 30' Flying Cloud
Lake St Louis , Missouri
Concerning air compressors, oil filled vs non oil filled. I'm no expert on the subject, but believe I've read on the forum that non oil filled is preferred to prevent chances of oil contaminated air being pumped in the water lines. Two years ago I used my oil filled since it has more output, this year, today as a matter of fact, I used my smaller non oil filled compressor to be on the safe side. Would be interested in hearing from some of the more experienced folks on the subject, if there is any difference re safety.
Barry
WBCCI 11988
AirEgger is offline   Reply With Quote
Space Heater for Winterization jjagnew Winterizing, Storage, Carports & Covers 6 09-18-2010 01:38 PM
Southern Illinois 'One Last Rally Before Winterization' TinLoaf WBCCI Rallies & Events 55 11-10-2009 10:56 AM
Compressors and winterization luckydc Winterizing, Storage, Carports & Covers 7 11-28-2004 10:06 AM
What to do for winterization? FarHarley General Interior Topics 1 11-25-2004 05:25 AM
Winterization Blues - Water Heater Question BrianRegan Water Heaters, Filters & Pumps 0 06-13-2004 11:36 AM
