Old 10-09-2014, 07:14 PM   #43
IanPoulin's Avatar
2011 28' International
Aldie , Virginia
So any recommendations as to a quality unit for the task?
2011 Airstream International Serenity 28' - 30a/taupe
2013 Fors F150 v6-ecoboost with max tow and HD payload packages
2016 Ford F250 Crew 4x4 KR Diesel
IanPoulin is offline   Reply With Quote
Old 10-09-2014, 07:19 PM   #44
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Originally Posted by Inland RV Center, In View Post
A small air compressor cannot possibly provide enough air to correctly blow out the water lines.
Normally, a minimum of a 5 HP compressor is necessary to do the task correctly.
I use a 120vAC compressor rather than a 12v model, with a 1½-gallon air tank. Pressurize the tank to 125psi, with the air output from the tank regulated to about 45psi, and it does just fine for blowing out the lines. And the compressor isn't anywhere near 5hp, more like ¾hp. The whole compressor, tank included, is only about the size of a five-gallon bucket.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 10-10-2014, 04:53 AM   #45
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
The reports I've heard are that when the backflow preventer breaks you are tipped off by the flood occurring in the bathroom when you try to back flush.
2012 Dodge Durango Hemi/AWD
Old 10-10-2014, 06:56 AM   #46
richw46's Avatar
Lexington , Kentucky
I have a Sears model, cost about $100 6 or 7 years ago. It has a 3 gallon tank and a 1 HP pump. I think it weighs about 40 lbs. It did a great job yesterday. I was very pleased.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 10-10-2014, 07:39 AM   #47
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
I have a smaller sears 120v model that I carry with me. I haven't used it to winterize so I'm not sure if it's up to it. I did use it to pump my trailer tires back up to 80psi awhile ago and it tooooook forever. It does put out 100+psi but the volume is very small. In a pinch it did work for the tires but not as well as I hoped. The one Rich shows looks to be much better. For winterization I have a stationary large one to use.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 10-10-2014, 09:13 AM   #48
DO NOT set the pressure.
The pressure regulator in the trailer, does that for both water and air.
Old 10-11-2014, 09:11 AM   #49
richw46's Avatar
I think on this particular model you have to set it to something. There are two gauges on it, tank pressure and regulated pressure. I have the regulated pressure set for 100 psi but it doesn't go much higher. If you set it for anything less it becomes difficult to air up 50 lb psi tires because the tank pressure drops so fast. To blow out the lines I let tank pressure build to 100 psi, start blowing out the lines and it drops pretty fast but there's enough pressure to do a sink at a time. The pump kicks in at about 70 and I let it run until it drops to about 30. Then I stop until it goes back to 100 and do the same sink a second time. That takes care of it. After all the lines are clear I pump the pink stuff in. My AS has a separate inlet where I can put a tube into a gallon and let the pump draw it in.
-Rich
Rich & Yvonne
2004 4Runner SE
Old 10-11-2014, 09:30 AM   #50
TinTin's Avatar
2009 23' FB Flying Cloud
Canmore , Alberta
Andy, could you be more specific? In most air purge winterization instructions I've read, they suggest setting the pressure on the output side of your compressor to 50 psi or less to protect the PEX water lines. My tank pressure is regulated at 120 psi. If I set the output pressure to 50 psi, the compressor is able to maintain the 50 psi output.
Bob and Nancy
http://www.rwcphoto.smugmug.com
Cheer Up, Slow Down, Chill Out!
TinTin is offline   Reply With Quote
Old 10-11-2014, 09:43 AM   #51
The water pressure regulator also regulates the air pressure.
So if you have 100 psi as an example, the regulator will cut it down to it's setting.
Old 10-11-2014, 10:23 AM   #52
TinTin's Avatar
Canmore , Alberta
Great to know Andy, thanks.
Bob and Nancy
Old 10-20-2014, 09:23 AM   #53
TinTin's Avatar
Canmore , Alberta
I tried blowing out the black tank flush system the other day. I don't think much (or any) air got to the flush mechanism due to the plastic pop-up valve on that water line's inlet. Is this the black water backup protector or check valve that some have mentioned?
I did manage, with some difficulty, to get a little antifreeze down the line by pushing the valve in with my finger and using a spray bottle.
Bob and Nancy
Old 10-20-2014, 02:36 PM   #54
TinTin's Avatar
Canmore , Alberta
A little bump.
No one else has encountered this difficulty?
Bob and Nancy
Old 10-20-2014, 02:50 PM   #55
Landrum's Avatar
2014 25' FB International
Little Rock , Arkansas
I have always pumped antifreeze through the plumbing without blowing the lines first. I never thought about putting antifreeze into the black tank sprayer?? I wonder if I just got lucky since I haven't had it freeze or break?
Landrum is offline   Reply With Quote
Old 10-20-2014, 03:18 PM   #56
TinTin's Avatar
Canmore , Alberta
Earlier in the thread some have said it is advisable to blow it/antifreeze it. The reality I found for that particular line? Kinda difficult due to the backup valve at the inlet.
Bob and Nancy
Space Heater for Winterization jjagnew Winterizing, Storage, Carports & Covers 6 09-18-2010 01:38 PM
Southern Illinois 'One Last Rally Before Winterization' TinLoaf WBCCI Rallies & Events 55 11-10-2009 10:56 AM
Compressors and winterization luckydc Winterizing, Storage, Carports & Covers 7 11-28-2004 10:06 AM
What to do for winterization? FarHarley General Interior Topics 1 11-25-2004 05:25 AM
Winterization Blues - Water Heater Question BrianRegan Water Heaters, Filters & Pumps 0 06-13-2004 11:36 AM
