Old 10-07-2014, 03:32 PM   #29
TinTin's Avatar
2009 23' FB Flying Cloud
Canmore , Alberta
30 psi shouldn't cause anything to hit the fan!!!
Bob and Nancy
http://www.rwcphoto.smugmug.com
Cheer Up, Slow Down, Chill Out!
TinTin is offline   Reply With Quote
Old 10-07-2014, 03:38 PM   #30
SSquared's Avatar
2013 25' FB Flying Cloud
Longmont , Colorado
Black tank flusher
Originally Posted by PharmGeek View Post
oh crap...I had not thought about the black tank sprayer or the city water check valve both requiring compressed air....
I thought with my antifreeze through water pump to all places + p traps + a bit in black tank + a bit in grey tank I was in the clear....
I think that black hose that came with the trailer may be a little stupid 4-5 foot extension for the propane access port on the trailer? I could be wrong though....
I have a 2013 25FB Flying Cloud, with a blank tank flusher. The flusher brand is "No-Fuss Flush", model 336. I called the company and asked them about winterizing. They said the flusher did not need to be winterized. I did nothing to winterize it last year, and no leaks so far.
Some friends of mine bought a new Coleman SOB this year. It also has a blank tank flusher, but of a different brand (I don't remember the name). That flusher's instruction manual insists that you pump pink stuff through it for winter storage (they recommend you acquire and use a portable electric pump).
Last year and this year, I blew out the pipes with an air compressor (1 HP, 10 gallon tank), and then ran pink stuff through....belt and suspenders.
SSquared is offline   Reply With Quote
Old 10-07-2014, 03:44 PM   #31
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Originally Posted by HowieE View Post
That is a plastic tank and not designed to be pressurized. If over pressurized by an amateur the tank may fail before the toilet leaves the floor and hit the ceiling.
It's impossible to pressurize the black by blowing air into the black tank flush system with the dump valve closed, since it vented to the outside through the roof vent.
Alan
A W Warn is online now   Reply With Quote
Old 10-07-2014, 03:46 PM   #32
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
The issue is not the flusher itself, but rather the line leading to the flusher, which the flusher manufacturer doesn't necessarily even sell, let alone provide a warranty for.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Protagonist is online now   Reply With Quote
Old 10-07-2014, 04:01 PM   #33
HowieE's Avatar
Princeton , New Jersey
Images: 12
You are correct if the vent stack is open. But Eldridge's law says Murphy was an optimism. Be safe things have been known to hit the fan.
2004 Excursion 4x4
Old 10-08-2014, 07:55 AM   #34
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
Speaking as a Canadian where temperatures drop to sub-freezing, here is what I did: my protocol takes a bit longer for the first year, but thereafter can be done in less than 30 minutes. I have done this with all my trailers/motorhome since 1981 without incurring any frost damage. I use plumbing (potable) antifreeze rated to -50 degrees.
First get a 3-way valve (see Camco 36543-X RV Pump Converter Winterizing Kit: Amazon.ca: Automotive ) and install it at the water pump's intake side. As well, make sure you have a hot water tank bypass system; if not, install one (see: http://www.amazon.ca/Camco-35983-Qui...2PKK40VHPAHZCV ). - That is the initial setup.
Then:
1) engage the hot water by-pass valves; release the pressure valve at the top of the hot water tank and open the drain at the bottom of the hot water tank. You can take the opportunity to get a drain cap that includes a small valve for subsequent years.
2) Open the valve to empty the fresh water tank.
3) Open a single faucet and, using any compressor, blow air into the street water intake. You only need to clear the water from the street intake to the water pump. Remove any in-line water filters. If you have an accumulator tank, that also needs to be removed, the connection capped and the tank drained and put aside until spring.
4) Switch over the new 3-way valve at the pump and connect the clear hose to it (make sure it is snug). Put the open end of the clear hose into a jug of plumbing (potable) antifreeze and then switch on the water pump.
5) Making sure that you don't run out of antifreeze, open one faucet at a time and let the water run out until what pours out is the antifreeze (usually pink in color). Repeat this for all faucets, hot and cold, one at a time, including shower and exterior shower. Flush the toilet until the pink antifreeze comes out. Pour some antifreeze into each drain (sink, shower) to ensure that it replaces water in the P-trap.
At this point, you have replaced all the water throughout the system with potable antifreeze - your plumbing is now protected against freezing.
In the spring, flush the antifreeze out with water; reconnect the accumulator tank and in-line water filters. Make sure the 3-way valve lets street water in, the by-pass valve is switched over for the hot water tank, and both the pressure relief valve and drain on the hot water tank is closed. Connect to street water and run each faucet/valve one at a time until what flows is clear water.
In a 19-foot SOB, I could winterize with 1 gallon of anti-freeze; with my AS LY motorhome, I bought a 5-gallon jug of antifreeze (more pipes to protect). For the past 7 years, I decided on a different protocol - I head down to south-western Arizona in November and return back to Canada in April.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
blkmagikca is online now   Reply With Quote
Old 10-08-2014, 07:31 PM   #35
richw46's Avatar
Lexington , Kentucky
I am unable to get any water or air to flow through the pipe after connecting the compressor. The water drained from the low point valves OK, but nothing is coming through the municipal water connection. I've tried opening different faucets, but I can't even hear any air coming through. We use the municipal connection only once, about mid summer, but I think I should hear at least the air coming through. What am I not doing right?
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 10-08-2014, 10:18 PM   #36
Did you close the low point drains before adding compressed air?
WBCCI #1105
TAC LA-4
Old 10-09-2014, 06:47 AM   #37
TinTin's Avatar
Canmore , Alberta
As Protag mentions, make sure the low point drains under the freshwater tank are closed. You should also have two water system shutoffs which allow water to drain to the low points when in the open position. They should be in the closed position for normal use, (and when you pressurize and purge).
On my 23 footer they are located under the pantry.
Bob and Nancy
Old 10-09-2014, 07:08 AM   #38
richw46's Avatar
Yes, but I think the problem is the water heater. I opened the bypass valve but didn't close the feed lines. I opened up the water heater drain and it was full of air. I'll start up my compressor and try again when the neighbors are awake.
-Rich
Rich & Yvonne
2004 4Runner SE
Old 10-09-2014, 07:44 AM   #39
HowieE's Avatar
Images: 12
First off close the hot water bypass valve and drain the heater. Close any drain valve you may have opened, fresh water tank and low point drains.When purging the system with air there is no reason to have to open the low point drains. They are hard to get to and don't effective do anything to begin with.
Now with a schrader air to city water adapter connected to the city inlet have someone open a faucet closest to the city connection. While that valve is open apply a short burst of air, 2 or 3 seconds. Water should flow from the valve. Repeat short burst till just droplets come from the valve and close valve. Do the same with the hot valve on that faucet. Move to another faucet and repeat. Don't forget the toilet, toilet spray, and any outside faucet.
When the system is purged of all but the last drop pump in the anti freeze while opening the faucets one by one starting with the one closest to the pump. Once anti freeze appears at each faucet close the valve and move on.
Add 8 oz. of windshield antifreeze or pink stuff to each trap and the toilet.
The picture is of a homemade adapter but they are available premade.
Yes there will be a small amount of water in the tanks but not enough to cause a problem.
2004 Excursion 4x4
Old 10-09-2014, 08:53 AM   #40
richw46's Avatar
The first time winterizer figured it out. I opened the hot water cross-over but didn't close the inlet to the tank. Pressure had built up inside the tank. Second mistake was putting air into the black tank sprayer instead of the city water inlet. (D'oh!) Now THAT was a Homer Simpson . So that's good and clear now and I can clear the water lines.
-Rich
Rich & Yvonne
2004 4Runner SE
Old 10-09-2014, 01:06 PM   #41
IanPoulin's Avatar
2011 28' International
Aldie , Virginia
I hope it's not too great a tangent - but does anyone have a good suggestion for 12v capable air compressors for the task?
2011 Airstream International Serenity 28'
2016 Ford F250 Crew 4x4 KR Diesel
IanPoulin is offline   Reply With Quote
Old 10-09-2014, 06:31 PM   #42
A small air compressor cannot possibly provide enough air to correctly blow out the water lines.
Normally, a minimum of a 5 HP compressor is necessary to do the task correctly.
Space Heater for Winterization jjagnew Winterizing, Storage, Carports & Covers 6 09-18-2010 01:38 PM
Southern Illinois 'One Last Rally Before Winterization' TinLoaf WBCCI Rallies & Events 55 11-10-2009 10:56 AM
Compressors and winterization luckydc Winterizing, Storage, Carports & Covers 7 11-28-2004 10:06 AM
What to do for winterization? FarHarley General Interior Topics 1 11-25-2004 05:25 AM
Winterization Blues - Water Heater Question BrianRegan Water Heaters, Filters & Pumps 0 06-13-2004 11:36 AM
