Old 11-23-2008, 06:44 AM   #1
1977 31' Sovereign
Manchester , New Hampshire
Images: 33
Winter renovation heating.
Hey folks want to work on inside renovating or 1977 sovereign,Land yauht and was wonder if my kerosene ready heat 60000 BTU forced hot air heater would be ok if I left all the windows open and had a fan blowing in fresh air. Don"t want to die from CO poisoning.
1976 Airstream Sovereign International Landyacht (renovating)(found DOM plate said 1976)
1968 Airstream Caravel 17 footer
2004 Nissan Titan with BT package
K/N Cool intake air
Duel power exhaust
Mrcrowley is offline   Reply With Quote
Old 11-23-2008, 07:17 AM   #2
Ken J's Avatar
1956 22' Flying Cloud
Durango , Colorado
Images: 14
Can you get an electric heater in there?
1956 Flying Cloud
Founder :
Four Corners Unit
Albuquerque National Balloon Fiesta
Rally
Vintage Trailer Academy - Formerly the original
restoration rally
Ken J is offline   Reply With Quote
Old 11-23-2008, 07:42 AM   #3
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Heating with the windows wide open does sound counter productive. The clearance requirements for one of those heaters is quite large, usually eight feet from the exhaust.
I would go with electric heaters as a cleaner, safer option.
Richard
Old 11-23-2008, 08:05 AM   #4
AirsDream's Avatar
1999 23' Safari
Perrysburg , Ann Arbor
I've got a 100k BTU model like yours ... sometimes what I do is set it up to blow into an open doorway of e.g. a garage (and trailer would be much the same but smaller so heat up faster) for a half hour or so until things get warm enough to work, then shut it off and put in a small electric heater to keep the area warm while I'm in there working. But it always leaves a bit of a kerosene "smell" that takes quite a while to air out. This is eased by letting the heater "warm up" for a couple of minutes before starting active heating, so that it is operating at it's peak efficiency.
AirsDream is offline   Reply With Quote
Old 11-23-2008, 12:22 PM   #5
1977 31' Sovereign
Images: 33
It isn't to live in just so I can work inside of it with out freezing leaving windows open should be all right as far as c2o poisioning correct?
K/N Cool intake air
Duel power exhaust
Old 11-26-2008, 08:30 PM   #6
78GussyTX's Avatar
1978 Argosy 30
Alvin , Texas
Images: 8
You can buy some portable electric heat / A/C units for about $600 for high power, less for lower power. They have an exhaust tube that you can run out a door or window, plugging the rest of the opening with blankets etc. I am installing an exhaust port (like a dryer vent) in our 78 Argosy to allow using one all the time, we live in Texas where our problem is heat. This unit will supplement our standard roof A/C unit, and have the dual advantage of being able to remove it and use it on my boat if I want to. They are about 12,000 BTU as I recall, but you could run it safely all the time if you wanted to, and sell them when you are done. They also are on wheels for moving around and are only about a 15 x 16 inch footprint.
I would just be very leary about the kerosene blower. Even if it turned out to be safe, seems it could leave a long term odor, which would be a shame on a re-done interior.
Regards,
Steve
78GussyTX is offline   Reply With Quote
Radiant heating jerri Furnaces, Heaters, Fireplaces & Air Conditioning 64 06-29-2011 09:59 PM
Boondock heating..how to? Dan S Furnaces, Heaters, Fireplaces & Air Conditioning 6 03-04-2007 06:55 PM
Furnace and heating niftypkg Furnaces, Heaters, Fireplaces & Air Conditioning 12 02-23-2007 07:46 PM
transmission heating aeriqua Tow Vehicles 15 08-03-2006 12:28 AM
Heating in NC Penguin Furnaces, Heaters, Fireplaces & Air Conditioning 7 11-24-2004 04:29 AM
