Old 09-27-2019, 08:33 PM   #1
2018 27' Globetrotter
1976 25' Tradewind
Flushing , Michigan
Window seal lubricant idea—has anyone tried this?
To keep my window seals from sticking to the glass, I have tried a couple of things that were suggested: 1) rubbing silicone spray and 2) using olive oil on the seals. Neither of these practices has worked very well for me, and it seems that the seals again stick to the glass fairly soon, making opening the widows a real chore—I expect many have had this same experience.
I saw something about a product today that piqued my interest—a silicone grease used to lubricate seals on Honda vehicles. It is Shin-Etsu silicone grease and while a bit pricey, seems like it may have some merit. In the research that I did I found good reviews, but no mention of the specific application to lubricate Airstream widow seals so they do not stick.
Has anyone else had experience with this product, specifically to cure the window sticking issue, and with what results? Has anyone used other proven tactics successfully?
Thanks.
steve46 is offline   Reply With Quote
Old 09-27-2019, 08:36 PM   #2
Overkill Specialist
GMFL's Avatar
2014 23' International
Dadeville , Alabama
I use Otis silicon plumbing grease.
Old 09-27-2019, 09:14 PM   #3
Long Island , New York
Our dealer recommended 303 Protectant, as does AS I think. This version [wipes] is lightweight, easy to use, can't spill liquid anywhere, etc.:
https://www.amazon.com/303-Protectan...gateway&sr=8-6
https://airstreamsupplycompany.com/p...s/formula-303/
303 mentions on AF: https://www.google.com/search?q=303+...com&gws_rd=ssl
The wipes are also handy for things like the awning arms and their spring-loaded lock-in pins.
Old 09-27-2019, 09:41 PM   #4
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Aerospace 303 is also recommended by ZipDee for protecting the awning fabric.
Peace and Blessings..
Channing
WBCCI# 30676
Old 09-27-2019, 09:43 PM   #5
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Davidson County , North Carolina
For several years I've used Oatey silicone grease that plumbers use to prolong life of gaskets. A Q-tip dipped and applied to the window gasket keeps the seals pliable and keeps the window from sticking. It is inexpensive and readily available. One container will last for years. Cost ~$3.50.
https://www.oatey.com/ASSETS/DOCUMEN...coneGrease.pdf
https://www.lowes.com/pd/Oatey-Silic...wHHQ&gclsrc=ds
Alan
2014 Silverado 1500 Crew Cab 5.3L maximum trailering package
Old 09-27-2019, 10:05 PM   #6
2005 33' Land Yacht Gas 33
GULFPORT , MS
Originally Posted by steve46 View Post
to keep my window seals from sticking to the glass, i have tried a couple of things that were suggested: 1) rubbing silicone spray and 2) using olive oil on the seals. Neither of these practices has worked very well for me, and it seems that the seals again stick to the glass fairly soon, making opening the widows a real chore—i expect many have had this same experience.
I saw something about a product today that piqued my interest—a silicone grease used to lubricate seals on honda vehicles. It is shin-etsu silicone grease and while a bit pricey, seems like it may have some merit. In the research that i did i found good reviews, but no mention of the specific application to lubricate airstream widow seals so they do not stick.
Thanks.
wd-40
joeb3875 is offline   Reply With Quote
Old 09-27-2019, 10:47 PM   #7
dznf0g's Avatar
Oswego , Illinois
303 fabric guard is for awning fabric. Aerospace 303 is for seals and to protect plastics and rubber from UV. They are not the same product and are not interchangeable. Both work great.
-Rich-
Old 09-27-2019, 10:48 PM   #8
dznf0g's Avatar
Oswego , Illinois
I believe wd40 contains petroleum distillates. I'd never use on rubber.
Originally Posted by joeb3875 View Post
wd-40
-Rich-
Old 09-27-2019, 10:50 PM   #9
Gsmblue's Avatar
2015 25' Flying Cloud
Bend , Oregon
I had to adjust the clamps my windows. All of them compressed the seals so much it was tough to close them. I have always used 303 and I have window poppers to put in.
https://britishairstream.blogspot.com
Mad Astrophysicist turned sales guy that works to fund his dirty snowboarding habbit, mwah-ha-ha . . .
Gsmblue is offline   Reply With Quote
Old 09-27-2019, 11:03 PM   #10
SSquared's Avatar
2013 25' FB Flying Cloud
Longmont , Colorado
I don't think 303 protectant is good for sticking. I have used a lot of it since 2013, and it does help for a few days. But I soon have a line of residue on the glass, and the windows have to be opened from the outside every day.
On recommendation from the forum, I have also tried Gummi Pfledge, with similar results.
SSquared is offline   Reply With Quote
Old 09-27-2019, 11:10 PM   #11
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Oatey is what I meant. Spell check got my. Anyway..... it works great.
Old 09-27-2019, 11:48 PM   #12
Night owls's Avatar
2018 26' Flying Cloud
Hemet , California
I use 303 protectant but the seals still stick after a while. I've just gotten used to going outside and pulling it up carefully with a butter knife and easily comes open.
Night owls is offline   Reply With Quote
Old 09-27-2019, 11:51 PM   #13
2013 25' International
Boise , Idaho
My research led me to PFPE oil. Also called Krytox. I learned about it from others who use it to keep sunroofs from sticking to their seals - a lot like our problem. It is expensive but a small amount goes a long way. Look for it on ebay. I bet I use 4-10 drops of it on a qtip and it lubricates one entire seal. I lubricate the seals at the beginning of the camping year and don't generally need to reapply.
afk314 is offline   Reply With Quote
Old 09-28-2019, 12:24 AM   #14
2016 30' Flying Cloud
Byron , California
I applied the Honda grease about two months ago. It helps, but is not perfect. But at least I can open from inside. If they have been shut for a while there is a little bit of stick, but it will release without outside help.
I plan on putting on a second application soon.
I used a razor blade on the inside of the glass to remove residue. Wiped the rubber down with a mild soap/water, let dry, then applied the grease.
This is on a 2016 FC
obytheway is offline   Reply With Quote
Old 09-28-2019, 01:19 AM   #15
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
I used a paper towel that was sprayed with silicone and wiped the seals occasionally. I did notice over time that the seals when the windows were opened, the seals would collect dust on them and after a while the dust on those seals prevented the seals from sticking to the glass. After 15 years of use the windows no longer stick to those seals and pop open with a minimum of force.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 09-28-2019, 01:27 AM   #16
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, I have been using silicone spray on window and door seals since the late 60's and never had a problem. Spray it on and leave it.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 09-28-2019, 07:54 AM   #17
2015 30' FB FC Bunk
Ayer , Massachusetts
I think I will try this. Thanks.
Ted S. is offline   Reply With Quote
Old 09-28-2019, 08:06 AM   #18
dznf0g's Avatar
Oswego , Illinois
Odd about 303 comments. I only get re-sticking after a year, or more after application. I wonder if seals become less sticky with age.
-Rich-
Old 09-28-2019, 09:13 AM   #19
Lost in America
mojo's Avatar
2015 27' FB International
2004 19' International CCD
Santa Fe , New Mexico
Gave up on re-applying silicone and 303, they all seem to wear out in short time.
But these work great...
https://seeyoudowntheroad.com/produc...poppers-%C2%A9
This is the strangest life I've ever known - J. Morrison
2015 Airstream International Serenity 27FB
2017
Chevy Silverado 2500HD Duramax Diesel
mojo is offline   Reply With Quote
Old 09-28-2019, 10:14 AM   #20
2014 30' International
Whitney , Texas
I use 303. I treated them prior to our summer trip to Colorado. A few days later, when we got there, I had to assist them since they were lightly stuck.
Rbarlow is online now   Reply With Quote
Has anyone tried these? mnmhays Lights - Interior & Exterior 3 03-23-2015 09:13 PM
Has anyone tried this flooring? wannaroam Floor Finishes 164 10-18-2012 09:15 AM
Has anyone tried to install surge brakes on an AS? DougZ Brakes & Brake Controllers 8 03-03-2011 10:21 AM
Has anyone tried Fort Getty Campground in Rhode Island? Eckhart On The Road... 6 12-07-2010 07:17 PM
has anyone tried to finance and Old A/S lately? volvophile Financing 16 11-20-2005 12:17 PM
