09-28-2019, 09:24 AM
#21
2019 25' International
Washington
, Washington, D.C.
dznf0g - I wonder if the variability in how well the 303 works depends on how it is applied?
09-28-2019, 09:37 AM
#22
Lin
, Ne
ArmorAll?
#23
2017 16' Sport
N/A
, N/A
Silicone will not attract dust n’ dirt, that’s important for a good seal.
09-28-2019, 09:55 AM
#24
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach
We've been doing this a long time. The only real fix is to drill a 1/4 inch hole in the bottom of the screen surround. Then use a 1/4 inch wooden dowel to push the window open at the bottom. This is the only thing that we have found that works in the long run.
Brian
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
09-28-2019, 10:35 AM
#25
Airstream - Other
Bosque Farms
, New Mexico
Silicone grease (aka silicone paste) is great stuff. You can buy a couple of different brands of it on Amazon. Go for price. It is not inexpensive stuff.
Be a little careful. Silicone can cause some types of rubber to swell. Not a lot, but enough to make it somewhat different. (Old British sports cars -- my main connection to silicone -- often use silicone brake/clutch fluid, but if used on newer or some replacement rubber, it causes the rubber inside the cylinders to swell up and leak.)
Lynn
ACI Big Red Number 21043
09-28-2019, 11:37 AM
#26
2008 19' Bambi
2012 23' Flying Cloud
2016 25' Flying Cloud
Bandera
No lubricant....we installed Window Poppers from www.seeyadowntheroad.com.
09-28-2019, 12:21 PM
#27
Cave Creek
Tried the aero 303 for years and they still stuck. Got the window poppers a year ago. Never looked back - huge improvement
Pete B55
2017 Classic
2017 F-250
09-28-2019, 12:28 PM
#28
2020 25' Globetrotter
Santa Rosa
I’ve had mixed results with 303 protectant. The best thing that I’ve found for keeping the window seals from sticking for extended periods is Gummi Pflege, a German product used for rubber automotive seals. It’s a water based non-solvent formula that protects and conditions the rubber and doesn’t leave a residue that attracts dirt like silicone can. I still have a tube that I purchased direct from BMW years ago but it’s now available from several sources and manufactured under the name Nextzett Gummi Pflege. It comes with a foam applicator attached and you simply run it over the seals. Easy to use and no mess.
I’m sure the window poppers work great too but the thing is that the seals really should be treated routinely to protect them anyway so having something that serves both purposes is a plus.
Mike
2020 25' Globetrotter Twin | 2024 GMC Sierra 2500HD Denali Ult. 4x4 Duramax
400Ah Battle Born lithium battery string | 580W solar (400W roof 180W portable)
09-28-2019, 12:55 PM
#29
2012 28' International
bridgeport
, New York
What I have found after three Airstreams is that any lubricant is either messy or doesn’t work very long. I use a small dent puller, about 3 inches in diameter. Place it on glass , lock the handle and pull the window open.
09-28-2019, 12:58 PM
#30
Overland Adventurer
2009 34' Panamerica
Telluride
El cheapo plumbers grease works best.
09-28-2019, 01:17 PM
#31
Washington
, Missouri
I use 100% silicon oil.
09-28-2019, 02:58 PM
#32
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
I've tried various cleaners as well as a couple versions of the 303 "stuff". I'm still not real convinced any of it is any better than the others. Windows stick after a week or so, no matter what I use.
09-28-2019, 05:12 PM
#33
2007 22' International CCD
Corona
Window seal lubricant idea—has anyone tried this?
Weird recent experience. Airstream has been baking in the full Southern California sun for the past 6 years. Went to install my window popper thingies just before the last trip, expecting the windows to be stuck. Wonder of wonders, they opened just fine anyway.
Didn’t need to pry them open or anything. Maybe the seals settle down after a few years? Maybe a good coating of fine dust.
I’ll still install the window poppers to make it easier to bounce the windows open after I unlatch them, but I’m not having real sticking issues...
I did have one Fantastic Fan lid get stuck shut, but removing the screen and a gentle push with a long screwdriver got it opening normally again. It’s usually shut, but this issue showed up after a couple days on the road in high humidity. Not making a lot of sense.
09-28-2019, 07:34 PM
#34
2020 Classic 33
Box Elder
, South Dakota
Triple dittos for Window poppers. Single one for most windows and two for the front/rear windows and problem solved.
Gary
2020 Classic 33 Twin, 2019 Ram 3500 Longhorn, ProPride
NŘVPN
09-29-2019, 02:16 AM
#35
Washington
, Washington, D.C.
I think the reason they didn’t stick anymore is your window seals are dried out.
09-29-2019, 03:05 AM
#36
Owners of Willie
2019 27' Globetrotter
Peoria
Originally Posted by OTRA15
I’ve used 303 several times and it doesn’t help me much.
Owner of Willie
09-29-2019, 03:06 AM
#37
Owners of Willie
Peoria
Hi
Mine too.
Owner of Willie
09-29-2019, 09:09 AM
#38
eagle river
, Wisconsin
windows sticking
Good old Armor all works for me , as well as cleaning them with a glass cleaner with no alcohol ..
10-03-2019, 07:47 AM
#39
1976 25' Tradewind
Flushing
, Michigan
Thanks for all of the ideas. I now have some new things to try!
10-03-2019, 07:59 AM
#40
Tampa
Originally Posted by A W Warn
That checked all the boxes for me.
Visiting Lowe's today.
Thanks.
BTW, Last week, I tried opening several windows. One was easy, needs adjustment in, the rest were stuck. None seemed adjusted properly.
Bone tool on the way tomorrow!
I purchased six of the chrome window knobs, and when I went to install them (one setscrew). I hit the "You didn't expect it to be that easy, did you?" factor. The new setscrews are a different size than the old, you can't get to them without opening the windows, yada, yada!
