Old 11-17-2015, 12:36 PM   #1
The Rambler's Avatar
1964 26' Overlander
Ingleside , Texas
Window seal-floor recomendation
Hello friends, we are in the process of replacing floor sections and now are at the point of tracing leaks and repairing them. Here are some pics of the window and previous owners job of sealing, not very impressive to say the least so after removing this material as best I can what do you all recommend to use? I have heard pro silicon and never silicon, so all contributions are appreciated. Also the flooring material debate. Marine grade, treated, non treated, I know sealing the edges is important. Thanking you in advance. Steve & Lori
P.S. It also looks like I will have to remove and rivet a seam at this window. What type of rivets for this? Olympic?
https://mail-attachment.googleuserco...18Cygnrtn9OwEI
The Rambler is offline   Reply With Quote
Old 11-17-2015, 01:28 PM   #2
1990 32' Excella
jonesboro , Arkansas
Sealant
Having worked on 100 or so a/s over the last 17 years I have not found any thing that seals and holds up as well as vulkem poly urethane caulk.clean off the silicone and wipe off with alcohol and apply just a big enough bead to cover. Stays flexible and sticks to pretty much any surface. You can get it at most any ace hardware or industrial supply. Good luck.
joel is offline   Reply With Quote
Nashville Campground Recomendation? Marjon On The Road... 2 06-29-2011 05:06 AM
Hitch recomendation steven2themax Hitches, Couplers & Balls 2 10-08-2010 09:49 PM
Shock Recomendation gaylejoe Tow Vehicles 3 09-13-2010 01:46 PM
Winter Trip recomendation: Eagle viewing Boondocker On The Road... 36 12-06-2007 04:07 PM
Vertical lip seal and trim seal for Classic Motorhomes rdm General Motorhome Topics 16 05-22-2006 07:49 PM
