Old 12-07-2019, 04:16 PM   #1
2018 25' International
Slidell , Louisiana
Window Rock Guard Twist Fastener and Gromet Won't Hold
The rock guard was a little out of alignment so the metal catch got slightly pushed in to far when trying to fasten it. Now it won't fasten. I replaced it with a new one but the same thing happened. Are there any tricks to get it working correctly again with replacing it?
BayouBiker is online now   Reply With Quote
Old 12-07-2019, 05:01 PM   #2
Castaway's Avatar
2012 25' FB Flying Cloud
Celina , Ohio
Are you just turning 1/4 turn?
Castaway is offline   Reply With Quote
Old 12-07-2019, 05:20 PM   #3
Slidell , Louisiana
Yes, but the misalignment cause the fastener to not be fully inserted past the metal clasp so when turning it caught in the clasp and caused it to turn in the rubber grommet, now the metal clasp is depressed too deeply into the grommet...
Old 12-11-2019, 10:04 AM   #4
Slidell , Louisiana
Just bumping the tread to see if anyone has an easy solution, otherwise I will remove the one I just replaced and then be more careful in aligning it before twisting the new one and causing the catch to sink back too far into the rubber.
Brian
Old 12-11-2019, 10:24 AM   #5
AirMiles's Avatar
2018 27' Globetrotter
Apollo Beach , Florida
The attached link shows pictures of how I through-bolted my window rock guards on by reusing my defective "twisting" rubber grommets. http://www.airforums.com/forums/f42/...ml#post1996232
2018 Globetrotter 27Q, 32 nights 4,935 miles, 600W Solar, PD4655L, 6V Batteries, ProPride, 16" Michelin's, 2019 F250 PSD
Sold: 2017 Flying Cloud 25FB, 316 nights 40,150 miles, 400W Solar
Sold: 2013 Casita SD17 89 nights 16,200 miles
Solar Production: 213 kWh in 248 days of use
AirMiles is offline   Reply With Quote
Old 12-11-2019, 10:57 AM   #6
Slidell , Louisiana
Nice way to solve it permanently!
Brian
Rock guard fixed itself. We bought new RS rock guard, waiting for delivery, went to Garymaya Rock Guards, Segment & Window Protectors 1 09-20-2017 04:00 PM
28 FC front window rock guard front center window dayner Windows, Doors, Locks & Vents 0 08-29-2015 07:41 PM
Rock Guard Solar Standard Front window guard ChrisseasCC Windows, Doors, Locks & Vents 1 07-31-2014 08:32 AM
Window guard fastener pagoff Rock Guards, Segment & Window Protectors 8 04-22-2006 09:57 AM
Hold down for Rock Guard uwe Rock Guards, Segment & Window Protectors 5 04-24-2003 06:01 PM
